Used tires on new truck
Discussion in 'Wheels & Tires' started by mason179, Dec 20, 2017.
  1. Dec 20, 2017 at 12:42 PM
    mason179
    mason179 [OP] Well-Known Member
    Darlington, SC
    2015 MGM DC SR5
    ive got a 2015 prerunner sr5 and just acquired some take offs of a 3rd gen.
    I just put them on the truck yesterday and I noticed the truck is pulling to the left.. do I need to go for an alignment?
    The guy that took them off didn’t mark the tires so I don’t know if that’s an issue..
  2. Dec 20, 2017 at 12:45 PM
    TrdSurgie
    TrdSurgie revised
    Oahu
    Probably needs an alignment.
  3. Dec 20, 2017 at 12:47 PM
    theredofshaw
    theredofshaw Well-Known Member
    Somewhere on the East coast
    not a taco (guess that means I can be a MOD now)
    (totaled) 2011 Tacoma DC
    i'd say alignment. maybe the old tires "adapted" their wear to the bad alignment. I'd also check to make sure you are seated properly against the brakes. I always torque mine down in a cross pattern to make sure they're seated right.
    also double check that the shop didn't leave any nuts off or loose, that happens a lot it seems.
  4. Dec 20, 2017 at 1:06 PM
    mason179
    Darlington, SC
    2015 MGM DC SR5
    I installed them myself and tighten the lugs down in a cross pattern.
    It’s raining today, so I’ll check air pressure first then go see about an alignment. Didn’t wanna fork out money
  5. Dec 20, 2017 at 1:08 PM
    doorsidedown
    doorsidedown Well-Known Member
    sounds like it was already out of alignment.
  6. Dec 20, 2017 at 1:43 PM
    mason179
    Darlington, SC
    2015 MGM DC SR5
    No.. I took my rims/tires off and swapped them with his takeoffs.
    Truck didn’t pull none the entire 3 hours round trip to pick up his takeoffs.
  7. Dec 20, 2017 at 3:24 PM
    doorsidedown
    Are they the same size tires/Wheels?
  8. Dec 20, 2017 at 3:49 PM
    mason179
    Darlington, SC
    2015 MGM DC SR5
    I went from steel rims to alloy 3rd gen rims..
    Tires are the same brand and size
  9. Dec 20, 2017 at 4:36 PM
    doorsidedown
    Shouldn’t need an alignment if you swap same size tires/wheels unless it was already out. My bet is it was off a bit and the new tires brought it to light. I’d have it aligned and bet it goes away.
