Used tacoma maintenance tips?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by raventaco, Oct 25, 2017.
  1. Oct 25, 2017 at 8:16 AM
    raventaco
    raventaco [OP] Be Prepared
    Lane
    Avondale
    06 Pre-runner Stormtrooper
    So I bought a 2006 trdor double cab prerunner almost a month ago, and I’m wondering what should be replaced or maintained. The truck has a whopping 172,000 miles on it.
    We’re scheduling a vehicle check at the local ford dealership that we’ve never had problems with (my family has always owned fords and I’m the one who decided to get a Toyota lol). I would like to know some good advice on things to replace/upgrade from actual Toyota owners.
  2. Oct 25, 2017 at 8:21 AM
    PackCon
    PackCon Well-Known Member
    Connor
    2017 Subaru Forester Limited
    Do you know the service history at all?
  3. Oct 25, 2017 at 8:30 AM
    ArmandHammer83
    ArmandHammer83 This truck is AMAZING
    Raymond
    Alabama
    2018 Tacoma AC V6 MT 4x4
    none yet
    I got mine with 183k on the clock and now has 191k and without a doubt check the cabin air filter ( so the A/C will blow colder and the heat wont stink) make sure you check for worn seals and bushings in the front end, just replaced a #6 coilpack on my 4.0 due to misfire....definitely a tune up ( unless its been done and have receipts) have the rear diff fluid checked and enjoy having the truck...looks good
    raventaco[OP] likes this.
  4. Oct 25, 2017 at 8:31 AM
    Steves104x4
    Steves104x4 Well-Known Member
    Buffalo NY
    2010 RC 2.7 4x4
  5. Oct 25, 2017 at 8:31 AM
    Tacologist
    Tacologist Well-Known Member
    Bob
    Tenessee
    05 Double Cab Shortbed
    Rear leaf suspension. Home done tailgate re-inforcement.
    If it is auto trans, drain a little fluid on a paper towel and see the condition of it. Less than a red/pink, consider a change. A full flush is debatable at your mileage.
    Brake fluid, power steering fluid, differential fluid serpentine belt, mass air flow cleaning and brake fluid are a good start.
  6. Oct 25, 2017 at 9:14 AM
    taco2010trd
    taco2010trd Cyber Bully
    Tampa, Florida
    2010 Silver TRD OR DCSB
    power steering fluid flush too, very simple procedure
  7. Oct 25, 2017 at 9:35 AM
    ArmandHammer83
    Raymond
    Alabama
    none yet
    ok so not to sound like an idiot but here goes....how do you do a power steering flush?....i've been cruising this site for almost 9 months and i've never done one and this is the first time i seen anything mentioned about it....also i need to do all those things mentioned... i'm the "if it ain't broke don't fix it" type
  8. Oct 25, 2017 at 9:38 AM
    raventaco
    Lane
    Avondale
    X2
  9. Oct 25, 2017 at 9:40 AM
    Lester Lugnut
    Lester Lugnut Well-Known Member
    N of Mex-S of Canada-E of LA-W of NC
    '15 Tacoma PreRunner V6 SR5 Auto
  10. Oct 25, 2017 at 9:52 AM
    taco2010trd
    Tampa, Florida
    https://www.tacomaworld.com/threads/power-steering-flush.416379/
  11. Oct 25, 2017 at 10:01 AM
    ArmandHammer83
    Raymond
    Alabama
    none yet
    i wish everything was as easy as that sounds...guess i know what i'm doing soon...thanks for the info
  12. Oct 25, 2017 at 11:00 AM
    taco2010trd
    Tampa, Florida
