Used 4Hi on pavement...what now?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by tacopasu, Oct 15, 2016.
  1. Oct 15, 2016 at 7:01 PM
    tacopasu
    tacopasu [OP] Well-Known Member
    2016 Blue TRD Sport LB 4x4
    Guys, noob here needs some advise. I used my 4hi for the first time today on dry pavement. I mean I drove at least 5 miles including making a couple turns. I felt something was off when I was pulling on my driveway today as it was super hard to navigate the car in low speed in 4hi. I then found out I wasn't suppose to use 4hi on pavement...ever. Question is, have I screwed up my Tacoma? Should I bring it in for a check up? It only has 3k miles on it btw. Thanks for reading and I appreciate any advice at this point.
  2. Oct 15, 2016 at 7:04 PM
    rngr
    rngr Aix sponsa
    01 SR5 4x4 2.7L
    It's fine. Just don't make a habit of it.
    3dBdown, 0210, Joe23 and 1 other person like this.
  3. Oct 15, 2016 at 7:06 PM
    DustStorm4x4
    DustStorm4x4 BBC 2020
    U S A
    04 Jeep LJ
    Check your CVs at most. I wouldn't worry about it.
    Joe23 and tacopasu[OP] like this.
  4. Oct 15, 2016 at 7:06 PM
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
  5. Oct 15, 2016 at 7:08 PM
    FritoBandito
    FritoBandito Well-Known Member
    Texas
    2016 Limited 4X4 DCSB
    Ditto. It's fine.. just don't do it going forward.
  6. Oct 15, 2016 at 7:09 PM
    neverstuck
    neverstuck Well-Known Member
    Guido
    Lebanon
    13 DCLB sport
    slide-in camper, OME Nitros w 884's and Dakars, Michelin A/T2, Pro EFX heated towing mirrors, Timbren HD bumpstops, KB VooDoo bed rails and tailgate cap, ImMrYo rvm bracket, G-Tek Fab door sill protectors, Ultragauge, window visors, hood deflector, Wet Okole seatcovers, in-vehicle safe.
    You're fine but many people do early fluid changes in their diffs to get rid of break in debris and switch to synthetics. I guess if you were really concerned you could think about doing that, since many people do anyway. If you're not particularly OCD, just wait until the maintenance schedule tells you it's due.
  7. Oct 15, 2016 at 7:09 PM
    krzysnwbrdr
    krzysnwbrdr Well-Known Member
    Masaki
    2016 Black Tacoma TRD Sports DCLB
    Sorry to jack the thread but ive got a question.
    In the winter time, to be on the safe side, using 4hi on potential frozen road is bad as well?
    For example, probably a whole different story but like my old Audi A8 had full time 4wd. Why not Tacoma?
  8. Oct 15, 2016 at 7:10 PM
    bulldog
    bulldog Well-Known Member
    SW MO
    2023 Pro
    Umm…it’s a Pro Retired 4/29/2023 Dobinsons MRR Dobinsons UCA Dobinsons C59-314 Front Springs Dobinsons I59-110 Rear Springs 4.88 Yukon Gears CMC MobTown Sliders Line-Xed RCI Aluminum Skid BAMF Recessed Grille WARFAB Rear tube bumper SSO Full Plate Hybrid (sitting in the garage still) TTD Carbon Fiber Steering Wheel Clazzio Dark Gray Seat Covers 35% Tint Vinyl Tailgate Letters Undercover Elite Tonneau Apex Stealth Cali LED 31.5" w/upgrade OPT 7 harness and MicTuning Switch V5 Gemtech Homelink 265/75 16 Mickey Thompson Baja Boss A/T Volk Gloss Black 16” 17' Pro Rigid Fog Lights 17' Pro Tail Lights Complete sound proofing
    I drive mine 10 miles a month on the road since I'm yet to have the time or a place to offroad. Just don't make a habit of making sharp turns :)
  9. Oct 15, 2016 at 7:10 PM
    tacopasu
    I won't. I used it once on wet pavement before but I don't even think that's advisable.
