Use an iPad mini for your Tacoma A/V System!
Discussion in 'Buy / Sell / Trade' started by shaneckc, Oct 11, 2014.
  1. Feb 19, 2015 at 4:15 PM
    #341
    shaneckc
    shaneckc [OP] Fyntünd Designs Vendor
    Shane
    Thousand Oaks, CA
    2014 SR Package DCLB 4x4
    Especially not in professional auto-paint shops, apparently.
  2. Feb 20, 2015 at 12:02 PM
    #342
    TOLLAV
    TOLLAV Wait, I have to drive ON the road??????
    Louisiana
    14 TRD Sport
    Email sent.
    Take my money please.......
  3. Feb 20, 2015 at 12:05 PM
    #343
    B737
    B737 Throbbing Member
    Kevin
    Jersey Shore
    2015 Tundra Double Cab Limited
    stock
  4. Feb 20, 2015 at 6:24 PM
    #344
    shaneckc
    Shane
    Thousand Oaks, CA
    I've got some not so exciting news and some very exciting (for some of us) news!
    The not so exciting news is that the paint shop that is painting the current kits in production has not finished re-painting them. I'm torn between remaking all of the kits this weekend and painting them myself (which would be about as expensive as the paint shop is charging to begin with) or to be patient.
    The very exciting news is that I am proud to reveal my take on a front loading iPad kit! This kit holds the iPad in via a tight pressure fit, as opposed to magnets as seen in other applications. The kit also comes with a docking cable attached to it, which plugs into the iPad when slid into place. The combination of these two things makes it superior to other methods because now, when you go offroading, hit a big bump in the road, or (god forbid) get in an accident, your iPad doesn't turn into a frisbee/projectile flying across your cabin!
    Please excuse the missing paint in certain areas of the kit. Some light modifications were necessary to this model to make stuff fit, the parts comprising the kit have already been amended in design and are being printed now.
    Check it out;
    And here is a short video showing the insert / removal of the iPad;
    https://www.youtube.com/watch?v=SsyrB7g_T9k
    This new style kit features my recently perfected 100% ABS plastic fabrication method. This means that there are no mechanical bonds present in the kit, and all pieces comprising the construction of the kit have been designed by yours truly, and are created using a 3d printer. Once all of the bonding and touch up work is done, these kits may as well be made out of one solid piece. These kits are as uniform and perfect as it gets.
    Notice that there is a large area between the upper and lower supports. This allows for a Single DIN radio to be placed behind that area, which can be accessed and used when the iPad is not in place.
    I am now accepting orders for this style of kit for $445, painted any color of your preference.
    This kit requires some modifications to be done in the vehicle for it to fit properly. The dash piece surrounding the radio needs to be modified like this;
    This can be done inside of the truck, or out with the dash piece removed. I recommend removing the dash piece and making the modification on a work bench. Removing the dash piece, using a rotary tool with a cutting/grinding disc, and replacing it can be done in about 10 - 30 minutes depending on your knowledge and skills with this type of stuff.
    You will also need to cut a small hole on the inside edge of the same piece, where your charging cable will be. The charging cable needs to be able to recess, slightly, into that area. This modification can not be seen once the dash is fully assembled, even with the factory radio in place.
  5. Feb 20, 2015 at 6:28 PM
    #345
    B737
    Kevin
    Jersey Shore
    stock
    does anyone want to buy a tundra? low miles!
  6. Feb 20, 2015 at 6:40 PM
    #346
    shaneckc
    Shane
    Thousand Oaks, CA
    hahahaha
  7. Feb 23, 2015 at 6:43 PM
    #347
    Pcyc
    Pcyc Self Proclaimed Leader
    Fritz
    Concord, CA
    09 DCSB TRD OR - Supercharged - Dual Cased - Twin Sticked
    https://www.tacomaworld.com/threads/pcyc-fj40-build.444289/ https://www.tacomaworld.com/threads/pcycs-2nd-gen-build.308160/
    so, when is mine shipping out? i am getting pumped!
  8. Feb 23, 2015 at 9:14 PM
    #348
    shaneckc
    Shane
    Thousand Oaks, CA
    You should be! I'll be sending you tracking info tomorrow.
    As for the rest of the kits;
    I went to go pick them up from the painter tonight and I was much happier with the quality of the paint. Except... The guy mixed up the colors on the kits. Flat kits went Glossy and Glossy kits went flat. He's fixing them, but that will be the last time this shop gets any of my business. After two shops failing to meet my expectations now, I'm just going to go ahead and start painting these myself. So I'm building a spray room this week and dropping about $800 on equipment / supplies to start painting on my own.
