use aftermarket coils with stock shocks to lift front?
Discussion in 'Suspension' started by tmolina, Oct 28, 2009.
  1. Oct 28, 2009 at 12:14 PM
    tmolina
    tmolina [OP] Well-Known Member
    Thomas
    AZ
    '02 Tacoma dbl cab Prerunner
    2 inch lift with SAW's on front, AAL on rear
    Has anyone used OME coils or Eibach coils with stock struts to lift the front of a 1st gen. Tacoma?? If so what kind of ride quality did you get?? Both can be found at Toytec...Thanks
    Thomas
  2. Oct 28, 2009 at 1:10 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    FWIW, when using lifting coils, its a good idea to replace the shocks too.
  3. Oct 29, 2009 at 12:03 PM
    sirsaechao
    sirsaechao Well-Known Member
    Tim
    CA
    2002 Toyota Tacoma SR5 TRD 3.4L 4X4 V6
    A lift, some wheels, some tires, some performance, some cosmetic and then audio.
    Don't think they are long enough or the valving is wrong for aftermarket spring. I would get proper shocks valved for the stiffer springs...OME springs w/ OME shocks. Plus depending on the miles...I would change them out cause you will need a spring compressor and another alignment later when you replace them. Why not do them now and get an alignment done after? The rear is no problem and much easier but the front you have to deal with a spring compressor and alignment anytime you do anything to the suspension.
