Using a recovery strap, where and how do I attach it?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by 80sforlife, Nov 21, 2016.
  1. Nov 29, 2016 at 2:23 PM
    #101
    LeftCoastNerd
    LeftCoastNerd Old 'nuff to know betta
    Santa Cruz, California
    08 AC 4x4 OR 6sp
  2. Nov 29, 2016 at 2:32 PM
    #102
    zerotimeouts
    zerotimeouts Well-Known Member
    Nor Cal
    2011 DCSB 4.0 S/C
    Is it OK to extend a dynamic recovery strap with a tow strap?
    Was thinking of using soft shackle in between but you could probably also loop them through each other.
  3. Nov 29, 2016 at 2:37 PM
    #103
    Paul631
    Paul631 Well-Known Member
    2016 4x4 5-spd Utility Package
    Bilstein 6112/5160 Grabber X3's
    It should be ok to extend it, as long as load ratings aren't exceeded.
    With regards to looping them together:
  4. Nov 29, 2016 at 2:44 PM
    #104
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    I would only use that for pulling a disabled vehicle along a road, i.e. no real resistance. If you're pulling people out of ditches, a snatch strap like I linked earlier will be much more beneficial. I've even used mine a couple times to help people when I wasn't off roading. One was a high-centered chrysler 300 and another was a mini van stuck in deep sand. Both times the ARB snatch strap made for a flawless and smooth recovery. The same probably couldn't have been said if I'd been using a tow strap with those hooks.
  5. Nov 29, 2016 at 2:45 PM
    #105
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    I'm sure it'd be fine but I wouldn't pull as hard as I would with one or two snatch straps linked together. At least not until I got a feel for how much that combo stretched.
    zerotimeouts[QUOTED] likes this.
  6. Nov 29, 2016 at 2:49 PM
    #106
    zerotimeouts
    Nor Cal
    2011 DCSB 4.0 S/C
    Hopefully it isn't something I need to practice often.
  7. Sep 18, 2017 at 4:23 PM
    #107
    Roland79
    Roland79 Well-Known Member
    Dave
    Missouri
    2017 TRD Off Road DCLB Black
    Sorry for ressurecting an old thread, but I'm buying an ARB recovery strap. I know Bubba Ropes are great, and Wheelers etc...but I'm buying an ARB.
    My question is, the straps maximum rating is supposed to be 3 (or 3.5?) x's the weight of the vehicle you are pulling out. I think I'll be fine with the 2 3/8" 17.5klbs rated ARB recovery strap, or would the 3" 24klbs one be better? I know you don't want overkill on these recovery straps, because they don't allow the strap to stretch/function properly if they are rated for too much weight. (30k lbs + etc)
    Just wondering which you guys would go with.
    DustStorm4x4 likes this.
  8. Sep 18, 2017 at 4:28 PM
    #108
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    I have the 17.5k one, and that's the best IMO. Our trucks only weigh like 5k lbs, so anything more than the 17.5 is overkill.
    hafjell and Roland79[QUOTED] like this.
  9. Sep 18, 2017 at 4:43 PM
    #109
    Roland79
    Dave
    Missouri
    Yes, Ive been thinking that is the best option. I've been looking online for an hour or two now, for good info. I finally found the info I needed on ARBs website (go figure o_O).
    I was thinking that maybe if I was pulling a truck a little heavier than mine out, I would need the heavier one. But on ARBs site, it says that when using a snatch/recovery strap to recover a stranded vehicle, you use the gross vehicle mass of the lighter vehicle, to determine the the 2-3x weight ratio for minimum breaking strength. So I'd easily be under that 17.5k lb MBS, even if I was pulling out a little heavier vehicle than mine.
    EatSleepTacos[QUOTED] likes this.
  10. Sep 18, 2017 at 6:20 PM
    #110
    Joe23
    Joe23 Canuckistikian
    The Great White North
    2017 TRD Off-road DCSB
    one of the guys I go on the trails with has something like that and its already bending.
    For what its worth it may be expensive but i have the new ARB recovery point and holy hell is it strong.
    tested and rated for 17 000lbs I believe.
    Safe to use for a snatch recovery.
