Used Wheels
Discussion in '2nd Gen. Tacomas (2005-2015)' started by asuchemist, Apr 25, 2015.
  1. Apr 25, 2015 at 9:47 AM
    asuchemist
    asuchemist [OP] My Hamstrings Hurt!
    South South Dirty Gilbert
    11' TRD Sport V6, 23' TRD Pro 4Runner, 23' Tacoma TRD Pro
    NONE
    Looking at these on CL. Pro Comp 17x8 wheels with Nitto Terra Grappler A/T 285/70/17.
    I currently have stock TRD Sport wheels 17" and stock suspension. Would I be able to run these without modifications? Would I be able to put my OEM tire on these wheels if the Nitto's don't fit?
    Thanks guys.
    http://phoenix.craigslist.org/evl/pts/4992864448.html
  2. Apr 25, 2015 at 10:00 AM
    Pigpen
    Dan
    Northwest Montana
    You probably won't be able to run those without some (2.5+") lift. You will probably have to do some wheel well trimming even with lift. The 2012+ seem to clear slightly better than earlier years.
  3. Apr 25, 2015 at 10:01 AM
    asuchemist
    NONE
    Okay thanks. Would I be able to mount my current stock 17" tire on these?
  4. Apr 25, 2015 at 10:07 AM
    Pigpen
    Dan
    Northwest Montana
    yeah, they should fit fine. You could sell the tires off of them on CL to recoup some of your cost.
    My tire guy usually charges me $70 to mount and balance, just to give you an idea of cost. I'd expect to pay a little more since you're swapping mounted tires to another set of wheels with tires already on them.