  9. Feb 24, 2015 at 5:12 AM
    #349
    Pcyc
    Fritz
    Concord, CA
    Nice! You will be happier in the end.
  10. Feb 24, 2015 at 6:47 AM
    #350
    TOLLAV
    Louisiana
    14 TRD Sport
    You can practice painting on my kit. You know freehand some unicorns, daisies, and shit.
    What???? I heard unicorns give +10HP and +2db and if you can milk a tear out of those SOBs that is sub 7 second ETs right there......
  11. Feb 24, 2015 at 10:20 AM
    #351
    shaneckc
    Shane
    Thousand Oaks, CA
    Hahaha, I'll do my best to airbrush a wicked ghost unicorn on your kit :D
  12. Feb 26, 2015 at 9:28 PM
    #352
    Ernesto4
    Ernesto4 Well-Known Member
    North Hollywood
    15 Tacoma access cab 5 lug SR5
    Great and here I was thinkin I finally bought everything I wanted for my stereo. I'm seriously considering buying an iPad mini just to buy this kit lol. Sorry if I'm being lazy and not going through the entire thread but how is everything hooked up to my speakers/ sub? What will everything be hooked up if i no longer have a headunit? Thanks
  13. Feb 26, 2015 at 9:58 PM
    #353
    shaneckc
    Shane
    Thousand Oaks, CA
    Haha, it really does change the whole look of the dash and it adds a TON of functions. It can also greatly improve your sound quality.
    Since you already have a full aftermarket system, there are a few ways that you can integrate it with your stereo. Each way offers different features. I'll attempt to break it down without leaving anything out.
    You can use an aftermarket head unit behind the iPad
    This will allow you to retain:
    Bluetooth hands free calling
    Bluetooth streaming Audio
    AM/FM/HD/SAT radio
    CD player
    iPod/USB input
    aux in
    I recommend, and sell, Sony radios for this. Specifically ones that support AppRemote. This allows you to control the different sources of the head unit from the iPad itself.
    You can use a home audio iPod dock
    Steering wheel controls
    .... That's pretty much it.
    But, it gives you the opportunity to use a really high end iPod dock with a quality digital to analog converter, or opens up doors like supplying your high end audio processor (like an Audison Bit Ten/One) with a digital optical sound input. It gives you a single RCA output for your amps, which you can distribute to as many as you want. You CAN retain hands free bluetooth depending on what equipment you choose / how you wire it. This method is a bit more advanced but it has its benefits for those who value them.
    I offer pre-harnessed packages of both of the options mentioned above. I base my pricing off of the lowest prices for each item in the packages found on the internet, and a labor charge which varies depending on how intricate the harness is. I solder all connections made for the harness, and the finished product is as close to plug and play as it gets.
  14. Feb 26, 2015 at 10:23 PM
    #354
    Ernesto4
    North Hollywood
    The price of $445 includes the Sony radio? Also is there anything behind the mount or are you able to just see all the wires when the iPad isn't mounted? I'm local so this is tempting
  15. Feb 26, 2015 at 11:18 PM
    #355
    shaneckc
    Shane
    Thousand Oaks, CA
    The $445 includes the dash / trim kit only. The back of the kit is left open so that you can still access and operate a radio. It'd be very easy to put a backing on it, though.
    Since you're local, I'd be willing to help you with the install portion of it. And if you wanted to check it out in person, I'm out in LA pretty frequently. Will definitely be out there one evening next week.
  16. Feb 28, 2015 at 7:22 PM
    #356
    shaneckc
    Shane
    Thousand Oaks, CA
    Bump
    3 kits ordered so far for the next production batch. Trying to get up to 5.
    All kits in the current batch will be sent out next week unless seller has requested that the kit be held.
  17. Mar 2, 2015 at 2:05 PM
    #357
    treysome
    treysome Member
    2013 4x4 SR5 Double Cab Long Bed
    Are one of those kits being shipped out this week mine? Can't wait to get this installed!
  18. Mar 2, 2015 at 3:54 PM
    #358
    shaneckc
    Shane
    Thousand Oaks, CA
    Yep! Yours will be shipped out this week!
  19. Mar 2, 2015 at 10:36 PM
    #359
    tacomonazul
    tacomonazul Well-Known Member
    Luis
    SOCAL
    07 DCSB LT/4LINK
    http://www.tacomaworld.com/forum/2nd-gen-builds/227832-my-never-end-build.html
    Hey Shane, how can I make the iPure 12V?
  20. Mar 3, 2015 at 9:59 AM
    #360
    shaneckc
    Shane
    Thousand Oaks, CA
    Hey Luis,
    To make the iPure work in a 12v application, you'll need a 12v to 7.5v step down transformer.
