Using Crawl Control ended up costing me $1100 in broken parts.
Discussion in '3rd Gen. Tacomas (2016-2023)' started by mmrocek, Feb 7, 2017.
  1. Feb 9, 2017 at 10:12 AM
    #181
    nchastings
    nchastings Well-Known Member
    Noel
    2016 Tacoma TRD Off Road
    Does the TRD-Pro come with a nipple skid!? ;-) I agree that stuff breaks going off road but putting easily breakable items where they are vulnerable and that can result in a single point failure of the entire damn truck is just bad engineering. Sorry. Toyota - hope you see this and correct potential fatal flaw in future gens.
  2. Feb 9, 2017 at 10:14 AM
    #182
    PROseur
    PROseur Well-Known Member
    Pussy
    2012 FJC TTSE/ 2001 Taliban Poverty DCSB/ 2017 6MT PRO / 2018 2.7L SR Utility
    Don't know.
    Us Pro owners can't be bothered to bend down and look what's underneath. We have already bent over enough
    My Pro only goes to mall and office. If I wanted to go off road, I would buy a real truck like a Frontier or Ridgeline
    Paul631, Wade360, nDub and 2 others like this.
  3. Feb 9, 2017 at 11:03 AM
    #183
    Tunngavik
    Tunngavik Well-Known Member
    Alberta, Canada
    2018 TRD Off-Road Access Cab 6 speed manual
    KC-HiLites Fog Lamps, Kicker speaker and tweeter upgrade, USB in center console, Power tailgate lock, Soundproofing, 32" lightbar
    You're kidding right????? :D This is Toyota we are talking about here..... A good portion of the threads in the 3rd Gen forums are carry over problems from the 2nd Gen - for example kazoo windshield noise, squeaky clutch, drive line vibration to name a few.
    Paul631 likes this.
  4. Feb 9, 2017 at 1:25 PM
    #184
    T@co_Pr3runn3r
    08 RC Prerunner SR5
    since the fail part is plastic, why not just print another one on the trusty 3D printer?
  5. Feb 9, 2017 at 4:56 PM
    #185
    Doublemind
    Doublemind Well-Known Member
    Yeah and that's what probably makes owning a 3rd gen frustrating. You have a few carry over issues and more to pile on top of those.
  6. Feb 9, 2017 at 11:40 PM
    #186
    GoGoGadget
    GoGoGadget Well-Known Member
    2017 DCLB OR
    How close is this part to the tires? Isn't the diff fairly centered? Seems that hammering the truck into a pile of sand would drive it up there pretty good, but I am just not envisioning sand being pushed back from the tires at low speed breaking even that plastic part.
  7. Feb 10, 2017 at 6:20 AM
    #187
    Paterico
    Paterico Well-Known Member
    San Antonio, TX
    2017 DCSB TRD OR 4x4
    Just behind the front center jack point. It's centered and you can see it from beneath.
    My guess is that the breather nipple broke off before the issue was observed and that sand/water/moisture worked it's way into the actuator.
    Here's what a 2nd gen actuator looks like inside:
    86a3f972-c740-4734-83b9-5ff4ba0d1d8d_zps_583efa136a5934a60dd05f4e825550b9328e88e8.jpg
    The breather tube port is right by the dude's thumb in this pic. The gear is in close proximity to the breather, as are the contacts which I can only assume are used indicate the position of the shift fork. I can see how sand could have jammed the gear up or blocked the contacts.
  8. Feb 10, 2017 at 8:31 AM
    #188
    PROseur
    Pussy
    So 3rd gen frames will rust too ?! :( :(
  9. Feb 10, 2017 at 9:33 AM
    #189
    nDub
    nDub Kan kun være malet af en gal mand
    Central Sierras - NorCal
    ‘17 TRD OR DCLB and a dǝǝſ
    Lead Free Gasoline
    So OP said he couldn't get out of 4-low, how does this actuator work? What does it disengage or engage? It is similar to old locking style hubs? As in it locks the axles to the wheels so they no longer free spin. I'm just curious and I want to know how the 4wd works. Its not like my older truck which was lock hubs and throw lever into 4-Low.
  10. Feb 10, 2017 at 9:43 AM
    #190
    Paterico
    San Antonio, TX
    The electric motor drives the worm gear set which moves the shift fork left and right. The shift fork moves a sleeve that engages the front wheels.
