Using 4hi on steep driveway?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by TheTurk, May 25, 2021.
  1. May 25, 2021 at 2:17 PM
    TheTurk
    TheTurk [OP] Well-Known Member
    Kendrick
    California, Central
    2019 TRD OR
    Hi guys so I recently moved to a new place where the driveway is like a mountain. I find the truck struggling on 2wd coming out of the driveway. Would it be fitting to shift to 4hi for this driveway? Or should I do 4lo? TIA
    Black DOG Lila likes this.
  2. May 25, 2021 at 2:20 PM
    GOTSAND?18
    GOTSAND?18 Well-Known Member
    2020 tacoma trd off road 4x4 Manual
    stock
    4high not recommended on dry pavement.. I would say not the best idea .plus u need to be in 4high first then go to 4low it won’t engage going straight to 4 low .
  3. May 25, 2021 at 2:21 PM
    Cudgel
    Cudgel “Tonka”
    Live in: An Ocean of Plastic Trash
    2017 OR DCLB
    ICON8 Lift -285s. upTOPoverland rack.
    On Friday use reverse.
    hiPSI, airmax233, Prestovie and 8 others like this.
  4. May 25, 2021 at 2:22 PM
    0xDEADBEEF
    2000 reg cab 4x4 flatbed MT
    Only if the tires are slipping.
    hiPSI, Prestovie, henryp and 5 others like this.
  5. May 25, 2021 at 2:23 PM
    Rock Lobster
    Rock Lobster Thread Derailer
    Dee Eff Dub
    I drive a Miata.
    I mean, its a steep drive, but its not that steep. o_O Are you squealing tires or losing power? There might be bigger issues at hand if you lack the power to climb that.
    4Hi doesnt give you any more gas pedal. 4Lo would give you a lower gear.
  6. May 25, 2021 at 2:25 PM
    TheTurk
    Kendrick
    California, Central
    2019 TRD OR
    Tires squeezing, I am running bfg k02
  7. May 25, 2021 at 2:26 PM
    Rock Lobster
    Dee Eff Dub
    I drive a Miata.
    What pressure are they at?
  8. May 25, 2021 at 2:26 PM
    stevebaz
    stevebaz Well-Known Member
    2016 access cab, TRD offroad 4x4, Quicksand
    if you have an automatic put it in 1st gear manually and push the ect button.
    Jojee117 and TheTurk[OP] like this.
  9. May 25, 2021 at 2:27 PM
    TheTurk
    Kendrick
    California, Central
    2019 TRD OR
    30 psi. I will be here for the long term and I do not want to damage anything. I also have neighbors so doing a peel out and going nowhere was really fun.. It has been 1 week that I've been using 4hi to get out
  10. May 25, 2021 at 2:29 PM
    essjay
    essjay Part-Time Lurker
    Concord, CA
    2011 Tacoma SR5 (V6/AC/4WD)
    If you legitimately need 4WD to get up that driveway, your truck is fucked.
    krtek, Prestovie, gman2431 and 11 others like this.
  11. May 25, 2021 at 2:31 PM
    stevesnj
    stevesnj Well-Known Member
    South Jersey/Philly Area
    1996 Land Cruiser 80 Series
    Yes 4wd hi is fine on dry as long as you don't make any sharp turns.
    knayrb, 02Duck, antlab67 and 6 others like this.
  12. May 25, 2021 at 2:31 PM
    Rock Lobster
    Dee Eff Dub
    I drive a Miata.
    4Hi works short term. For long term I would lay down a texture top coat on the driveway to help improve traction for all vehicles.
  13. May 25, 2021 at 2:32 PM
    TheTurk
    Kendrick
    California, Central
    2019 TRD OR
    The driveway is almost polished concrete. When you live across the street from a dirt mound, dust gets onto it, creating a slippery surface.
  14. May 25, 2021 at 2:32 PM
    Dubiousveracity
    Dubiousveracity Well-Known Member
    2018 TRDOR DCSB MT
    none
    4 high on pavement is fine if not turning tight. Though if you are struggling to get up that in 2hi and it's not a traction issue 4 high won't help...
    So 4 low, which again is fine if not turning tight.
    There's also the 2 low mod.
    henryp and TheTurk[OP] like this.
  15. May 25, 2021 at 2:34 PM
    Thunder Fist
    Thunder Fist Well-Known Member
    David
    Birmingham, AL
    2017 MGM TRD OR DCSB
    Like, so many.
    4wd on dry pavement is fine if you're going straight.
    Chako, henryp, jmneill and 3 others like this.
  16. May 25, 2021 at 2:36 PM
    balljoint
    balljoint Well-Known Member
    Dave
    Ontario
    '18 DCLB
    The angle maybe means sand and gravel and anything that drops off your frame will slide down to your rear wheels and compromise traction. Try a regular sweeping of the driveway and maybe keep something in the back for a bit of weight over your drive wheels.
  17. May 25, 2021 at 2:36 PM
    Junkhead
    Junkhead TRDude
    Serge
    Prince George, BC
    Black 4x4 Sport MT 2018
    Some Serious Tires
    You meant 2WD LOW mod?
    henryp likes this.
  18. May 25, 2021 at 2:37 PM
    Dubiousveracity
    2018 TRDOR DCSB MT
    none
    Yep
    henryp and Junkhead[QUOTED] like this.
  19. May 25, 2021 at 2:37 PM
    stevesnj
    Also try 2nd gear if it's a manual. Dunno if the auto has a 2nd gear start. You could try. Put it in 2nd and if it revs a little more than usual it has 2nd gear start.
  20. May 25, 2021 at 2:38 PM
    brandon78lusch
    brandon78lusch Well-Known Member
    Brandon
    East Carolina University
    2019 TRD Sport DCSB, 1978 Pontiac Firebird Trans Am
    whats it like in the rain? oh wait it doesnt rain in california
    TheTurk[OP] likes this.
