Using a foam cannon
Discussion in 'Detailing' started by pinktaco808, Mar 29, 2023.
  1. Mar 29, 2023 at 12:46 PM
    pinktaco808
    pinktaco808 [OP] Hot Steppa
    Any tips and steps on using a foam cannon with washing??
  2. Mar 29, 2023 at 4:27 PM
    EnviroJunkie
    EnviroJunkie Well-Known Member
    Cody
    Spokane, WA
    '17 Tacoma DCLB TRD OR
    just make sure you follow up with a t-shirt cannon
    23MGM, Taco 422 and Speedbird like this.
  3. Mar 29, 2023 at 4:39 PM
    avi8or_co
    avi8or_co Well-Known Member
    2019 Cavalry Blue TRD Sport, 2023 Lexus IS500
    Hose off with the pressure washer…make sure the WHITE nozzle is on the gun.
    Hit it with the foam and let it dwell a few min. I usually use that time to do the wheels.
    Hose off the foam and do a light touch contact wash with 2 buckets with grit guards.
    Hose off and dry with the electric leaf blower
    That’s my method….
    Taco 422 and pinktaco808[OP] like this.
  4. Mar 30, 2023 at 5:09 PM
    pinktaco808
    Any water spot or run from washing after
  5. Mar 30, 2023 at 8:36 PM
    avi8or_co
    Nope…get in the body/rear view/door/lights/seams good with the blower and push the majority off the panels as best you can. Then follow with a MF drying towel and a squirt of detail spray to get the last remnant off.
    The blower method works excellent with
    well waxed/sealed paint. Now if you haven’t done that in a year that’s another story and the water won’t come off well. In that case: wash, clay, I’d wash again after claying, hand dry, buff if you’re going to and then wax/seal.
  6. Apr 18, 2023 at 5:50 AM
    bboggio28
    bboggio28 Well-Known Member
    2020 TRD Sport
    i always try and foam it twice. so start with dry car, hit it with foam cannon and let dwell a bit. rinse off with pressure washer and a tip that is safe for car paint. hit again with foam cannon and let it dwell. this time you can incorporate either the two bucket method or use like 6 microfiber towels and never reuse them during the wipe down. . then hose it off again. leaf blower off any water you can, micro fiber towel dry, and then use a quick detailer spray and another microfiber.
    sorry, should have mentioned this. start with wheels and tires first. clean all four then do the body of the car.
  7. Jun 4, 2023 at 3:40 AM
    VaToy
    VaToy Life Long Member
    Parts Unknown
    2018 TRD DCLB Sport 4x4 Silver Sky
    Bilsteins 5100s on the top setting, 4runner Gray TRD Pro Sema wheels, 285/70/17 Toyo AT3s, Sumo Bump stops, TRD exhaust, ECGS Clamshell bushing, 1/4 shim for the lean and one inch rear block, OEM Pro grill and garnish OEM TRD Skid plate, TRD CAI, Demon Brackets, Rigid Industries Pro fog lights, OEM Trail Rails sidebars, Diode Dynamics LED SL1 high and low beam lights, OEM Roof racks, Clazzio leather heated seats, Remote Start, TRD Pro shift knob, tinted windows, Rockford Fosgate 4 channel amp for the headunit and sub and amp combo, OEM Puddle lights, OEM tailgate lock, OEM bed mat, LED interior lights, OEM blackout kit for letters, JLT catch can, upgraded 27F toyota True Start battery, Vleds led tail light kit with Pro tail lights, OEM Rave4 side mirrors with convex spotters,just to name a few mods.
    Do your fender wells first, then wheels and tires last, then wash. Foam cannon in sections on real hot days even if your in the shade. I use a mild car wash and a multi purpose cleaner that is safe for paint prior any paint coatings but on a maintenance wash I just use the 2 bucket method, dry with filtered air drier, a nice spray was detail spray for a top coat on my coating.
    pinktaco808[OP] likes this.
