Used wrong weight oil
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Elayhu, Jul 20, 2015.
  1. Jul 20, 2015 at 11:44 AM
    Elayhu
    Elayhu [OP] Well-Known Member
    Bethlehem, Ga
    2013 DCSB OR
    I have a 2013 DCSB OR with the 4.0. Didn't notice until I finished pouring in the oil that I had used 5w 20 Mobil One Full Synthetic instead of 5w 30. So, my question is should I go ahead and bite the bullet and shell out another $37 on 5 qts of the 5w 30. Or will I (my truck) be ok using the 5w 20 until the next 5k oil change. I'm not towing or hauling any heavy loads but I do live in Ga and its hotter than hell down here this time of the year.
  2. Jul 20, 2015 at 11:47 AM
    Sterdog
    Sterdog Offline
    I am Groot
    People's Democratic Republic of Canuckistan
    15 FoST
    I've seen this mistake made more than a few times and odds are you would never have a problem. If I did it I would leave it alone until next oil change. Honestly people run the wrong oil weight all the time and never notice. I would be hard pressed to say you will actually cause any long term damage with that oil.
    That being said the lower weight could cause some slight changes to your VVT-i that could hurt your fuel economy but who knows where the cut off is for VVT-i and oil weight. Also, most oils follow a linear relationship with heat so the hotter the engine runs the lighter the 5w-20 oil will be compared to a 5w-30.
    greeneggsnspam likes this.
  3. Jul 20, 2015 at 11:54 AM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    Don't go longer than 3k miles on that oil, if you don't want to change it now. That oil's only purpose is gas mileage. Not engine protection against contact wear.
  4. Jul 20, 2015 at 12:02 PM
    thebeeler
    thebeeler part of the problem
    Daniel
    Yuma
    Your sister
    Total Chaos, Plate bumpers, e-locker, etc
    False, don't fall suspect to advertising claims. I expected better from you.
    EDIT: Have run multiple different oil weights in the same engine and had the oil analyzed by black stone. No difference in wear patterns.
  5. Jul 20, 2015 at 12:05 PM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Only speak the truth. My sources are extremely reliable and accurate. Expect no less from me.
    I am only going off of testing data. Nothing from advertisers.
    Now, for other engines, not the single VVT-I 1GR, changing viscosity can have severely damaging effects. Due to thin materials, tight tolerances, and tolerances of oil pumps. I do not speak for those engines.
  6. Jul 20, 2015 at 12:10 PM
    BDL5589
    BDL5589 Well-Known Member
    NE Georgia
    '14 MGM 4WD RC
    Do I personally think it will hurt anything? Nah. Do I think $37 is worth it for peace of mind? Everytime.
    xaqori, QChawks and Torspd like this.
  7. Jul 20, 2015 at 12:11 PM
    DriverSound
    DriverSound Señor Member
    Oregon
    2015 DCSB OR 4x4
    Too few to list.
    $37 bucks for peace of mind? I do know that the dual VVt-i's uses 5/20 same engine class but little difference internals. I try to stick to manufacturer suggested weight most of the time.
  8. Jul 20, 2015 at 12:13 PM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    This is real simple. What season are we in, and more importantly, what are the average temperatures of the OP's location during the day?
  9. Jul 20, 2015 at 12:17 PM
    Elayhu
    Bethlehem, Ga
    2013 DCSB OR
    low to high 90's from now until the end of August.
  10. Jul 20, 2015 at 12:22 PM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Good. 20 weight oil is only good to 14-15 degrees Celsius. Otherwise known as 60 degrees Fahrenheit ambient. Not 90. Combined with the EPA mandated no more than 900ppm ZDDP, that oil fails in summer temps quickly. It can't stand the heat. Plain and simple.
    Single VVT-I 1GR, Don't run it. At the end of the day, it is your engine though. Do your own thorough research if you don't believe me. It'll make you that much more informed, and able to protect your investments better.
  11. Jul 20, 2015 at 12:25 PM
    hetkind
    hetkind Well-Known Member
    Howard
    Johnson City
    2011 SR5 Access Cab, white with Leer Cap
    bilstein set at 1.75, Racho 5000 rear with 4 leaf kit, floor mats, high lift jack, pull hook in hitch, bed rail corner braces, severe duty brake pads and devil horns on the grill....
    you should be just fine for the normal oil change interval, the difference in viscosity at higher temps in minimal.
    Howard
  12. Jul 20, 2015 at 12:27 PM
    Taco me elmo
    Taco me elmo Here, Eat some paint. Drink some Bleach.
    Tophat bobcat
    North of South, East of West
    Slow polished TuRD
    Anti theft 5-Speed
    My truck runs better with the wrong oil... LOL
    12TRDTacoma likes this.
  13. Jul 20, 2015 at 12:28 PM
    rmorse
    rmorse Well-Known Member
    Bobby
    Bowie, MD
    2015 Blue Ribbon Metallic Access Cab TRD Sport
    WTF, no. Lol, ambient temps don't matter for the the second number.
    TacomaMike37 likes this.
  14. Jul 20, 2015 at 12:28 PM
    TacomaMike37
    TacomaMike37 Well-Known Member
    13' DCLB MGM
    It can't stand the heat? Oil fails when its too warm outside. Did I read those two sentences right? Seriously?
    Last time I checked oil temps run into the low to mid 200's and sythentics can run in the low 300 degress all day long. So outside temp has zero impact on this discussion unless we are talking arctic type temps where cold crank comes into play.
    OP dont sweat it. Change it next time. You could run 5w-20 till the end of days with zero impact on engine wear.
    azchris, rmorse and thebeeler like this.
  15. Jul 20, 2015 at 12:29 PM
    tomwil
    tomwil Well-Known Member
    East Coast USA
    2014 Reg Cab 4x4
    If the vehicle is still under warranty, best to use the recommended viscosity.
    Why take the chance of Toyota denying a warranty repair in saving $37?
  16. Jul 20, 2015 at 12:29 PM
    Taco me elmo
    Tophat bobcat
    Slow polished TuRD
    Anti theft 5-Speed
    Hell I have the wrong stuff according to the book in my engine and rear diff... oh no's!!!!!
  17. Jul 20, 2015 at 12:31 PM
    rmorse
    Bobby
    Bowie, MD
    Bruh.... Are you trolling?
  18. Jul 20, 2015 at 12:31 PM
    Cmurder
    Cmurder 2011 TX TRD Offroad
    B.C.
    Kansas City
    2011 TX TRD Offroad
    nothing cool
    $37 man.... $37. How much is your truck worth? You probably spent $40 on dinner the other night. Just spend the money and put the right oil in.
    QChawks and ManBeast like this.
  19. Jul 20, 2015 at 12:34 PM
    thebeeler
    Daniel
    Yuma
    Your sister
    Huh well would ya look at that, approved for use in the GR engine family :poking:
    See link above
    azchris and TacomaMike37 like this.
  20. Jul 20, 2015 at 12:35 PM
    Taco me elmo
    Tophat bobcat
    Slow polished TuRD
    Anti theft 5-Speed
    You guys act like hes running ATF or diff oil in his engine its still 5w- the 20 and 30 make such little difference on a daily driver that it wont hurt anything.
    Yes I understand the VVti engine are a little more strict on swapping viscosity but its not like going from a 10w-30 to a 20w-50...
    I run 5w-40 instead of 5w-30 in my engine and 75w-140 instead of 75w-90 in my rear diff.. its fine.
    Snowman likes this.
