Used the 3M headlight restoration kit. Should of left them alone.
Discussion in '2nd Gen. Tacomas (2005-2015)' started by BarefootBandit, Oct 23, 2011.
  1. Oct 23, 2011 at 2:02 PM
    BarefootBandit
    BarefootBandit [OP] Well-Known Member
    TC UCA OME 884 5100 TSB+AAL 4.10 V6 6spd 285/75/16
    Any help is appreciated. The tops of my headlights were becoming foggy so I went out and bought the 3M restoration kit. Did 1 headlight and what do you know... it looked worse than before!
    Anybody have this happen to them? Will I ever be able to get my lens back to completely clear?
    If I bring it to a professional will they be able to make it look completely brand new again?
  2. Oct 23, 2011 at 2:10 PM
    TacomaPrime
    TacomaPrime Cybertronian Tacoma
    Gregory
    Illinois
    14 TRD sport 4x4 Barcelona Red
    Weathertech front floor liners, window vent visors. Custom bedside decals. OEM bed mat, tonneau covrew. Added D rings to bed.
    post a pic of them.
  3. Oct 23, 2011 at 2:11 PM
    Tacomanator
    Tacomanator Well-Known Member
    Clam Slammer
    Southern Cali
    King 2.5" extended travel coilovers with compression adjusters, Camburg UCA's, King 2.5" rear shocks, TRD 1st gen CAI.
    Rubbing compound always did the trick for me. You could also try wet sanding.
  4. Oct 23, 2011 at 2:18 PM
    BarefootBandit
    I guess this kit is only supposed to be used on headlights that really need them. I did the passenger side. You can see the original untouched driver side looks better. Sigh.
  5. Oct 23, 2011 at 2:24 PM
    wildjerseyfirefighter
    wildjerseyfirefighter I sell fishing and fishing accessories
    Joe
    NJ
    05 Tacoma TRD Sport
    stock, for now
    try a rubbing compound..3m makes the best stuff IMO. I did a home made headlight restore on my dads 2002 tacoma, came out damn near new looking.
  6. Oct 23, 2011 at 2:32 PM
    Casey05Taco
    Casey05Taco Well-Known Member
    Casey
    Penngrove, CA
    05 Tacoma Prerunner
    trd seat covers, bed mat, tinted windows, debadged, mud flaps removed, tinted tails, blacked out center console, Black Rims, 6000k HID in highs and fogs, blacked out front emblem, Pioneer AVH-4300DVD, Gauge Cluster, lower valence, retrofitted, audio system, Maxtrac Spindles, Billies
  7. Oct 23, 2011 at 2:42 PM
    RAT PRODUCTS
    RAT PRODUCTS Well-Known Member
    Farmington, MN
    Cummins Coal Roller
    Smokin with a smarty.
    Use a drill buffer and some plastic polish. Work it a lot.
  8. Oct 23, 2011 at 2:48 PM
    UndefinedTaco
    UndefinedTaco I'll eat all your food.
    Justin
    Tracy, CA
    Toyota
    It's an 89 Toyota Pickup. I got some stuff done to it.. FJ axles going under it soon.
    Wet sand the piss out of it with 1500 then wet sand with 2000
    then rub the compound in it(clear x or whatever)..let it sit for a few seconds..rub it out(circular motion),
    then wet sand the piss out of it with 1500 then wet sand with 2000.
    then hit it with the compound again(clear x)..then rub it out again.
    then hit it with a rubbing compound with a buffer...guaranteed it'll look brand new.
  9. Oct 23, 2011 at 3:49 PM
    iroh
    iroh Well-Known Member
    michigander
    07 AC SR5 2.7 5MT 4x4
    tonneau
    Word of warning, if you wetsand through the plastic's protective layer it'll oxidize again in 6 months and turn yellow.
    Once it gets bad enough to need polishing it typically becomes a yearly - or more often - task. For the worse-off ones I start with mother's mag aluminum polish with a gentle touch and finish with maguiar's scratch-x 2.
    I need to pull an old lamp off one of these days and polish, clearcoat, polish again to see if it sticks.
    If it needs sanding, always always wetsand! I used 1500 and 2500 the only time I had to do it.
  10. Oct 23, 2011 at 4:47 PM
    three west
    three west Well-Known Member
    JD
    UP MI
    09 DC SB TRD Sport
    you're just not done yet.
    I used the same kit on my old Ram and it worked great, and held up for nearly 2 years before I had to do it again, and then it was a very easy touch up.
    Just get back out there again and work the progressively finer grits & compounds until they're clear again.
  11. Oct 23, 2011 at 4:53 PM
    NelsonTacoma
    NelsonTacoma This is my derpawayinator!!!!!
    Tucson, AZ
    06 PreRunner TRD Sport 03 4Runner Limited 4wd
    Bilstein 5100's , 6000k HID Hi/Low Kit, Magnaflow Muffler, 1.5 inch AP Wheel Spacers, Mudflap Delete
    This.
    I just did this to my headlamps a week or two ago. Turned out great. Wet sanded lightly with 3000 grit sand paper. Then buffed the crap out of them. Here's my results.
    Before
    After
    Lucky for me I had a friend who does this all the time give me advice on what to do before I started.
  12. Oct 23, 2011 at 5:00 PM
    Tacoma Mike
    Southern Maine
    I never use sandpaper on them. i have a kit with buffing wheels with different compounds. I've had real good luck. I would rather try an extra 5 min and see how it comes out than do that.
    I just deleted a couple of pics off my phone last week.
    Darn.. These were pure yellow and I got them just about clear.
    Give her another shot. You still need to get the compound to them. What else do you have to lose??
    Oh IMO never use the stuff you paint on after.
    It just seals in the yellow and fog you missed. Looks good on TV but I've seen the results. You can't miss it..
  13. Oct 25, 2011 at 6:06 AM
    ST3VE
    ST3VE IG: @fishsohard
    MD --> SC
    Tint, car seat, baby wipes
    Easy fix.. wet sand it with 1000 then go out and get a rattle can of clear.. remove the whole housing from the truck and LIGHTLY spray 3 or 4 coats with about a minute between coats. if not come to maryland and I will do it for you.
