Useless 4WD indicator?
Discussion in '1st Gen. Tacomas (1995-2004)' started by MstrYota, May 23, 2017.
  1. May 23, 2017 at 8:46 PM
    MstrYota
    MstrYota [OP] Great balls of fire!
    Daniel
    Ventura County, CA
    2000 TRD 4x4 Prerunner/1998 TRD 4x4
    Too much but not enough!
    I'm about ready to swap transmissions on my truck from 2WD to 4WD. The 4WD transmission has an (from what I can tell) actuator on the back of the transfer case. IIRC all it does is tell the driver whether you're in 4WD or not? The truck has a J-shift case and manual hubs with an ADD diff with the ADD system locked full time in 4WD. I just planned on not hooking any of the wires up? Input would be appreciated
    Also the dudes that took the tranny out just frickin cut the main wire cluster so is that going to be an issue as well? Possible to use wire cluster off 2WD tranny? (You can see the main cluster of wires in the first pic, it's wrapped in the plastic tubing running along the top of the transmission
  2. May 23, 2017 at 9:00 PM
    MstrYota
    Daniel
    Ventura County, CA
    Herp derp forgot to select the proper forum for this, mods can you be of assistance? @tcBob
    tcBob likes this.
  3. May 24, 2017 at 3:07 AM
    COMAtized99
    COMAtized99 Well-Known Member
    North Carolina
    99 DCLB v8
    The Bed is stock...ish
    What did that transmission come out of? I'm pretty sure all the t cases that have the actuator on the back need the electrical side wired In to engage and disengage 4wd.
    DustStorm4x4 likes this.
  4. May 24, 2017 at 4:24 AM
    ToyRyd04
    ToyRyd04 Taco Transformer
    Greg
    Perryville, MD
    '04 PreRunner
    SAS'd PreRunner Diamond Axles Crawlbox
    That actuator engages 4wd, pretty sure that transfercase is the Multi-mode version from a 4runner. (Unique, able to utilize AWD).
    COMAtized99 likes this.
  5. May 24, 2017 at 7:22 AM
    pray4surf
    pray4surf Well-Known Member
    Rick
    Oceanside, CA
    98 PreRunner conv to 4x4
    F&R suspension, OBA, Custom bed rack, RTT, rear frame plates, 4x4 conversion from prerunner, many other
    I didn't bother with the idiot light connection...
    I have an ADD front and the j-shift transfer case - locating the correct nylon gear to get the speedo to function was the biggest hurdle. That cut loom would cause me fits. Holler if you need any wiring diagrams/FSM pages
  6. May 24, 2017 at 10:39 AM
    COMAtized99
    North Carolina
    99 DCLB v8
    I was thinking it looked alot like the tcase I just put in my truck. The OP has kind of a rare tcase and didn't realize it.
    ToyRyd04[QUOTED] likes this.
  7. May 24, 2017 at 10:43 AM
    ToyRyd04
    Greg
    Perryville, MD
    '04 PreRunner
    I think so, we were talking on another thread (about that shifter console with the cup holder built-in) recognizied it from that OPs pictures of the multi-mode.
    COMAtized99[QUOTED] likes this.
  8. May 24, 2017 at 4:19 PM
    MstrYota
    Daniel
    Ventura County, CA
    It came off of a 4Runner. I alwasy just assumed it worked with the ADD system which i didnt think was a big deal since i dont have it. So basically is this thing just a paperweight now because its the wrong damn transfer case? The transfer case is a J-shift, not the push button one on the later model first gens
  9. May 24, 2017 at 5:10 PM
    ToyRyd04
    Greg
    Perryville, MD
    '04 PreRunner
    It'll work with ADD since the 4runner it came out of had that. It's also a J shift, but unique because the shifter it's suppose to have also has a push button on the side.
    This info should help.
    MstrYota[QUOTED][OP] likes this.
  10. May 24, 2017 at 5:12 PM
    MstrYota
    Daniel
    Ventura County, CA
    i dont have an ADD wiring system nor did/do i want to start messing with wiring and electrical. So basically it won't work with my setup becasue it requires the electrical activation?
  11. May 24, 2017 at 5:21 PM
    MstrYota
    Daniel
    Ventura County, CA
    Found this on another site regarding the "multi-mode" and the conventional 4WD
    If I understand the 99-2000 Multimode T-case was a modified J-shifter with a 4wd button on the shifter. From 2wd with the shifter in the top-left position, pushing the button engages the 4wd with the center differential operating (i.e. unlocked.) This is the AWD mode. Then, pulling the J-shifter down to the Low-Left position locks the center diff and keeps the front axle engaged for "conventional" 4wd. Moving the J-shifter to the right and up then puts it into N and continuing up to the top-right position puts it in 4wd LO.
    On this t-case if the electric actuator fails, you lose AWD capability but can always run it in "conventional" 4wd mode by pulling the J-shifter down to the low-left position (I think!)
    So sounds like the electrical connections are only needed for the AWD functionality? So if i just dont hook any of it up i can still use conventional 4WD?
  12. May 25, 2017 at 4:29 AM
    COMAtized99
    North Carolina
    99 DCLB v8
    Op, that tcase will not work for you. It is a few inches longer than the normal tcase, and the 2 to 4 wheel drive shift just engages a switch and the ECU and actuator move the motor to get between 2 and 4 wheel drive
  13. May 25, 2017 at 4:57 AM
    gearcruncher
    Canadain bumper technician
  14. May 25, 2017 at 7:09 AM
    otis24
    otis24 Hard Shell Taco
    Mark
    California
    OtisBound Outdoors Bodonkadonk
    OtisBound Bodonkadonk
    The one thing with the idiot light is this...well 2 things.
    I've actually had chain control guys ask to see the 4wd indicator light on my truck. This has only happened twice, but I don't really go to the mountains in the winter all that much.
    If you're an idiot like me you'll get stuck on some boulders for 5 minutes before you realize you're in 2 wheel drive low range and not 4 wheel drive low range. That indicator is handy sometimes.
  15. May 25, 2017 at 8:19 AM
    pray4surf
    Rick
    Oceanside, CA
    Unless you alter the wiring, there is no 2-wheel low...
  16. May 25, 2017 at 8:25 AM
    otis24
    Mark
    California
    There's a much easier way to do that than that thread.
    There's a blue plug on top the transmission. Dissconnect it and you'll have 2 wheel low. It's great for tight switch back corners while you're in 4 low or super steep terrain with tight twists and turns where you want the torque but have a tactile surface that will cause drive train binding.
    Also, I've heard that 2 wheel low along with the gray wire mod (locker anytime) is great for doing donuts.
    pray4surf[QUOTED] likes this.
  17. May 25, 2017 at 8:40 AM
    MstrYota
    Daniel
    Ventura County, CA
    any of you guys want the transmission? lol
  18. May 25, 2017 at 2:53 PM
    COMAtized99
    North Carolina
    99 DCLB v8
    I'll give you 20$ plus the ride for the remaining harness on that transmission and Tcase.
  19. May 26, 2017 at 8:38 AM
    MstrYota
    Daniel
    Ventura County, CA
    It'd be easier to sell if everything was sold together
  20. May 26, 2017 at 9:02 AM
    COMAtized99
    North Carolina
    99 DCLB v8
    Most folks are going to want the whole engine harness, not a third. If you change your mind, let me know. Good luck with your project
