Using 2016 TRD OR, can a destination be enter while truck is moving?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Tacoma-or-Colorado?, Jan 16, 2017.
  1. Jan 16, 2017 at 6:25 AM
    Tacoma-or-Colorado?
    Tacoma-or-Colorado? [OP] Well-Known Member
    My wife's Mercedes C300 nav system does not allow me or a passenger to enter a new destination manually into the navigation system when the car is moving. I find that annoying. I can select addresses I have previously saved, just not a new one.
    With the 3rd Generation Tacoma TRD OR, how does that work? For example: I want to go to my friend's house, an address that is NOT in the "saved" addresses. Can my passenger manually enter the address into the navigation system? And/or can I verbally (attempt) to enter the address? I say "attempt" as most times our Mercedes C300 nav system gets really inventive with what we say....
    I have seen on forums where I cannot manually add a destination, but I have also read where I COULD- hoping for clarification!
    Not a big deal, just curious.......BTW, I do not currently own a Tacoma....trying to decide if the navigation system might replace my Garmin GPS.
  2. Jan 16, 2017 at 6:28 AM
    gpb
    gpb Well-Known Member
    Atlanta
    2017 White DCSB TRDOR 4x4
    Nope, not unless you put a switch into the vehicle speed signal wire. Do a search on reverse camera mod and you'll see some discussion. @jshsltr sells a 28pin harness that you can use to let you do this mod without cutting the factory wires.
    You might be able to verbally enter an address, I haven't tried.
  3. Jan 16, 2017 at 6:44 AM
    Pittrider
    Pittrider Pitty, those needing correction.
    Greg
    B.C.
    2016 MGM LTD LB
    Do you need to know, or care?
    Yes to verbally, no to manually.
  4. Jan 17, 2017 at 4:19 AM
    Tacoma-or-Colorado?
    Thanks to you both. I was afraid of that. Our Mercedes is the same, and nearly impossible to verbally enter an entire address without it interpreting it in sometimes laughable ways!
    ME: Find address.
    Nav: Please state the address
    ME: 123 Hornswallow Ln, Goleta, California
    Nav: Did you say 23 Swashbuckler's Cove, Palm Beach, Florida?
    Frustrating! However, Mercedes MBrace, which is the cell phone ap that links to our car, allows us to easily send an address to the car, along with other useful functions (remote start, locating the car <useful if someone borrowed it>, and a couple of the usual POI searches). HOWEVER, my passenger once tried to trick our navigation by sending an address using MBrace while in the car, driving, but the system refuses to do that since the car is in motion! I believe I will retain my trusty Garmin in any vehicle I buy, even if that vehicle has a built in navigation system. If it cannot be updated while driving it's nearly worthless. I understand the safety concerns and liability, but why not simply detect if there is a passenger, then allow the input while driving?
    Meangreen2 likes this.
  5. Jan 17, 2017 at 4:26 AM
    backtrack2015
    backtrack2015 Well-Known Member
    Austin TX
    2016 Silver DCSB OR 4x4 AT Tech (sold 8/17)
    Pop-n-lock tailgate. New radio knobs. Rear step.
    It is frustrating for sure especially since the truck is all setup to detect a front seat passenger. I believe you can modify the truck (snip wire and add a switch) to defeat this interlock if it is bothersome enough.
    It is interesting that MB does this too; I did not know that. BMW and Porsche let you do whatever you want.
  6. Jan 17, 2017 at 4:31 AM
    Spare Parts
    Spare Parts Well-Known Member
    Southern Maine
    2022 Off Road Premium 4Runner Lunar Rock
    Voice command is one way, and I agree it doesn't seem to listen to me. I have also used the app to add an address. Basicly if you plug in the addy on the phone app, then add it to saved locations , which you can access while moving.
    If navigation system is a high priority, it would not be a reason to buy the Tacoma.
  7. Jan 17, 2017 at 4:35 AM
    gpb
    Atlanta
    No they don't. Not unless they've changed it since the CIC systems.
  8. Jan 17, 2017 at 4:46 AM
    backtrack2015
    Austin TX
    I think you are correct. I swear we could do it in our 2014 X5 35d but I just asked the wife (it is her car) and she thinks it will only do presets/previous/search for POI/and voice entry (no manual entry of address). I'll have to try it next time we are in her car.
