Using coolant
Discussion in '1st Gen. Tacomas (1995-2004)' started by Bashlin, Jul 8, 2009.
  1. Jul 8, 2009 at 4:27 PM
    Bashlin
    Bashlin [OP] New Member
    MIssouri
    tacoma 4X4
    Hello everybody,
    I'm new and trying this out. I have 1998 tacoma had for over a year and it is using coolant. Mech. has pressure tested it and put dye in it and says everything is ok. Should i trust that?
  2. Jul 8, 2009 at 4:42 PM
    BakoTruck
    BakoTruck Well-Known Member
    Herbie Hancock
    Bakersfield, CA
    05 PreRunner TRD
    Mostly stock for now, I have added a cb radio, various cheap mods and I plan on adding aftermarket wheels and other items in the future.
    Um maybe I'm missing something here or it's because I'm not an expert, but I'm not sure what your problem is. Do you mean it's leaking coolant? What is the problem?
  3. Jul 8, 2009 at 5:16 PM
    Bashlin
    MIssouri
    tacoma 4X4
    my resvoir keeps going down so i asumed it was using coolant somehow.
  4. Jul 8, 2009 at 5:23 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    how much are we talkin? a little coolant use...mainly evaporation, is pretty normal.
  5. Jul 9, 2009 at 4:29 AM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    How many miles on the truck? When you say, resevoir...do you mean the overflow tank? How far is it going down by?
    In my 96 tacoma, my over-flow tank level was getting low regularly for about a year. I couldn't locate the problem....Until finally, it got worse enough to notice some droplets on the ground.
    It was my water pump. The gasket material around the water pump was leaking. It had 85K miles on it and due for a change anyway. I changed my water pump, & thermostat and it was all good from there.
    Keep an eye on the overflow. Top off where needed. Crawl underneath and look for any residue of coolant that's been leaking. You probably have a leak somewhere but it's not leaking bad enough to notice yet. A leak could be anywhere in the system.
