Using 4x4 on pavement
Discussion in '2nd Gen. Tacomas (2005-2015)' started by TG8, Dec 26, 2011.
  1. Dec 26, 2011 at 10:18 PM
    TG8
    TG8 [OP] Well-Known Member
    Trey
    Laredo, Texas
    2011 Tacoma Trd Sport 4x4
    STOCK STOCK STOCK SUCK STOCK STOCK WeatherTech Floor Mats All-Weather throughout the truck Smittybilt Bull bar with Hella 500 Series Halogen Driving Lamp (2)
    Using 4x4 on pavement will mess up your truck right not only wear out tires extremely fast?
  2. Dec 26, 2011 at 10:18 PM
    OZ-T
    OZ-T You chose ... poorly
    Peter North
    British Columbia
    Going straight is no problem , tight turns will bind up the front end
  3. Dec 26, 2011 at 10:19 PM
    Maverick904
    Maverick904 Resident Fishing Expert
    Kameron
    Northeast Florida
    08 TRD Rugged Trail 4x4
    3" Procomp Lift, BDF Light Bar, Borla Stainless Cat-Back System, 2 10" Polk MM Subs, LED Interior Lighting, Pioneer Touch Screen, Kicker Speakers up front, Sonys in the back, Grillcraft grill, 20% tint, Weathertechs, Projector Retrofit Headlights. BHLM
    the one and ONLY time 4x4 should be used on pavement is when there is a shit ton of snow and ice on it...and in that case you probably shouldnt be driving anyway.
  4. Dec 26, 2011 at 10:20 PM
    OZ-T
    Peter North
    British Columbia
    Or a boat ramp
  5. Dec 26, 2011 at 10:20 PM
    MQQSE
    MQQSE Afoot is the game
    Rob
    Palmer, AK
    x2 ... and somebody around here has a real good explanation link in his sig ... can't remember the handle?
  6. Dec 26, 2011 at 10:21 PM
    Maverick904
    Kameron
    Northeast Florida
    yeah that too...but turn it off before you turn. luckily the ramp i use doesnt get bad...yet.
  7. Dec 26, 2011 at 10:21 PM
    Maverick904
    Kameron
    Northeast Florida
    its whippersnapper
  8. Dec 26, 2011 at 10:23 PM
    OZ-T
    Peter North
    British Columbia
    FWIW , I drive in 4x4 for days when there is snow on it .
  9. Dec 26, 2011 at 10:24 PM
    TG8
    Trey
    Laredo, Texas
    Okay just making sure bc my friend was telling me how is it harmful can it be on the road if I use it on mud but I told him he's a idiot bc it's two complete different surfaces
  10. Dec 26, 2011 at 10:24 PM
    MQQSE
    Rob
    Palmer, AK
    ... and OffRoadToy. Found it ... damn sometimers gets worse all the time! :eek:
  11. Dec 26, 2011 at 10:24 PM
    Maverick904
    Kameron
    Northeast Florida
    I dont have the issue down here :D Our ramps just get slippery at super low tides when the shit thats covered by water 90% of the time is exposed and its covered in algae and shit.
  12. Dec 26, 2011 at 10:25 PM
    TG8
    Trey
    Laredo, Texas
    Is turning tight in snow still okay even if your grabbing some pavement
  13. Dec 26, 2011 at 10:25 PM
    TnRedNeck721
    TnRedNeck721 GO VOLS!
    Zach
    TN
    07 TRD off road 4WD
    i have had to use it on my drive way 2 times. when it has been raining really hard. my drive way it kinda steep and get slick. drive way is straight tho. just don’t turn at all.
    also i COULD use new tires.. but i don’t have the money right now.
  14. Dec 26, 2011 at 10:28 PM
    OZ-T
    Peter North
    British Columbia
    You will still feel it bind up , as long as there is some slip it's not too bad .
    Generally you want to try to take a wider turn , or pop it back to 2wd if that is an option
  15. Dec 26, 2011 at 10:28 PM
    Maverick904
    Kameron
    Northeast Florida
    and you will know when it binds up...trust me...
  16. Dec 26, 2011 at 10:31 PM
    MQQSE
    Rob
    Palmer, AK
    If it's slippery than you'll be fine; that's what it's there for.:cool:
    ... I use mine all the time in snow and ice (Alaska). By my understanding, it becomes a problem on dry pavement. No problems and I'm into my second winter with my truck.
    Well... only issue is recent replacement of my front wheel bearings at 58K miles, but that's a known weak spot for my year and I don't believe related to my use of 4X4.
  17. Dec 26, 2011 at 10:34 PM
    MQQSE
    Rob
    Palmer, AK
    I flip mine between 2HI and 4HI as needed ... like he said, 2HI is better for a tight turn. You'll feel the truck kind of "crab walk" if you turn tight in 4HI (or 4LO for that matter).
  18. Dec 26, 2011 at 10:37 PM
    Hilborn
    Hilborn Zombie Killer of the Year - Nominee
    Dallas/Fort Worth
    2009 DCLB TRD Sport 4x4
    Akebono Performance Ultra Premium Ceramic Pads ATO Hi-Lift Jack Mounts AVS Window Vents AVS Door Sill Protectors BAMF Bolt-On Sliders BAMF CMC Plates Banks Cat-Back Exhaust BedRug Bilstein 5100 Shocks Console Vault Differential Breather Relocation Mod DynaBeads Garmin NUVI GPS Goodyear Duratrac 265/70-17 Hi-Lift 48' Extreme Jack HCF Delete Hypertech In-Line Speedometer Recalibrator IGGY Switch Panel JBA UCAs Leer 100XQ Method Vex Titanium 17x8.5 OME 886x Coil Springs OME CS047R Dakar Leaf Springs OME Carrier Drop Kit Optima D27F Yellow Top Pop n' Lock rcbs204 Illumited 4x4 Switch Rexing V1 Dash Cam Stoptech Sport Slotted Cryo-Treated Rotors Sway Bar Delete ToyTec Solid Steel Axle Degree Shims Toyota Cargo Divider USA Spec IPod Interface Vibrant Ultra Quiet Resonator Weathertech Floor Mats Wheeler's 3/8" Top Plate Spacer Wheeler's Brake Lines Wheeler's SuperBumps with 3/8" Spacers
    i used my truck in the snow last winter driving to and from work in 4hi going 50+. didn't have alot of sharp turns since i was mostly on the freeway. always look forward to winter so it'll snow again so i can drive in it. would take alot for me to put it in 4hi even in the rain. just no needed for it.
  19. Dec 26, 2011 at 10:41 PM
    IDtrucks
    IDtrucks Unhinged and Fluid
    Mark "Buck"
    Jackson Wyoming
    :facepalm:
    seriously...thats a shitty answer. there is, unbelieveably, an inbetween for snow conditions on road. there is no problem at all with driving on the roads with 3" of snow, are you saying that 4wd is not needed for example, with 3" of snow or that 3" of snow is too much and you shouldnt be driving in it?
    4wd is for low traction sitiations, on pavement thats pretty limited to situations like snow and ice, you dont need 4wd for when it rains, thats not low traction enough. as said before driving with 4wd on with dry pavement will cause it to bind or even break.
  20. Dec 26, 2011 at 10:42 PM
    MQQSE
    Rob
    Palmer, AK
