Used Supercharger question
Discussion in 'Performance and Tuning' started by PrerunnerVsix, Dec 30, 2018.
  1. Dec 30, 2018 at 7:48 PM
    PrerunnerVsix
    PrerunnerVsix [OP] Well-Known Member
    Ali
    Houston, Tx
    2013 Tacoma TRD Sport
    Hey guys, Im looking at buying a used 3.4 trd supercharger. I checked it out today and everything seems okay but when rotating it I can hear something like every rotation. The sound is very faint almost not even a sound. Is this normal or should I bail on this blower? Supposedly it has 80,000 miles. Thank you
  2. Jan 2, 2019 at 9:24 PM
    White lightning boosted
    White lightning boosted Well-Known Member
    Jesse
    Poulsbo
    15' DCSB OR S/C
    Lift, pedal commander, led foglights, led interior lights, led back ups, led under lighting, urd tcai, led headlights, methanol injection, 76mm tb, hood struts, dif breather mod, ratiotek trans kit, x-series gauges, true cool trans cooler, belt wrap mod, 2.8 pulley
    @1997tacomav6 might be able to give you some insight. He has rebuilt his multiple times. He has some pics in my thread methanol 4.0. My suggestion is buy it. What's the price anyway?
    BassAckwards likes this.
  3. Jan 2, 2019 at 9:25 PM
    NRXTM
    NRXTM Well-Known Member
    Houston
    2011 toyota tacoma
    He was asking $1,600 but I talked him down to $800 somehow. I still haven’t bought it yet though
  4. Jan 2, 2019 at 9:28 PM
    Jesse
    Poulsbo
    15' DCSB OR S/C
    My thoughts are he doesnt feel like rebuilding it. I think you have a pretty good deal. Does it come with ALL the parts needed? Or is it missing parts? @1997tacomav6 would be the guy I'd talk to for sure. He has run his a half a million miles. Literally.
  5. Jan 2, 2019 at 9:38 PM
    1997tacomav6
    Denver
    Buying a used supercharger is a gamble if you can’t hear it run. You really have no idea what condition it is until it is installed on the engine. Then you will know if there are bearing issues when the supercharger is spinning at 10,000 rpms.
    Typically the supercharger will last 100,000 to 150,000 miles. So if it has 80,000 it will need a rebuild soon for 1000.00 as long as there are no other issues pending.
  6. Jan 2, 2019 at 9:41 PM
    1997tacomav6
    Denver
    Is it the grey unit 1st gen or the black 2nd gen?
  7. Jan 2, 2019 at 9:42 PM
    1997tacomav6
    Denver
    Either way if you got it for 800.00 that would be a bargain, but plan on 1000.00 for a complete rebuild top to bottom
  8. Jan 2, 2019 at 9:45 PM
    zerotimeouts
    zerotimeouts Well-Known Member
    Nor Cal
    2011 DCSB 4.0 S/C
    You might feel some resistance or noise when it’s not on the truck, maybe?? Those impellers are really close together. I’d rebuild it prior to install even if it wasn’t high mileage
    You could get it rebuilt for around $900. It’s probably worth it at $800 and it’s much easier to rebuild it before putting it on. It’s doable at home if you feel like it but if needed there is more they can do when it gets rebuilt.
    Plus you could get it ported and have rebuilder put smaller pulley on for ya.
    They are pretty tough and as mentioned will typlcally go a long time.
  9. Jan 3, 2019 at 3:23 PM
    PrerunnerVsix
    Ali
    Houston, Tx
    It is a 2nd gen black supercharger, and does come with everything except the throttle body bolts. Thanks everyone for the information, looks like Ill have to decide wether or not I want to rebuild it and everything. He said he bought it from an auction parts 4runner and is trying to recoup money selling parts.
  10. Jan 3, 2019 at 3:48 PM
    Jesse
    Poulsbo
    15' DCSB OR S/C
    I'd say its worth it.
  11. Jan 3, 2019 at 4:12 PM
    1997tacomav6
    Denver
    Well you won’t find one cheaper than that, better jump on it
  12. Jan 3, 2019 at 4:27 PM
    PrerunnerVsix
    Ali
    Houston, Tx
    Do you ever get tired of using 93 all the time?
  13. Jan 3, 2019 at 4:40 PM
    1997tacomav6
    Denver
    Mmmm nooo, If I was worried about 91 or gas prices I would be in a Honda Civic
  14. Jan 3, 2019 at 7:52 PM
    Jesse
    Poulsbo
    15' DCSB OR S/C
    The mileage and hp improvements of quality gas are worth it. Like your body, put low grade food in and get by or eat well and feel your best. Nothing great is the cheapest.
    1997tacomav6 likes this.
  15. Jan 27, 2019 at 8:50 PM
    DesertRatliff
    DesertRatliff Well-Known Member
    Mt. Hood, OR
    Mas Tacos Por Favor
    Plenty of info here on TW on rebuilding the 'charger yourself. I found a grey one for $500 from a guy in Delware that had 300k miles on it. I pulled it apart, rotors were in good shape so just pressed in new rotor bearings, shaft bearings, coupler and oil and was out the door for a few hundred bucks more. 40k on it now with no problems. Getting the bearing spacing just right on the nose cone shaft was the hardest part for me but having a boosted 5VZ-FE at elevation for pennies on the dollar was worth the learning process. I say jump on it!
    And if you find a 'charger for a 1GR-FE for that price, please let me know! The new '14 Tacoma is crying for boooooooost!
  16. Jan 27, 2019 at 8:53 PM
    Jesse
    Poulsbo
    15' DCSB OR S/C
    I'll sell mine when the next bigger one comes available: )
  17. Jan 27, 2019 at 8:56 PM
    DesertRatliff
    Mt. Hood, OR
    Mas Tacos Por Favor
    For the same price I got the grey one for? DEAL!!!
    EDIT: I'm looking, so all ears if you find any deals.
  18. Jan 27, 2019 at 8:57 PM
    eon_blue
    Azusa, CA
    800 is a steal assuming it includes everything needed for install. Even if it needs a rebuild is a good deal.
    The superchargers do make a rattling noise when the engine is on, you can hear it at idle especially with the hood up. If it's an obnoxious rattle though that you can hear when driving then it probably needs rebuilt.
    They're supposed to need a rebuild every 100k or so
  19. Jan 27, 2019 at 8:57 PM
    Jesse
    Poulsbo
    15' DCSB OR S/C
    No. I'll have it ported, fully rebuilt, with a variety of pulleys. It's one of the last trd stamped blowers made. Price will reflect.
    DesertRatliff likes this.
  20. Jan 27, 2019 at 8:58 PM
    eon_blue
    Azusa, CA
    You have a 2nd gen Tacoma though right? Think he has a first gen Tacoma judging by his avatar
