Use fog light as headlight
Discussion in 'Lighting' started by Kietzilla, Jul 19, 2021.
  1. Jul 27, 2021 at 6:48 AM
    TacoFergie
    TacoFergie Well-Known Member
    Iowa
    For wiring check out these two threads. But I also know the 3rd gens are more difficult to do as a "fog light on anytime" mod compared to the 2nd gens.
    This one refers to stock wiring and compares if your truck came with the stock wiring or not.
    https://www.tacomaworld.com/threads/nitoris-oem-sr-foglight-mod.451495/
    This one has part numbers for the bezels and shows how to wire them independently from your factory wiring so you can use them anytime (ie headlights off, on and high beams). Factory settings only allow fog lights to be on when low beams are on. If your low beams are off or you switch your high beams on the will turn off.
    https://www.tacomaworld.com/threads...-light-mod-step-by-step-picture-heavy.403875/
    I personally like OEM switches since they don't stand out from the rest of your dash switches. But if you like a different color light in the switch, there are many options that are cheaper. CH4x4.com has been reliable for me and has tons of options!
    https://www.amazon.com/dp/B00DWVNBIC
    Harness
    https://www.amazon.com/Toyota-Genui...6b45eaa2be0&pd_rd_wg=ZhUPl&pd_rd_i=B00DWVNCI6
    If you are capable, willing and like to do your own wiring I really like these for waterproof relay/fuse integrated add on circuits.
    https://www.ebay.com/itm/Waterproof...y-Tall-Cover-12-V-Car-Truck-ATV-/292027499244