  10. Oct 15, 2016 at 7:11 PM
    bulldog
    SW MO
    2023 Pro
    Snow and ice is fine. That's why I have a 4X4 in the first place.
  11. Oct 15, 2016 at 7:12 PM
    tacopasu
    I have heard that because it is a part time 4wd, you shouldn't use it unless the road is slick.
  12. Oct 15, 2016 at 7:13 PM
    KRAMERICA
    KRAMERICA Old Man Mike
    Middle Tenn
    '18 F250 Super Duty
    A couple of rear window decals...
    As long as it drives okay when you put it back in 2WD, I wouldn't worry about. I wouldn't go telling the dealer that I ran it in 4WD on pavement though. According to the manual you're supposed to run it 4WD for about 10 miles every month just to keep it lubed up, but I don't always have the time to find a dirt road. So I run mine in 4WD on the pavement occasionally, but I generally don't make any turns while it's engaged.
    If the road is snowy or icy, that's fine. As long as the wheels can slip a little as you're turning, you'll be ok. Your Audi had a different type of 4WD, where the transfer case allowed the necessary slippage.
    bobrown14 likes this.
  13. Oct 15, 2016 at 7:14 PM
    krzysnwbrdr
    Masaki
    Yse but what about to use 4wd on pavement to be on the same side? Potential frozen highway drive and snow city drive.
  14. Oct 15, 2016 at 7:14 PM
    DustStorm4x4
    U S A
    04 Jeep LJ
    4hi on a frozen road would be fine IMO. If I'm slipping in 2wd, I think it's safe to say 4wd won't fuck up anything.
    0210 likes this.
  15. Oct 15, 2016 at 7:16 PM
    krzysnwbrdr
    Masaki
    That makes sense... Is this mean if you install aftermarket(if there was one) LSD, it will be fine?
  16. Oct 15, 2016 at 7:26 PM
    GM131
    GM131 Member
    G
    2016 Silver 2016 Tacoma TRD
    So I am confused- don't drive in 4h on dry roads. What about wet, slick, snowy roads....... 4h is good then ??
  17. Oct 15, 2016 at 7:28 PM
    KRAMERICA
    Middle Tenn
    '18 F250 Super Duty
    Not necessarily, an LSD usually just prevents both wheels from loosing traction at the same time. You'll always have "some" power to one of the two wheels with LSD. LSD doesn't in turn, allow slippage in the gears. When turning your wheels need to go at different speeds, but the 4WD system is trying to make them turn at the same speed. That causes excessive pressure on the 4WD parts, and with enough pressure, things will break. Vehicles with ALL Wheel Drive like your Audi A8 or Subaru's usually have some sort of clutch system in their transfer cases, that allows the slippage to occur.
  18. Oct 15, 2016 at 7:31 PM
    Eric J
    Eric J Well-Known Member
    Ponte Vedra Beach
    2008 MGM dcsb 4x4 Trd sport debadged
    To many to name
    Just don't do it again. You could seriously fry your transfer case and front driveshaft it's only meant for slippery conditions
    tacopasu[OP] likes this.
  19. Oct 15, 2016 at 7:31 PM
    Pittrider
    Pittrider Pitty, those needing correction.
    Greg
    B.C.
    2016 MGM LTD LB
    Do you need to know, or care?
    Yes.
    Basically, use it when there is a chance that your front wheels can slip. Otherwise leave it in 2WD. Never on dry roads, unless the wheels are straight.
    0210 likes this.
  20. Oct 15, 2016 at 7:33 PM
    KRAMERICA
    Middle Tenn
    '18 F250 Super Duty
    As long as your steering wheels can "slip" when they are being turned you should be ok. Dry pavement usually doesn't allow the wheels to "slip". When pavement is slick, not necessarily just wet with water, but with snow or ice, there will be enough slippage to be okay.
