Used 4.88 gears
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Zeptiix, Oct 29, 2023.
  1. Oct 29, 2023 at 2:35 PM
    Zeptiix
    Zeptiix [OP] Well-Known Member
    2021 OR Army Green
    Bought some used 4.88 nitro gears off someone local. According to him everything is all put together but I was wondering if I took all this to a mechanic would it be all I need? I was just a bit weary because I know there should be shims and other things. Thanks in advance![​IMG]
  2. Oct 29, 2023 at 3:21 PM
    faawrenchbndr
    faawrenchbndr Til Valhalla
    Greg
    Denver, Indiana
    ‘23 Sport 4x4 DCSB
    Crap……I would never buy used gears
    Is there any wear marks on the ring gear teeth?
    SR-71A, na8rboy, wilcam47 and 3 others like this.
  3. Oct 29, 2023 at 4:41 PM
    Zeptiix
    2021 OR Army Green
    There isn’t that much wear to be honest, the guy only used them for a little under a year and around 5k miles
    wilcam47 likes this.
  4. Oct 29, 2023 at 4:43 PM
    socalexpeditions
    socalexpeditions IG: @socalexpeditions
    Problem with used gears is that they have already been broken in. The metal has meshed in a certain way (gear pattern) that probably will not be replicated when you install it on your truck. Some future problems can arise from this. Just a heads up.
  5. Oct 29, 2023 at 4:54 PM
    joba27n
    joba27n YotaWerx Authorized tuner
    Nolan
    Alberta
    2021 Gray TRD Sport Tacoma MT
    YotaWerx Stage 1, Bumper light bar, Hood wrap, Roadmaster Active Suspension, Durobumps.
    I agree with the above mentioned about future possible issues, however an experienced driveline guy can set you straight. Just make sure you replace all the bearings and races for it. Don't reuse the bearings. If all the measurements are done like backlash and runout and gear pattern is okay then you should be fine. This is a hunting gear set so it doesn't have to be timed
    Junkhead and wilcam47 like this.
  6. Oct 29, 2023 at 5:12 PM
    Evan_P
    Evan_P Well-Known Member
    Evan
    Hillsboro OR
    2020 Voodoo Blue TRD Off-Road
    We wouldn’t touch that job in our shop. No way of knowing how the gears were setup previously and they are likely to end up noisy if the new pattern doesn’t match the old wear.
    Junkhead, Chew and wilcam47 like this.
  7. Oct 29, 2023 at 5:20 PM
    faawrenchbndr
    Greg
    Denver, Indiana
    ‘23 Sport 4x4 DCSB
    The reasons above……bad juju
    Get your money back if you can
  8. Oct 29, 2023 at 5:46 PM
    Chew
    Chew Not so well known user
    Chewy
    Midwest
    19 TRD OR
    Amazon dog poo bed mat mod
    I was wondering if a shop wouldn’t want to install due to a good chance of an unhappy customer and them not knowing if they were setup correctly to begin with.
    I’d think the cost of proper install is as much or more than the gears themselves, so I can’t imagine the draw to used.
    Junkhead likes this.
  9. Oct 29, 2023 at 5:50 PM
    faawrenchbndr
    Greg
    Denver, Indiana
    ‘23 Sport 4x4 DCSB
    Back when I was building Jeeps, a diff setup was about $500 in labor alone.
    Junkhead and Chew[QUOTED] like this.
  10. Oct 29, 2023 at 5:56 PM
    na8rboy
    na8rboy 18 DCLB Sport Cement
    WI
    18 DCLB SPORT CEMENT
    All of the above. I would never trust/install used gears.
    Junkhead and Chew like this.
  11. Oct 29, 2023 at 6:17 PM
    ShimStack
    ShimStack Well-Known Member
    Ben
    NC
    '91 Truggy, '98 Project, '16 DC OR M/T Locked F/R
    I wouldn't be quite so fearful of a used gear set. If it isn't showing any signs of damage, abnormal wear, or spun bearings they'll be just fine once setup to spec.
