Used tacoma, many issues
Discussion in '1st Gen. Tacomas (1995-2004)' started by jbandt, Aug 31, 2015.
  1. Aug 31, 2015 at 1:09 PM
    keakar
    keakar Well-Known Member
    karl
    louisiana
    well $5,800 is too much, maybe $2800-$3k is about decent price if the body interior and frame have nothing wrong with them so my opinion is, you got hosed for about $3k too much.
    you could likely buy a parts truck for $2k to $3k and have all the parts you need to make it right and the truck would be worth at least $10k when you are done so you wouldn't be underwater on it in my opinion but im not as familiar with 4wd as 2wd trucks so im sure others can give you better advice on 4wd valuations
  2. Aug 31, 2015 at 1:10 PM
    Mush Mouse
    Mush Mouse Club Soda Not Seals
    mush
    where ever you want me to be
    2013 SR5
    its a Toyota truck and that's all the modifications needed
    auto or manual tranny
  3. Aug 31, 2015 at 1:14 PM
    keakar
    karl
    louisiana
  4. Aug 31, 2015 at 1:20 PM
    jbandt
    jbandt [OP] Well-Known Member
    Manual.
  5. Aug 31, 2015 at 1:35 PM
    Flowin
    Flowin Well-Known Member
    Acworth, Georgia
    2014 DCSB TRD OFF ROAD
    OME 3" lift, 265/75/16 KO2s, 35% tint
    Don't panic - get some used parts to fix it, there are plenty on here and locally (assume you are in CA)...you can do most of the work yourself. - if it comes out cheaper than expected give it a 299 Maaco paint job in original black and you're golden
  6. Aug 31, 2015 at 2:03 PM
    jbandt
    I'm not paniced per se. More disappointed or discouraged really. The budget is pretty tight, and while new axles and front suspension parts were going to be manageable for a noob, a new diff I'm not so sure about. But it is a secondary vehicle so there's no hurry to fix it up. I'll have to find out what something like will cost used. First thing first! I gotta get it registered! LOL.
    As of now it is driveable. The cv's aren't popping or showing the tell tale signs of failure yet. So I think as long as I keep it in 2wd I can still drive around town once in a while.
    I appreciate everyone's help. I know I'll be back asking more questions since it has multiple issues. And for now I'll just keep an eye out for a used diff.
  7. Aug 31, 2015 at 2:48 PM
    keakar
    karl
    louisiana
    well for things you need to buy new check rockauto.com they have the best prices "most" of the time so always compare elsewhere but they are usually the best source. when you go there choose the parts with the red hearts next to them, these are how they mark the most popular parts based on reliability, quality, and price. http://www.rockauto.com/?a=G-motormite
    if you need to find your part numbers for something go here and put in your vin number to see a parts number list for your truck http://www.toyodiy.com/parts/q.html
  8. Aug 31, 2015 at 6:57 PM
    deckeda
    deckeda Well-Known Member
    '04 Double Cab PreRunner SR5
    If the CVs aren't yet clicking, they might be able to be re-packed and saved with new boots. I know that's often more work/nearly as much (or more) than buying remanufactured axles with new CVs ... but could be better/longer lasting than remanufactured axles. (There are front-drive cars where this is very sage advice; these guys here will let you know if something similar applies to these trucks.)
    Sounds like the 4x4 capability can wait until you get the suspension sorted properly.
  9. Aug 31, 2015 at 7:37 PM
    keakar
    karl
    louisiana
    the cv half shafts only cost $42 and $43 for each side so its pointless not to just replace the whole thing, you will spend $25 just for the new boots for one side so its pointless to repack or try to repair them
  10. Aug 31, 2015 at 7:39 PM
    jbandt
    Where do I go for those prices? Napa has already been recommended as a source for axels, but not sure of their pricing yet.
  11. Aug 31, 2015 at 7:41 PM
    deckeda
    Ah OK, so it's not the same situation then. I didn't know the remanufactured parts would last as long as OEM for these trucks. Thanks.
  12. Aug 31, 2015 at 9:15 PM
    jbandt
    You guys aren't going to believe this but the diff isn't cracked. I just looked again and it's fine. That photo just happened to get the shadow of the grease at just the right angle. If you zoom in a lot you can see it's just a shadow. I'm so relieved. I also looked real close where the axle goes into the diff and I can see oil leaking from that point. So now I'm back to a manageable situation. Wheeewww!!!
    tacomatrd22 likes this.
  13. Aug 31, 2015 at 9:56 PM
    Indy
    Indy Master of all I survey.
    That's good. Damn convincing shadow!
  14. Sep 1, 2015 at 1:39 AM
    Wyoming09
    Wyoming09 Well-Known Member
    New Tripoli Pa
    Super Springs
    Just curious was this a case of really not knowing what to look at pre purchase or were you over come by Lust for this truck.
    Till you get done rebuilding the front suspension and axles if you can do the work a SAS might be more cost effective .
    After doing the tie rods and ball joints and cv axles the cost of the parts does add up.
  15. Sep 1, 2015 at 2:34 AM
    #35
    hetkind
    hetkind Well-Known Member
    Howard
    Johnson City
    2011 SR5 Access Cab, white with Leer Cap
    bilstein set at 1.75, Racho 5000 rear with 4 leaf kit, floor mats, high lift jack, pull hook in hitch, bed rail corner braces, severe duty brake pads and devil horns on the grill....
    You bought a project, you have a project. I bought a 99 Honda Accord for my daughter a couple of years ago, with bad CV joints, we paid 3k for the vehicle and have since put tires, brakes, battery, starter into it, the usual stuff, but the weak honda transmission set us back 2.5k more.
    With the money you have into it, it is a toss up between fixing and flipping and moving up or trying to salvage a poorly maintained vehicle.
    †he prices of decent used vehicles is high and the local market drives the bus
    Let us know.
    Howard
  16. Sep 1, 2015 at 3:28 AM
    #36
    johnny3
    johnny3 Well-Known Member
    01 Tacoma TRD
    I'd fix it myself, cv axels are easy to change, quite easier than an Accord, the NAPA Max Drive ones seem to bethe most popular here, you can find the seals on Ebay http://www.ebay.com/itm/351436756619?_trksid=p2060353.m2749.l2649&ssPageName=STRK:MEBIDX:IT, then do the suspension "as needed" when you feel like it. Mine looked about as bad on the under side as yours, but it drives fine, I pressure washed it underneath got a lot of the rust & crud knocked off. No vehicicle looks good on the under side at the age & milage of our trucks.I think you got a pretty decent buy on your truck. Just get ready for your education, it's fun. I would recomend changing those axle seals while you already have the shafts out.
    #36
  17. Sep 1, 2015 at 6:14 AM
    #37
    jbandt
    I knew some of the basics going in. And I knew at my price point there was likely going to be some maintenance. But it was sort of a hurried decision as I had already missed out on two other trucks. I'm still happy with my decision so far.
  18. Sep 1, 2015 at 12:59 PM
    #38
    keakar
    karl
    louisiana
    I pulled those prices off of rockauto.com
  19. Sep 1, 2015 at 2:39 PM
    #39
    Wyoming09
    New Tripoli Pa
    Super Springs
    I based my costs on what I paid in new parts
    Then I also did Wheel bearings Rotors Calipers and Pads
    Compared to buying a Toyota Solid Axle Truck or 4 runner and rebuilding that
    Then splice in the whole frame front end complete
    Some place mid cab
    If course one would in fact want to have a solid axle .
    Then I would need no more then stock height which is already hard enough to get into.
