Use HW 990 + Sumos Same Time Review
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Caesar8975, Feb 7, 2020.
  1. Feb 7, 2020 at 4:10 PM
    Caesar8975
    Caesar8975 [OP] New Member
    2012 Tacoma 2.7 4x4 Reg Cab
    Kc G4 fog lights Kc hood lights 883 Emu coils Hellwig 2000 lb leafs Sumo spring 1000 lb Custom Led bed lights
    Ever have load capacity issues with your tacoma? I sure did. The rear leafs couldn't handle half a truck bed of wood before bottoming out. They are non tsb springs. I decided to run the Hellwig Ez-990 2000 lb capacity leaf springs with sumospring 1000 lb capacity bump-stops rather than swap leafs. The ride is firm but not harsh at all. When it has 250 or more lbs in the rear, the truck rides absolutely smooth. You can stack wood to the top of the cab and it wont even bottom out.The rear raised .75 to an inch. It completely fixed “bed hop”. Overall it rides like my 92 F150. I highly recommend this setup for anyone who needs a stout truck. It also retained lots of flexibility off-road.
