using a highlift without sliders??
Discussion in '1st Gen. Tacomas (1995-2004)' started by wolfgang123, Jun 6, 2010.
  1. Jun 6, 2010 at 2:05 PM
    wolfgang123
    wolfgang123 [OP] Well-Known Member
    Skyler
    Charlotte, NC
    1997 TACOMA - 4x4
    is it possible? where would i place the jack? i dont have money for sliders but i do have a highlift, and my jack for the truck broke on me the other day :(
  2. Jun 6, 2010 at 2:11 PM
    bailerc
    bailerc Well-Known Member
    Cody
    Fayetteville, NC
    16' MGM Limited
    high lifts have a bunch of accessories that you should be able to use to get it off the ground with no body damage
  3. Jun 6, 2010 at 2:18 PM
    colinb17
    colinb17 If at first you don't succeed, don't try skydiving
    Colin
    Charleston, SC
    '07 TRD Sport 4x4
    Build thread in sig... 4-link long travel
  4. Jun 6, 2010 at 2:20 PM
    Jason'sLawnCare
    Jason'sLawnCare Prepared for Bambi
    Jacksonville Florida
    08 4x4 Double Cab TRD Rugged Trail
    CBI Moab 2.0, CBI Trail Rider 2.0, CBI sliders w/kickout, Superwinch EPi9.0S, OME sport shocks w/886 coils, OME n182, 1.5" aal, JasonBuilt 3/16th full belly skid, BuiltRight uca, Body Mount Chop, 285/75/16 km2's, Rear cat delete, exhaust crossover rerouted, Fog light anytime, Locker mod, Rear leaf tsb, Debadged, Uws Tool Box, Electric Exhaust Cutout, AFE Pro Dry S, Kiwi Wifi, Diff Breather Relocated, Grom Ipod Adapter, Dual Diehard platinum batteries isolated by BlueSea marine switch
    x2 on the hi lift accessories. There's something to lift from the wheels but I don't think that would be good for swapping a spare on there. For the rear you could use the hitch.
  5. Jun 6, 2010 at 2:29 PM
    dylandercole
    dylandercole Well-Known Member
    Dylan
    Santa Cruz Mountains, CA
    03 SR5 TRD 4x4 5-speed
    sway-a-way 2.0 coilovers, 1.5'' AAL, 1'' toytec shackle lift, Go-Rhino 3000 Grille Guard, Kicker KS6502 speakers, JVC KD-S24 Head unit, billstein 5125 rear shocks, Deck Plate mod, K&N air filter, Wheelers offroad front and rear braided brake lines, diff breather mod, power slot rotors, ebc yellow stuff pads
    x2 on using the hitch for the rear
  6. Jun 6, 2010 at 2:57 PM
    wolfgang123
    Skyler
    Charlotte, NC
    1997 TACOMA - 4x4
    yeah im looking to use it instead of replacing my broken stock jack. so i would need to able to swap tires and such.
  7. Jun 6, 2010 at 6:01 PM
    BRP27
    BRP27 When I grow up I want to be just like Me
    So far south in Texas my feet are in salt water
    04 4X4 Tacoma SR5
    3 in Ultimate ToyTec, set @ 2.5 in. AAL PINCH Weld Mod ( beat the pinch weld over inside the fender) Painted the pinch weld on bottom of cab Black Hi Lift Knock off
    I have a reciever hitch on the front and the back. I use the hi lift in the recievers to lift the front or back. The truck is lifted and a stock jack doesnt work for me. I don't have sliders
    They make recievers for the front of tacomas. It is a simple bolt up.
    here is a pic
  8. Jun 6, 2010 at 8:05 PM
    wolfgang123
    Skyler
    Charlotte, NC
    1997 TACOMA - 4x4
    where you get the front hitch???
  9. Jun 6, 2010 at 8:11 PM
    ttylerr
    ttylerr Well-Known Member
    Tyler
    Fort McMurray, Alberta
    09 MGM 4Banger 4x4
    5% tint all around, Alpine IVA-W505, 16x8 Mojave Teflon Rims w/Hercules Terra Trac 265/75, Grillcraft Grill, Slimcubby HIDs, Front 5100's @ 0 w/Eibach 1.6" springs, URD Short Shifter, Extang Trifecta Tonneau Cover, Uniden Pro510XL and K30Mag Mount, Relentless Fab Bumper soon to come
    i use the hi-lift lift mate and bring a jackstand along to drop the axle on to swap tires. works perfect
  10. Jun 6, 2010 at 9:30 PM
    wolfgang123
    Skyler
    Charlotte, NC
    1997 TACOMA - 4x4
    yes but where do you put the highlift as to not damage the body? that the problem.
  11. Jun 7, 2010 at 4:48 AM
    BRP27
    04 4X4 Tacoma SR5
    Ebay its made by Curt
  12. Jun 7, 2010 at 7:49 AM
    colinb17
    Colin
    Charleston, SC
    '07 TRD Sport 4x4
    if you have a jack stand, you can use the wheel-mate to do the actual lifting, and still be able to swap out a tire
  13. Jun 7, 2010 at 8:47 AM
    Paul's TRD
    Paul's TRD I'm Not Your F***ing Brother
    TX
    2011 Z71 4x4 5.3L V8
    Sorry Threadjack. This is what I want. Going to be getting one of those hitch mount winches b/c i don't exactly want one permanently attached. Got a buddy that has this mounted on his jeep and works freaking great.
  14. Jun 7, 2010 at 8:49 AM
    SC4333
    SC4333 Well-Known Member
    Grant
    FL
    SOLD - 2016 TRD Off-Road 4x4 DCSB
    Get the hilift wheel adapter. I use one on my truck, and keep a 6 ton jackstand with me when going on long adventures off road.
  15. Jun 7, 2010 at 9:07 AM
    sachou
    sachou Well-Known Member
    Sam
    Richland, Washington
    2006 TRD Sport Acc Cab 4x4 V6 6spd
    I wouldn't recommend getting a Hi Lift to replace your home jack. Get a good beefy floor jack for use when your working on it in your driveway or garage.
    You will not be able to jack from anywhere on a stock truck unless you have the wheel accessory as mentioned, or two receiver hitches front and back. But even then that's pretty inconvenient imho.
    Hi Lifts should be used on the trail, and in conjunction with jack stands if you're going to be underneath it.
  16. Jun 7, 2010 at 9:10 AM
    colinb17
    Colin
    Charleston, SC
    '07 TRD Sport 4x4
    i'll be running that exact setup by the end of the summer....glad you're happy with it:)
  17. Jun 7, 2010 at 9:14 AM
    brutalguyracing
    brutalguyracing BIG DADDY
    F.U> GUYZ
    broken mods
    x2^^^^^^^^^^^^^^^^^^^
  18. Jun 8, 2010 at 8:28 AM
    wolfgang123
    Skyler
    Charlotte, NC
    1997 TACOMA - 4x4
    ok guys thanks for the info, i guess i will pick up a bottle jack or something to cary with me. i am also buying one of those front hitchs for when i get my winch...thanks guys
  19. Jun 8, 2010 at 11:58 AM
    Jason'sLawnCare
    I just read something that could make using the hitch a bad idea. The truck could go side to side and the hi lift could slip out of it or be moved to an angle.
  20. Jun 8, 2010 at 12:59 PM
    BRP27
    04 4X4 Tacoma SR5
    That not an Hitch only issue. Hi lifts are famous for going side to side and the truck falling
