Used or Remanufactured 3RZ motors, Where to buy?
Discussion in '1st Gen. Tacomas (1995-2004)' started by YOTASTEVEO318, Apr 14, 2017.
  1. Apr 14, 2017 at 1:38 AM
    YOTASTEVEO318
    YOTASTEVEO318 [OP] Active Member
    1995.5 4X4 Tacoma (1st Gen) and Long Travel 1996 Toyota Tacoma 2WD (1ST GEN)
    4WDTACO: New paintjob, 3 inch coil spacer lift 2WDTACO: Long Travel , modeled after Total chaos kit , possibly early total chaos kit strapped at 14" , fiberglass fenders all the way around , bilstien coilovers
    I'm looking for either a used or remanufactured 3RZ motor for my dads Tacoma, its a 95 so would any 95-04 3rz work? I'm located in southern California.
  2. Apr 14, 2017 at 4:00 AM
    Dalandser
    Anthony
    Downey
    Empty Wallet Mod
    YOTASTEVEO318[OP] likes this.
  3. Apr 14, 2017 at 1:04 PM
    DrZ
    DrZ Well-Known Member
    Mesa, AZ
    96 2.4L 5-speed
    There are differences in the years. Early 3rz had a distributor with built in cam sensor. Later, Toyota switched to coil packs and a cam sensor located on the side of the head.
    I'm not sure of all the differences. Maybe someone else knows which years will fit a 95.5 and match the wire harness and computer.
  4. Apr 14, 2017 at 1:12 PM
    DustStorm4x4
    DustStorm4x4 BBC 2020
    U S A
    04 Jeep LJ
  5. Apr 14, 2017 at 2:59 PM
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    No not any 3rz will work.
    You'll need one with a distributor pack not coil packs. Emissions stuff changed as well in 01.
    basically find one that is made for an early taco and you'll be good.
    Could look at doing a V6 swap. You'll have to cut out the motor perches and mounts and weld in new ones. But worth the power upgrade if you can. Wiring should be straight forward but won't be fun.
  6. Apr 14, 2017 at 5:01 PM
    Ritchie
    Ritchie Well-Known Member
    San Diego (North County)
    RC Step side Pre-runner
    2.7 w/auto, 4WU 3 link, F & R Diamonds, ARB's F/R w/ Yukon 5.29's, Inchworm 4.7 Lefty, Deavers, ARB OBA, Schrockworks up front.
    ^^ like Blackdawg said.
    I can't say anything about the distributor models, but there are differences with the coil pack models as there are 4 port & 8 port versions. The 8 port are better from what I've found as I have the 4 port version. Supposedly have better performance and fuel mileage.
    Look at LC's site. They do have various 3RZ's available.
    Good luck.
  7. Apr 15, 2017 at 3:16 AM
    YOTASTEVEO318
    Oh yea that's right, it would have to be a 95-07 then.
  8. Apr 15, 2017 at 3:21 AM
    YOTASTEVEO318
    I want to do a 5VZ swap in my truck really bad, maybe I could give him my motor and get myself a 5VZ. lol
    Dalandser likes this.
  9. Apr 15, 2017 at 1:41 PM
    Nedrolls
    Nedrolls Well-Known Member
    Scott
    Coquille, Oregon
    1999 Ext cab beater. 2016 Pro 4Runner(wife's)
    Like previously stated Lce, or yotashop.com has pretty good reviews
  10. Apr 15, 2017 at 3:25 PM
    Dalandser
    Anthony
    Downey
    Empty Wallet Mod
    If you're going to spend $3k on a new motor just throw an ls in there. I wouldn't pay that much for a replacement when there are some really great shops in SoCal like L & R engines in Sante Fe Springs that will rebuild that thing for less than $2400 - what they quoted me for my 5vz.
  11. Apr 27, 2017 at 8:32 AM
    YOTASTEVEO318
    We aren't using the full 3k for the motor haha , we are using some of that for tires and stuff too
    Dalandser[QUOTED] likes this.
  12. Apr 27, 2017 at 8:40 AM
    YOTASTEVEO318
    Also, what is the difference from the short block and long block? Is the stock block a short block?
  13. Apr 27, 2017 at 8:49 AM
    043RZ
    043RZ Well-Known Member
    Spring Grove, PA
    2004 Tacoma SR5
    6" Fabtech Lift, OME Dakar leaf springs, BudBuilt Traction Bar, 15" American Racing Wheels, 5.29 Nitro Gears, 35" BFGs AT, Pioneer 200 Watt Stereo, 6x8 Pioneer speakers, Raised Front and Rear Diff Breathers, Deck Plate Mod, Red Interior Underglow, Red Exterior Underglow, Cool White LED Rock Lights,
    Short block is just the block and lower end (pistons, crankshaft and maybe balancing shafts). Long block includes the block, lower end components and head already installed to the block. Stock is stock. You can get the stock engine in a short or long block. Just depends on if you want to reuse your old head.
  14. Apr 27, 2017 at 10:26 AM
    Dalandser
    Anthony
    Downey
    Empty Wallet Mod
    My bad I was referring to the remanned options from Yotatech and LCE being upwards of $3k - too much for what you're getting if you have a good engine shop willing to do it for less since you're going to be yanking the engine out either way. Keep us updated.
  15. Apr 27, 2017 at 7:01 PM
    mataco4wd
    mataco4wd Well-Known Member
    994wd
  16. Apr 27, 2017 at 8:05 PM
    Dalandser
    Anthony
    Downey
    Empty Wallet Mod
    This is the reason why spending money for a local rebuild is so important; who's going to yank an engine out of their vehicle and ship it back to a place that will *maybe* warranty their work after you pay for shipping? The likelihood of them ever having to fix their work is almost zero: https://www.yotatech.com/f208/apr-auto-care-230256/
    http://m.ripoffreport.com/reports/a...to-care-apr-auto-care-toyota-car-parts-634317
    There's no substitute for an engine shop that knows what they're doing that is local to you with great customer feedback, reviews, and service. They will tell you what issues your engine could have been having and know how to put it together to be reliable.
    aeok18109 and YOTASTEVEO318[OP] like this.
  17. Apr 28, 2017 at 8:51 AM
    col. sandurz
    col. sandurz Well-Known Member
    Any info on this? wondering if my heads bad on mine. Noticed the V6 engines are half of 2.7l
  18. Apr 28, 2017 at 7:25 PM
    mataco4wd
    994wd
    Was not aware, I spoke to someone there recently, said they only want the head as a core return.Thanks for the post, I was actually about a check away from ordering a new "non toyota" 3rz from them. Im also trying to decided on who I will order from, or just drive the wifes car and do a rebuild.
  19. Apr 28, 2017 at 7:58 PM
    Dalandser
    Anthony
    Downey
    Empty Wallet Mod
    You're welcome - I have been looking for awhile for a rebuilt engine that was less than a JDM swap that had good reviews and haven't found anything so far besides some good local shops that will be more expensive than a swap from a JDM engine importer - but that's for the 5vz which I guess is a little more common and thus almost half the price from the importer I'm looking at buying from.
  20. Apr 29, 2017 at 5:31 AM
    mataco4wd
    994wd
    I wonder where Marlin crawler sources their 3rz for swaps. Read an article in 4wdtoyotaowner about swapping to pickups.