    98tacoma27 and Hiluxski like this.
  11. Feb 10, 2017 at 9:48 AM
    #191
    smitty99
    smitty99 I also bought a 4Runner
    Scottsdale
    16 TRDORDCSB 4x4 A/T (loaded w/ JBL)
    6112s/5160s & 3-leaf AAL;ubolt flip kit;Superbumps
    Over-engineered...sometimes having all of those extra gadgets doesn't pay off.
    bobrown14 and cruxofthebisquit like this.
  12. Feb 10, 2017 at 9:48 AM
    #192
    splitbolt
    splitbolt Voodoo Witch Doctor
    NW Arkansas
    2016 TRD OFFROAD DCSB MGM
    Jes likes this.
  13. Feb 10, 2017 at 9:50 AM
    #193
    nDub
    Lead Free Gasoline
    Thanks!
  14. Feb 10, 2017 at 9:58 AM
    #194
    gpb
    gpb Well-Known Member
    Atlanta
    2017 White DCSB TRDOR 4x4
    Is that a bottle of lube on the right? Is it for when they hand you the bill?
    :D
    tcjacado and Tunngavik like this.
  15. Feb 10, 2017 at 10:03 AM
    #195
    nDub
    Lead Free Gasoline
    Ok after reviewing the videos. The front axle actuator engages one axle which is similar to other 4wd applications out there. But even engaged it still is just an open diff with spider gears.
    So rather than having to get towed 300 miles home couldn't the OP have just put it in 4 high? Or maybe electronics. In which case removing the front drive line would have worked too. Or would the T-case still been in low range because of electronics? In which case just drive home slowly because that t-case is going to get hot.
  16. Feb 10, 2017 at 10:47 AM
    #196
    jowybyo
    jowybyo Well-Known Member
    Joe
    Baltimore, MD
    '14 MGM DCSB Postrunner 4wd Conversion, Debadged
    You can pull the covers of the actuators and manually spin the gear to disengage the front axle. Then you can do the same to the actuator on the t-case to get it out of 4-low. The computer system likely wouldn't have done anything because it sees that the front actuator is messed up, so the system just shutdown and throws an error.
    This is the reason there is a lot of interest in going to the FJ t-case (stick shift) and wiring the front actuator to a switch independent of the computer. Gives you a lot more control in situations like this. There is also a member on here who developed manual lock hubs for the 2nd gen.
    OnHartung'sRoad likes this.
  17. Feb 10, 2017 at 11:03 AM
    #197
    stevebaz
    stevebaz Well-Known Member
    2016 access cab, TRD offroad 4x4, Quicksand
    I don't understand what keeps the transfer case from shifting out of 4 low if the front axle shaft wont disengage. Do we need to unplug the front actuator electrical and put in a jumper to trick the ECU to think the axle actuator has retracted when it mechanically wont on its own? If I have a failure in the front axle actuator in the field I could care less if the front axle gears spin going down the highway I can fix it when I get home but I sure as hell care if I cant get the transfer case to shift out of 4 low so I don't have a tow out in the field. With a front axle actuator malfunction what sensor or electrical map keeps the transfercase actuator from doing its job and shifting into 4 high or 2WD. If you had a factory service manual you probably could figure this out.
  18. Feb 10, 2017 at 11:35 AM
    #198
    jowybyo
    Joe
    Baltimore, MD
    It's the 4wd ECU. I'm sure you should jump the pins in the connector to make the computer think the actuator is disengaged. I believe there is a timer in the ECU that freaks out if the front axle doesn't disengage in a certain amount of time. And since that is the first step, it halts the whole process.
  19. Feb 10, 2017 at 11:57 AM
    #199
    Tunngavik
    Alberta, Canada
    According to the Vegas bookies I've spoken to, there are 4-2 odds saying that they will. :bananadead:
    :D
    PROseur[QUOTED] likes this.
  20. Feb 10, 2017 at 12:04 PM
    #200
    tgear.shead
    tgear.shead Well-Known Member
    So.... you're sitting there stuck and spinning your wheels for.... HOW MANY minutes? If it doesn't move pretty much right away, you need to STOP DIGGING IT IN DEEPER and either DIG or PULL it out! If it doesn't move right away, it ISN'T GOING TO.
