Use of 4 wheel drive.
Discussion in '3rd Gen. Tacomas (2016-2023)' started by NTSALL4, Jul 30, 2017.
  1. Jul 31, 2017 at 11:35 AM
    LeftCoastNerd
    LeftCoastNerd Old 'nuff to know betta
    Santa Cruz, California
    08 AC 4x4 OR 6sp
    a wise friend of mine said "4x4 isn't for getting you in, its for getting you out!" ... I *did* use 4Lo when I was climbing over North Pass in Death Valley in 2 feet of snow. I also used it when pulling a subaru out of a big mud puddle
  2. Jul 31, 2017 at 11:46 AM
    Trident904
    Trident904 Touching Drum Sets
    Brian
    Treasure Coast, Florida
    17 4Runner TRD OR
    Modded it so much it turned into a 4Runner
    I got told I was being unsafe by not being in 4wd
    GotToyota likes this.
  3. Jul 31, 2017 at 11:56 AM
    Toyo_newb
    Toyo_newb Well-Known Member
    Matthew
    2017 DCLB TRD OR 4x4 QUICKSAND
    Just go on trails where you need to use it at least once a month. It's way more fun that way.
  4. Jul 31, 2017 at 12:10 PM
    NM Lance
    NM Lance Well-Known Member
    I do it as often as I think about it. It took 5 tries to get mine in, and out, of 4X4 high when it was brand new. Now that I have used it a few times, I can get it in and out in one shot.
    I just want the peace of mind knowing it will engage when I get it stuck again.
    BassAckwards likes this.
  5. Jul 31, 2017 at 12:15 PM
    coopcooper
    coopcooper certified youtube mechanic
    alberta canada
    black on black on black 05 trd off road
    stickers and sticker accessory's
    took me a solid hour to get my truck into 4lo when I first bought it. then another half hour to get the rear locker to engage. nastiest clunk sound ive ever heard from a tcase when it finally engaged. clearly the guy that owned it before me never used 4lo or the locker.
  6. Jul 31, 2017 at 4:59 PM
    Barcared
    Barcared Well-Known Member
    Philadelphia, PA
    2016 Barcelona Red TRDOR RIP. 2020 MGM TRD OR.
    I don't think it turns all the time? only think so from first time I greased the zerks. I turned the front with my hands to get access to the zerks. I thought the rears were lined up ok, but they were just a bit off to grease, so I put in reverse and backed up a few inches. It put the rear driveline zerks right where I needed it, but the front drive shaft stayed just where I left it.
    Based on the size and volume of front diff, I'd think that bumps and turns are enough to splash enough fluid on the gears, but maybe need to shift just to keep the u joints greased?
  7. Jul 31, 2017 at 5:30 PM
    splitbolt
    splitbolt Voodoo Witch Doctor
    NW Arkansas
    2016 TRD OFFROAD DCSB MGM
    I think the main point is to heat it up enough to burn off moisture.
    Grey 2015 likes this.
  8. Jul 31, 2017 at 5:51 PM
    Paterico
    Paterico Well-Known Member
    San Antonio, TX
    2017 DCSB TRD OR 4x4
    If you have a highway commute just engage it on the entrance ramp to the highway and turn it off as you're slowing down and exiting. That's how I do it
  9. Jul 31, 2017 at 6:04 PM
    mynewtoy
    mynewtoy I like men
    greg
    Mississippi
    09 double cab 4x4
    Detriot locker rear ARB air locker front 4.56 gears OME 3" lift, SPC uca's , moto metal 951 wheels 315/75/r16 Treadwright guard dogs, homemade front plate bumper with smittybilt 9.5k winch, homemade skids, homemade Bed bars, Mobtown offroad high clearance rear bumper with tire carrier, Homemade rock sliders , U-bolt flip, Wheeler's super bumps, BORA 1" wheel spacers , Black headlight mod , black tail lights, Satoshi Grill , autoPage C3 RS-665 alarm with remote start, flowmaster 40 series exhaust, cruise control,bed/ground effect lights, wet okole seat covers, tinted,windows, weather tech floor mats, AVS vent shades, debadged, hidden cobra 19 cb, 7" offroad lights behind grill, rear diff breather relocate, abs kill switch
    :eek::eek:wtf are you guys talking about. I bought a 4x4 and I use it at all times for max traction
    I'm joking don't tear your truck up :D
    NM Lance likes this.