  9. Jan 17, 2017 at 4:49 AM
    smitty99
    smitty99 I also bought a 4Runner
    Scottsdale
    16 TRDORDCSB 4x4 A/T (loaded w/ JBL)
    6112s/5160s & 3-leaf AAL;ubolt flip kit;Superbumps
    No. Because the manual input won't work when driving and the voice commands will have you road raging.
    lesaverman and Spare Parts like this.
  10. Jan 17, 2017 at 5:08 AM
    NY Taco
    NY Taco Well-Known Member
    Rochester, New York
    2017 Inferno Sport DCLB
    Leer 180 Cap, Beat Sonic Navi By-Pass
  11. Jan 17, 2017 at 5:15 AM
    jake72
    jake72 Well-Known Member
    Jake
    N.E. PA
    2019 trd off-road dcsb mt
  12. Jan 17, 2017 at 5:21 AM
    gpb
    Atlanta
    Here's an $18 option. https://www.tacomaworld.com/threads/28-pin-head-unit-wiring-harness-adapter.458293/
    I suspect you can buy your own switch and run wires to it for much less than the $132 difference.
    (if you really need a no-drill stick-on switch, see this PIAA unit: https://www.amazon.com/PIAA-74034-Switch-Powersport-Harness/dp/B003D5E8DY )
  13. Jan 17, 2017 at 5:57 AM
    NY Taco
    Rochester, New York
    It works exactly as advertised! I had one in my Sienna for years, never a problem.
  14. Jan 17, 2017 at 10:18 AM
    Tacoma-or-Colorado?
    Interesting......I will have to do more research on the "addy" on the phone. What is the full name of that phone app?
    Does that app allow you to find a location on your phone, then transfer it to the truck's nav system? And could a passenger do that while the truck is moving.
    Oh, the nav system is not a high priority, but I would probably not go for a trim level that didn't have what seems to be the basic radio....seems like every SR5 and above has navigation in it. Totally different from the GM where it's a $1000 upgrade (have to get Bose radio with the GPS).
  15. Jan 17, 2017 at 10:20 AM
    Tacoma-or-Colorado?
    I am both too cheap for that and not that adamant to add that feature. Thanks for the link though.......you never know.......<g>
  16. Jan 17, 2017 at 10:45 AM
    Spare Parts
    Southern Maine
    its the toyota Entune app suite, you find the destination in the app, click on saved, it goes to the saved destinations app in the suite. I know when i first get in and my phone connects it will up date saved destinations, but not sure while traveling.
  17. Jan 18, 2017 at 4:50 AM
    Tacoma-or-Colorado?
    Thanks. That sounds exactly like the Mercedes MBrace app, but I know THAT won't send any data when you're driving. I believe it's set up to only receive the new destinations when the car starts each time. I can live with it, but it would be nice if the passenger could manually enter data as needed. I maybe wrong, but it seems like as the built-in nav systems work that way. Another reason to hang onto my Garmin 2597 with life time maps!:cool:
    Spare Parts[QUOTED] likes this.
  18. Jan 19, 2017 at 5:36 AM
    NoDak
    NoDak Well-Known Member
    JR
    Minot, ND
    16 Tacoma TRD Sport 4x4 Blazing Blue
    or you know buy a $100 garmin unit with free lifetime map updates and you kill 3 birds with 1 stone.
    1. save $50 from beatsonic and save on install $$$ and time
    2. don't have to pay to update the maps in the head unit from toyota
    3. you can what ever you want with a garmin while driving
    Spare Parts likes this.
  19. Jan 19, 2017 at 5:42 AM
    gpb
    Atlanta
    You forgot:
    4. Take it down and put it away every time you park lest you come back to a smashed window​
    Been there, done that. No thanks.
  20. Jan 19, 2017 at 5:53 AM
    NoDak
    JR
    Minot, ND
    not like you use the nav all the time. just like you don't use the built in nav all the time :)
    mine just stays in the center console unless I really need it. in a quick pinch I use my phone.
