USB to USB-C
Discussion in '3rd Gen. Tacomas (2016-2023)' started by GreyGhost, Dec 27, 2021.
  1. Dec 27, 2021 at 8:02 PM
    jcxd45
    jcxd45 Active Member
    22 Tacoma Limited
    JGO and tacoshell88 like this.
  2. Dec 27, 2021 at 8:23 PM
    tacovagon
    tacovagon Well-Known Member
    Dan
    Oceanside CA
    2016 SW SR5 DCLB 4x4
    ARB Locker 5100s w OME 887s OME EL095R Camburg BJ UCAs
    The Iphone still has the same old lightning connector on it and the same USB to lightning cables that you have always used will still work the same. You are not moving enough data to see any benefit in the USB-C connector.
    D. Lengua likes this.
  3. Dec 28, 2021 at 6:35 AM
    NJOffRoad
    NJOffRoad Well-Known Member
    Anthony
    Pine Barrens, NJ
    2021 Cement TRD OR 4x4
    -Off-Grid Engineering Dual Battery system with Redarc BCDC1225D and Full Throttle Group 35 AGM -SPOD BantamX -Expedition Essentials 3TPAM -Spiker Engineering hood struts -Taco Vinyl raptor grill -Baja Designs Squadron Sport fogs -Baja Designs Squadron Pro ditch lights -KC Cyclones under-hood lights -ARB Twin Compressor -Mobtown Offroad Skids & Sliders -Diamondback Tonneau Cover
    Yup and that center console USB C port allows true fast-charging for my S20 :bananadance:
  4. Dec 28, 2021 at 7:46 AM
    Doc62
    Doc62 Well-Known Member
    Dave
    SE Pennsylvania
    2021 Tacoma TRD Off Road, 2019 Sahara
    I had to buy a USB to USB-C cable to connect my iPad Pro to my computer. You would think it would come with the cable to connect to a computer to sync with iTunes out of the box. But then again it’s Apple.
  5. Dec 28, 2021 at 8:14 AM
    p_sando
    p_sando Well-Known Member
    utah
    2020 DCSB TRD OR 6MT
    I recommend an Apple lightning>USB-A cable. Seen a few posts on here about CarPlay issues with third party lightning cables, if it is that finicky then an adapter could also introduce problems.
  6. Dec 28, 2021 at 8:43 AM
    Taco_mike73
    Taco_mike73 Well-Known Member
    York, PA
    2020 Cement SR5 DCSB 4x4
    Lomax tonneau cover, oem bed lights, AJT Design chrome delete, black out badges & tailgate letters, AVS hood deflector & vent visors, Solkie tech hood supports, interior LED lights, Tufskinz mud guards, RedArc TowPro Liberty, bed mat, kicker speaker upgrade, Hikari ultra H11 low beams, Diode Dynamics SS3 fogs in yellow, Meso customs total taillight stage 1. Coming soon: Compact powered sub install Future mods planned: bigger tires (265/75/16) BILLSTIEN 5100 lift
    That must be a change they made for 2021 as my 2020 only has USB A ports in the center dash and inside the center console there are 2 USB -A
    None offer fast charge. I use a USB A to usb-c Cable for my OnePlus. 7pro. Of course nothing except OnePlus chargers will reach the 30 watt warp speed charging it can do.
    Edit
    Since I have the wireless Android auto thing coming in February from a Kickstarter. I think this will be the perfect way to go with my 7pro until I replace it with something that has wireless charging and install the aftermarket charging pad.
    This way is cheap and will charge me up as needed.
    VELOGK Warp Car Charger 30W [5V/6A] for Oneplus 9/8/8T/8 Pro/7 Pro/7T/7T Pro/Nord N10, Backward Compatible with Fast Dash Car Charger Adapter for Oneplus 7/6T/6/5T/5/3T/3(with 3.3FT Warp Type-C Cable) https://smile.amazon.com/dp/B08KYB9YDP?_encoding=UTF8
  7. Dec 28, 2021 at 8:58 AM
    Taco_Coma
    Taco_Coma That's a lovely accent you have. New Jersey?
    South NJ
    2018 DCSB SR5
    I mean you could just get a regular usb cord. The usb-c won’t have any special effect with an adapter
  8. Dec 28, 2021 at 9:11 AM
    GreyGhost
    GreyGhost [OP] Well-Known Member
    Eli
    Placentia, Ca.
    2020 TRD Sport
    Yes and no. All my iPhones and family iPhones and work iPhone all came with lightning to USB-C charging cables. I’m not trying to get a performance boost. Just wanted to transition to a USB-C receptacle since all my cables are USB-C.
  9. Dec 28, 2021 at 9:20 AM
    GreyGhost
    Eli
    Placentia, Ca.
    2020 TRD Sport
    Thanks for all the info. Probably didn’t make myself clear but I’m not trying to get a performance boost by switching to a USB C receptacle for my CarPlay. I do have a regular Lightning to USB A cable I’m using. It’s a 3rd party cable but works. Just figured I would change it out to a USB C if there was one available since all my current cables are lighting to USB C.
  10. Dec 28, 2021 at 9:54 AM
    tacovagon
    Dan
    Oceanside CA
    Just leave all of the USB-C cables in the box and continue using the old cables that have always worked and you won't have a problem. The new cables were intended for the people that charge their Iphones with their MACs. If you don't do that, you don't need the new cables.
  11. Dec 28, 2021 at 9:55 AM
    drizzoh
    drizzoh itsjdmy0
    Andrew
    Arizona
    2021 Tacoma TRD Off-Road 4x4
    On my '21 there's a USB-C in the center console. I just use Bluetooth and have the Qi charging feature in the truck so I haven't tried plugging the phone in, but is there any reason that will not work?
  12. Dec 28, 2021 at 7:54 PM
    GreyGhost
    Eli
    Placentia, Ca.
    2020 TRD Sport
    Don’t really think Apple made USB-C cables so people can charge from their Macs. There are a ton of people who don’t have Macs but have iPhones. USB A is old and slow technology.
  13. Dec 28, 2021 at 8:19 PM
    tacovagon
    Dan
    Oceanside CA
    Apple removed USB from new Macs and they are now USB-C only. They put USB-C cables in the Iphone box without USB-C power adapters. Draw your own conclusion. When charging, the data speed has no relevance. I don't even see a speed difference when using USB-C to update my Iphone software. Definitely no need for USB-C when mobile.
  14. Dec 29, 2021 at 6:49 PM
    GreyGhost
    Eli
    Placentia, Ca.
    2020 TRD Sport
    Watched a video on YouTube by Classy Tacos. Just tap in to your existing 12volt wire.
    tunamook[QUOTED] likes this.