  10. Jul 31, 2017 at 7:09 PM
    joepagejr
    joepagejr Well-Known Member
    Joe
    2016 TRD Off-Road Access Cab - Inferno
    https://youtu.be/xUFQ2ECfPOw
  11. Jul 31, 2017 at 7:13 PM
    asc
    asc Well-Known Member
    Just do it once per month when it's raining outside. It keeps things lubed.
    BrotherBudro and GotToyota like this.
  12. Aug 1, 2017 at 9:10 AM
    Grey 2015
    Grey 2015 Well-Known Member
    Skip
    Loxahatchee Florida
    2015 Tacoma
    Front CV's turn all the time isn't that the major cause on boot failure on some lifted trucks? I myself don't fully understand the "ADD" thing but I believe due to it the turning of parts stops at the front driveshaft coming out of the front diff. I have heard reasoning for doing this is too lube up gears and has splitbolt mentioned "to burn off any moisture".
  13. Aug 1, 2017 at 9:25 AM
    splitbolt
    NW Arkansas
    ADD part starts at 12:04.
    JoshyP and Grey 2015[QUOTED] like this.
  14. Aug 1, 2017 at 9:59 AM
    JoeCOVA
    JoeCOVA Well-Known Member
    Joe
    Colorado Springs
    Easy for me! I put on about 500 miles offroad a month!
  15. Aug 1, 2017 at 10:06 AM
    #35
    OnHartung'sRoad
    OnHartung'sRoad -So glad I didn't take the other...
    Somewhere in the Mojave Desert...
    2017 Tacoma OR 4x4 (formerly 2002 OR 4x4, 1995 4x4 4Runner, 1985 4x4 Toy PU) ... and RIP’s (rust in pieces) to a Bronco II 4x4 & S10 Blazer 4x4
    That's an excuse to take time out of your household duties to go 4-wheeling at least once a month- "see honey, it says it right there..."
  16. Aug 1, 2017 at 1:30 PM
    #36
    Grey 2015
    Skip
    Loxahatchee Florida
    2015 Tacoma
    Thanks super informative! So the drivers side is always spinning slinging some lube around in there? I know with manual hubs nothing in there moves unless the hubs are locked or the transfer case is engaged.
    SOSC likes this.
  17. Aug 1, 2017 at 1:55 PM
    #37
    splitbolt
    NW Arkansas
    Yes.
    The differential gears spinning induce movement on the ring gear as well, so it goes for a dip too.
    That's why I believe heat is the main goal and the recommendation of 10 miles.
    Grey 2015[QUOTED] likes this.
  18. Aug 1, 2017 at 2:03 PM
    #38
    Jibbs
    Jibbs "When in doubt, throttle out!"
    Josh
    Cincinnati
    2017 SCREW Raptor Lightning Blue
    Whoooooooshchchch
    I use 4Lo alot on the muddy hills we get to wheel on because I have a stick and it saves my clutch. Plus cause I'm just lazy. Mostly the latter. Seriously, wheeling on hills is about the only time you'll really hear me bitch about how these trucks don't have any torque down low. You just can't get up the fuckers without taking thousands of miles off the clutch. 4Lo though and its a cinch
    02Duck and MOC221_ like this.
  19. Aug 1, 2017 at 2:12 PM
    #39
    melikeymy beer
    melikeymy beer Hold my beer and watch this
    2019 Tundra
    We don't need no stinking manual. The manual also says to change your oil at 10k miles. Most third gen TW Tacoma owners however change their oil at 500, 1,000, 2,500, 5,000, and after that every 3,000 miles.
    Woodrow F Call likes this.
  20. Aug 1, 2017 at 2:15 PM
    #40
    MOC221_
    MOC221_ 3 pedal metal
    Frank
    2019 DCSB Sport M/T Barcelona Red
    vF Tuned; ADM; Core SS
    Not to mention you'll want to be going a lot slower over rocks ruts n shit than 4Hi 1st gear will allow with the clutch out. 4lo 1st gear and let her work.
    02Duck likes this.
