Use an old CB?
Discussion in 'Audio & Video' started by NativeTaco, Mar 10, 2013.
  1. Mar 10, 2013 at 2:23 PM
    NativeTaco
    NativeTaco [OP] Mountain Man
    Travis
    Fort Collins, CO
    '08 DCLB
    ARB, OME, BAMF, ATO, Rigid, more... Mountain Man Limousine
    I was given an old cb radio by a relative, and I was wondering if it would be worth trying to use? It is an old Cobra, but I dont know the model. I would buy a quality antenna be have someone tune everything, but the unit IS old and doesn't look to have been the top of the line back in its day either. I will only be using it on wheeling trips, but moab will have some times where range is needed. Should I even waste time and money on this unit?
  2. Mar 10, 2013 at 2:38 PM
    David K
    David K Well-Known Member
    San Marcos, Alta California
    2010 4WD Off Road DC
    I have a CB so old, it has only 23 channels... so I added some with crystals! I am talking the 1970's. It is a Browning... small and high quality... still works (I think)...
  3. Mar 10, 2013 at 3:29 PM
    Rich91710
    Rich91710 Well-Known Member
    Rich
    Los Angeles
    08 Base
    Cobra is owned by Uniden, and has been around for a very long time and have always made very good radios.
    If you have something like a 148GTL, that was "the" radio to have back in the 80s.
  4. Mar 10, 2013 at 6:36 PM
    NativeTaco
    Travis
    Fort Collins, CO
    '08 DCLB
    Looks like a TRC-247, will have to do some research...
  5. Mar 11, 2013 at 6:07 AM
    LUSETACO
    LUSETACO Here for the Taco Pron
    Dennis
    Aim-ish country PA
    Make: Chevy Model: Pile
    Yes
    Did you mean a TRC-427? If so I believe those were built on the same chassis as the Cobra 25. Might be an alright radio. You are always taking a chance on an older radio like that though. But if it was free may as well give it a go. You will have everything in place for your setup. If the radio doesn't work out just swap in a different one and re-tune the antenna. I would like to see this thing, I love old CB's!
  6. Mar 12, 2013 at 12:44 PM
    NativeTaco
    Travis
    Fort Collins, CO
    '08 DCLB
    It is the 427! I will take some pics when I get a chance and report the functionality after the install. Antenna suggestions?
  7. Mar 12, 2013 at 12:53 PM
    4Wheelin4Banger
    4Wheelin4Banger Longtime Toyman
    Randy
    Ferntucky, NV Halfway between Reno & Falabama
    2011 4x4 Access Cab Silver State Edition
    3" OME lift 885s & Dakars riding on 33" KM2s Click the sig pic to see the build thread .
    3', 4', or 5' Firestick with spring.
    With a Relentless hood mount
    And a Firewire cable.
    I got an old CB for free and all I need is the Firestick.
  8. Mar 12, 2013 at 4:19 PM
    LUSETACO
    Dennis
    Aim-ish country PA
    Yes
    I've never had much luck with Firestiks. The choice is yours though. I would suggest a Little Wilson or Wilson 1ooo. They are super easy to install and out of the 3 Wilsons I've had I only had to make one minor adjustment to tune one of them. They are easy to take off when you don't need it also.
