USB TO USB-C 2018 Tacoma
Discussion in '3rd Gen. Tacomas (2016-2023)' started by monroemcd, Jul 2, 2024.
  1. Jul 2, 2024 at 2:09 PM
    monroemcd
    monroemcd [OP] Member
    Monroe
    2018 Black TRD OFF-ROAD
    Hello all, I just recently got an IPhone 15 and bought a usb to usb-c. My phone would charge but I was not able to get my music playing. Anyone have ideas why this is happening or what to do about it? (Ps. I have a 2018 Tacoma).
  2. Jul 2, 2024 at 2:20 PM
    drizzoh
    drizzoh itsjdmy0
    Andrew
    Arizona
    2021 Tacoma TRD Off-Road 4x4
    Should be the same as 2021 for this, so make sure you're using the media port under the headunit on the dash. The port in the center console armrest is for charging only.
  3. Jul 2, 2024 at 2:22 PM
    monroemcd
    Monroe
    Thanks for the heads up. I am using the one under the head unit.
  4. Jul 2, 2024 at 2:24 PM
    drizzoh
    drizzoh itsjdmy0
    Andrew
    Arizona
    Bummer, would have to see it to know what the issue is then. Either something failed or an incompatibility. Will BT work?
    Also check if you have any available headunit software updates: Home | Toyota Software
  5. Jul 2, 2024 at 2:26 PM
    monroemcd
    Monroe
    BT Still works. It keeps saying please add compatible files to your ipod.
  6. Jul 2, 2024 at 4:16 PM
    NoOne
    NoOne El Taco Guapo
    Ø ©
    Gulf South
    2022 Tacoma DCLB OR (AT) - BC
    2018 SR5 - (Sold) 2018 OR - RIPieces 2022 OR - BluCrush
    2018 units aren’t CARPLAY. They will only read media files in standard format (Ala .mp3, .wav, etc.) iPhones never did a standard format (.aac I think?). Bluetooth is your best method. Otherwise, you’re relegated to audio out (mini-jack).
  7. Jul 2, 2024 at 4:19 PM
    monroemcd
    Monroe
    So I can’t listen to Spotify with my phone plugged in? I was able to on my old phone with the lightning cord.
  8. Jul 2, 2024 at 4:30 PM
    NoOne
    NoOne El Taco Guapo
    Ø ©
    Gulf South
    I believe it was doing that via Bluetooth, just charging via the cord. I honestly never used it that way, since BT was just less complicated. I did hook up a HDD with media files that it negotiated no problem.
    Perhaps that is an issue with firmware (radio) between lightning and USB-C negotiation/spec.
  9. Jul 31, 2024 at 12:55 PM
    monroemcd
    Monroe
    Thank you!
