Using a 96R battery?
Discussion in '1st Gen. Tacomas (1995-2004)' started by DietSoda6, Dec 1, 2022.
  1. Dec 1, 2022 at 6:09 PM
    DietSoda6
    DietSoda6 [OP] New Member
    1995 Totota Tacoma Ext. CAB V6 3.4L
    Greetings! Has anyone had to use a 96r instead of what it actually takes? Is that comparable to 24F or 35? Would it cause issues if used temporarily?
  2. Dec 1, 2022 at 6:55 PM
    Bivouac
    Bivouac Well-Known Member
    Northern Lehigh Valley Pa
    2000 Tacoma 5 speed 3.4
    Remains to be seen I bought the tires and wheels the rest came along
    You should be fine it looks to be a AGM battery Positive post on the right side like a 24F
    Make sure to find out the height of the battery.
    Just what manufacture are you planning to get.
    No reason to not just leave it in
