Using 4cyl front diff on a V6 to regear?
Discussion in '1st Gen. Tacomas (1995-2004)' started by SummitHans, Jan 20, 2023.
  1. Jan 20, 2023 at 1:34 PM
    SummitHans
    SummitHans [OP] Active Member
    Colorado
    '04 Tacoma TRD OR SR5
    Icon 3" Lift Total Chaos UCAs and LBJ Uniball Conversion Solo Motorsports LCAs Fr33Lance Fab Spindles LC Engineering Tundra Brake Swap AFe Intake Aluminess Bumpers F+R Coastal Offroad Sliders KP Offroad Alignment Cams And more...
    Weird question, but weird circumstance...
    I have a 5spd v6 that was regeared to 4.56 and the front diff grenaded. Apparently the stock 4cyl has 4.56 gears...can you swap in a used front diff from a 4cyl into the V6 instead of paying to rebuild the diff?
  2. Jan 20, 2023 at 2:12 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    I don’t see why not. Just make sure the front is for sure 4.56.
    The V6 had 4.10 best I remember?
    SummitHans[OP] likes this.
  3. Jan 20, 2023 at 2:41 PM
    Dirty Pool
    Dirty Pool FLIES ON THE FRIES, KETCHUPS WATERED DOWN
    59.4 Miles, 56.67° NE Of Moab
    99 XCAB V6 MT TRD
    Dirty Pool rear bumper/air tank with integrated spare CV shaft storage, DP customized TJM front bumper, 8000 lb Ramsey/Technora rope, E-locked, Extended breathers with front diff catch can, PCV catch can, SAWs with DP heim joint seals, DP custom 6 leaf rear springs/Billies, DP custom skids, 2lo, Gray wire, Cap, Bed Rug, Black steelies, 01 Center console, Map lights, Disraeli gears
    Yes, but do verify the ratio and..............
    Your 04 should have the "ADD" system. You will need a diff from an ADD equipped truck. "ADD"=automatic disconnecting differential, not manual hubs.
    A factory manual hub equipped truck can use a manual hub or ADD diff.
    SummitHans[OP] and TnShooter like this.
  4. Jan 20, 2023 at 2:48 PM
    SummitHans
    Colorado
    I wasn't aware there were gen 1's with manual locking hubs...
  5. Jan 20, 2023 at 2:50 PM
    Wulf
    Wulf no brain just damage
    rock raisin
    There are! You can swap the stub shaft and diff tubes from ADD and manual hub trucks as well. the add/manual tube bolts on to the differential. You can take your ADD stub shaft + tube + actuator and install it on whatever front diff you end up using.
    96-2004 Tacoma all use a 7.5" front diff
  6. Jan 20, 2023 at 2:52 PM
    SummitHans
    Colorado
    Pretty rad! You learn about something new (to spend money on) every day...
  7. Jan 20, 2023 at 2:56 PM
    Dirty Pool
    99 XCAB V6 MT TRD
    They were available up to 00 or 01 IIRC.
    ADD and man hub diffs are different. The compatibility deal is the ADD diff has a few additional parts inside the diff proper not found on the manual hub diff. These parts do not interfere when putting an ADD diff in a manual hub truck or converting an ADD truck to man hubs.
  8. Jan 20, 2023 at 3:12 PM
    Dirty Pool
    99 XCAB V6 MT TRD
    ADD diff, pass side, extension tube removed. In the darkness beyond the oil slinger is a needle bearing, also not found on a man hub diff.
    Man hub diff, no slinger or needle bearing.
    Needle bearing in ADD not seen in first pic.
    Bivouac and SummitHans[OP] like this.
  9. Jan 20, 2023 at 3:44 PM
    Wulf
    rock raisin
    When I took my truck apart for regearing it had an oil slinger despite being manual tube and hubs but perhaps someone had swapped in an ADD third prior to my ownership
    Dirty Pool[QUOTED] likes this.
  10. Jan 20, 2023 at 3:52 PM
    Dirty Pool
    99 XCAB V6 MT TRD
    That or possibly factory ADD converted to man hubs. That was fairly popular back in the day.