    Buying a gear set all you can expect to get is a ring and pinion. Bearings, hardware, shims, etc. come in an install kit which you will want to purchase.
    faawrenchbndr likes this.
  12. Oct 29, 2023 at 6:39 PM
    Stocklocker
    Stocklocker Well-Known Member
    17TRDORDCSBAT
    Geez. It’s just a gear set, not the Space Shuttle, find a shop that knows what there are doing, and get their professional advice with the used gears in hand. They are probably fine. Most people don’t abuse their shit then try to sell it to unsuspecting people.
    Lone_Wolf77 likes this.
  13. Oct 29, 2023 at 7:48 PM
    Evan_P
    Evan
    Hillsboro OR
    The issue here is not that a shop may not know how to set them up correct or that there is something wrong with the gears, it’s that with used gears there is already a certain mesh that has been worn into the gears and any deviation away from that may very well cause noise. Now it would probably live just fine, even my 4.88’s are not quiet and haven’t been since day 1, but when you charge someone potentially multiple thousands of dollars to install parts, even when they provide them, there is a good chance they are going to be upset. That is a risk that is just not worth it to many shops.
  14. Oct 30, 2023 at 3:40 AM
    faawrenchbndr
    Greg
    Denver, Indiana
    ‘23 Sport 4x4 DCSB
    Correct, it’s not rocket science, but it’s not Legos either.
    It’s kind of like reusing a camshaft and lifters. The old-school camshafts, solids and hydraulics,
    when broken in, the lifters and the cam lobes mate.
    If at some point, a new set of lifters are installed, or the lifter locations were switched, it’s a 50-50 chance on whether the lifters will eat the cam lobes off.
    The same situation when installing used gears. If they are able to be set up nearly identical like the first time they were installed, there shouldn’t be a problem. If the gear lash is not set up to that identical previous pattern, gear noise and extreme wear can be a major issue.
    Junkhead, Chew and na8rboy like this.
  15. Oct 30, 2023 at 4:32 AM
    airforceb2cc
    airforceb2cc Well-Known Member
    Don
    KCMO
    2021 DCSB Nightshade
    Ironman FCP; 315/75R16; KDMAX; Skids; Sliders
    It depends what you got. Is it just the ring and pinions or is it both 3rd members? If 3rd members, bolt those suckers up and fill them. If just the ring and pinion, you can have a shop install them but will most likely need to buy shims and I would do the ECGS clamshell while you are at it.
  16. Oct 30, 2023 at 5:34 AM
    faawrenchbndr
    Greg
    Denver, Indiana
    ‘23 Sport 4x4 DCSB
    That’s a great point……but the pinion is sitting in the bottom of a box
    Chew likes this.
  17. Oct 30, 2023 at 5:44 AM
    airforceb2cc
    Don
    KCMO
    That's so weird. Pictures didn't show up when I first looked. Yeah, I would pass on that.
  18. Oct 30, 2023 at 5:47 AM
    clg
    clg Well-Known Member
    2017 Off-road
    "All put together".....shows pinion at the bottom of a box.
    The mesh is already set into the gear, so you're either hoping to set it up with the exact same pattern (good luck with that), or you're going to have an awfully loud and abnormally wearing set of gears. So yes, the gears themselves may be fine, but assembly of them into the 3rd members to achieve a reliable assembled gearset is not worth the risk.
    But hey, save a few hundred but spend thousands on installation and master install kit. Makes sense...
  19. Oct 30, 2023 at 5:51 AM
    Buck Henry
    Buck Henry Well-Known Member
    2019 White TRD Off Road
    It'll fucking work just fine. I say go for it OP. But then again, what the hell do I know.
    Carry on
  20. Oct 30, 2023 at 5:10 PM
    Stocklocker
    17TRDORDCSBAT
    Re-read what I wrote. Keywords are “get professional advice”. That ain’t shitposters on TW, no offence.
