Used Tires
Discussion in 'Wheels & Tires' started by gonzo6up, Mar 24, 2010.
  1. Mar 24, 2010 at 1:45 PM
    gonzo6up
    gonzo6up [OP] Well-Known Member
    Middle Tn
    09 tacoma SR5 4x4 sport
    tint/ vent visors/ seatbelt chime mod/ DTRL Mod
    Alright so i ran across a deal for some tires and I've got a question. I bought some slightly used goodyear a/t tires ( approx 5K miles on them) which were on a suv with the whitewalls out, will it effect anything if i put the whitewalls to the inside when i switch them to my truck? I dont see any dips or side wear on the tires but i wanted to get someone elses opinion just in case
  2. Mar 24, 2010 at 1:47 PM
    RelentlessFab
    RelentlessFab Tacoma offroad armor fabricating beast Vendor
    Eric
    Eastern side of the Sierras: Sparks, NV
    07 SR5 6mt to 03 SR5 to 08 Sport and 17 6MT TRD OR
    Nope, no problem. It will be fine
  3. Mar 24, 2010 at 1:47 PM
    08pretaco
    08pretaco Almost there
    Oliver
    az
    2014 Tundra 4x4 CM 5.7L SR5
    AFE pro dry s, Husky X-act Contour
    changing their direction can tear and shread up the tire from the inside and out? no?
  4. Mar 24, 2010 at 1:58 PM
    Rucas
    Rucas 1st gen > 2nd gen
    Lucas
    Northern Colorado
    1st gen. 4x4 MANual
    sparkles, fairys, and happy things.
    dont you just switch sides and the tread will face the correct way again?
  5. Mar 24, 2010 at 2:09 PM
    08pretaco
    Oliver
    az
    ^ so like the rear right now the front left?
  6. Mar 24, 2010 at 2:13 PM
    Rucas
    Lucas
    Northern Colorado
    1st gen. 4x4 MANual
    no sorry, i meant
    if you put the white letters facing in, then dont you just put the right front on the left front, and right rear on the left rear?
  7. Mar 24, 2010 at 2:17 PM
    08pretaco
    Oliver
    az
    oh dir haha i just made that more complicated than it needed to be
  8. Mar 24, 2010 at 6:34 PM
    RelentlessFab
    Eric
    Uh, no. If so, then what would happen after tire rotations? The proper method for rotating tires is a "modified 'X' pattern": The front tires go straight back, then the rears go to the opposite side front location. Hence the rears will then be spinning the opposite direction after a tire rotation.
  9. Mar 25, 2010 at 7:33 AM
    gonzo6up
    Middle Tn
    thanks for the help guys
  10. Mar 25, 2010 at 9:13 AM
    08pretaco
    Oliver
    az
    some tires are unidirectional and you can only rotate front to back
