Used Shell
Discussion in 'Tonneau Covers, Caps and Shells' started by bdunna, Feb 8, 2021.
  1. Feb 8, 2021 at 6:23 AM
    bdunna
    bdunna [OP] Well-Known Member
    2005 tundra access cab
    Those that found a used shell, how did you install it? Does it take 4 people to lift? Coming to the conclusion that a new top is out of the question. Now just wondering how to get it on, 3rd light hooked up etc.
  2. Feb 8, 2021 at 6:26 AM
    Blueberry.Taco
    Blueberry.Taco blueberry.taco (IG)
    Ryo
    Fulltime Overlanding
    Long travel house on 35s with a custom aluminum utility bed and FWC
    some welding required
    it's doable although awkward with 1 person, be very careful and slow or be prepared for scratches. 2 people make it easy.
    oconnor and Hamer95USA like this.
  3. Feb 8, 2021 at 6:28 AM
    BassAckwards
    2009 Tacoma AWD Turbo 2TR-FE
    2 person job for sure. Easier with more people but not reqd
  4. Feb 9, 2021 at 6:48 PM
    Fast1
    Fast1 Well-Known Member
    Minneapolis, MN
    2021 TRD Off-Road Access Cab
    make sure, the two, have enough height to lift it over the bed rails. Each of you will have about 75 lbs to lift or.. curl. 4 makes it easier
    bdunna[OP] and Hamer95USA like this.
