Using Crawl Control ended up costing me $1100 in broken parts.
Discussion in '3rd Gen. Tacomas (2016-2023)' started by mmrocek, Feb 7, 2017.
  1. Oct 24, 2020 at 4:04 PM
    #241
    MicComa
    MicComa Well-Known Member
    ADK MTNS, NY
    Cut him some slack, at least he understands my sense of humor. Lol, you both get it and I just like funnin with you guys.
  2. Oct 24, 2020 at 4:16 PM
    #242
    Tripod1404
    Tripod1404 Annihilator tripod
    In my opinion, breather connector broke before OP got stuck in sand while he was playing in sand. When he got stuck, wheels spinning pushed sand into the actuator and when he switched into 4wd low it got jammed and got disabled. So it wasn't so much as "crawl broke my truck", it was "I ripped the connecter while off-roading and sand got into the actuator through the broken line".
    hiPSI likes this.
  3. Oct 24, 2020 at 4:30 PM
    #243
    2000prerunner23
    2000prerunner23 Well-Known Member
    steve
    Sooooo...pre 1995 Toyota pickup was the shit because it had stock manual hubs and manual t-cas shifter?
  4. Oct 24, 2020 at 4:52 PM
    #244
    hiPSI
    hiPSI Laminar Flow
    South Carolina
    2024 Long Tundra
    And they do well on the street and trails. The don't do well when the truck is sumped up to the frame in sand. Might as well be rock as sand is pretty much a solid when it is contained.
  5. Oct 24, 2020 at 4:54 PM
    #245
    hiPSI
    hiPSI Laminar Flow
    South Carolina
    2024 Long Tundra
    And? Never let fact get in the way of a good conversation...
    G8R_Taco and Lt. Dangle like this.
  6. Oct 24, 2020 at 5:18 PM
    #246
    OnHartung'sRoad
    OnHartung'sRoad -So glad I didn't take the other...
    Somewhere in the Mojave Desert...
    2017 Tacoma OR 4x4 (formerly a 1998 SR5 PU, 2002 OR 4x4, 1995 4x4 4Runner, 1985 4x4 Toy PU) ... and RIP’s (rust in pieces) to a Bronco II 4x4 & S10 Blazer 4x4
    Talking about packing stuff under the truck, I was on a slick clay covered road and had to keep momentum to get out, so I was pounding through to make progress. Well hell, my steel plates filled up past the oil pan with clay and when I got home, it was like brownies overfilling a baking pan- they were so heavy I had to just drop them and back the truck out. It left an imprint of the engine and tranny bottom in the clay, too. I didn’t realize the breather tube was encased, but luckily it didn't get yanked off or broken when I dropped the pans.
    G8R_Taco and hiPSI like this.
  7. Oct 25, 2020 at 10:42 AM
    #247
    highteckredneck72
    highteckredneck72 Active Member
    Florida
    2020 TRD OR 2wd white
    stock
    Yup love it here! I have family in hudson NY. If i lived up there 4WD would be a Must!!
  8. Oct 25, 2020 at 12:13 PM
    #248
    Dryfly24
    Dryfly24 He’s a leprechaun. He tells me to burn things.
    George
    NM
    2020 Jeep Gladaitor - Formerly 2019 Tacoma OR SB
    I actually agree with both of you to an extent.
    If you do dumb shit with your truck and push it beyond its design limits, expect to be writing a check when things go south.
    On the other hand, you can’t market a truck as the second coming in off road capability, then wash your hands of all responsibility when something that shouldn’t break does, just because someone took it off pavement.
    Common sense. It goes both ways. . .
  9. Oct 25, 2020 at 1:06 PM
    #249
    hiPSI
    hiPSI Laminar Flow
    South Carolina
    2024 Long Tundra
    Except you can market shit to do things it shouldn't do.
    Pay attention to commercials for pretty much everything... toys, vehicles, flex seal and flex tape lol. This has been a marketing ploy since the Crusades.
    Taking something "off road" is almost undefinable. A nice two track level path with no rocks or mud is off road. So is Rubicon trail. So is the Sahara Desert. So is the grass parking lot at a kids soccer game.
    So when Toyota, or Jeep or anyone else advertises "off road" it could mean any of the above.
    Where the gray area is is what they "show" the vehicles doing. High speed desert, rock crawling etc does not mean you SHOULD do it, only, in certain situations like professional drivers, spotters or additional mods it COULD do it. When you buy the truck common sense should prevail and you should only do what you can afford... that's you, not Toyota.
    What's the difference between what this OP did, balls deep stuck in wet sand, or sliding into a rock wall on a trail? The answer is no difference... you put the vehicle in that position, not Toyota, so you are responsible.
    It's a harsh and sometimes expensive life lesson that very seldom happens to older people because they learned that lesson years ago.
    My Tundra has the Off Road package. Do I think it added any capability from a stock Tundra? Um, no. I got some shocks, sway bar and stickers.
    Don't fall for the hype lol.
    G8R_Taco likes this.
  10. Oct 25, 2020 at 1:14 PM
    #250
    Manwithoutaplan
    ID
    Got to pay to play!
    hiPSI likes this.
  11. Oct 25, 2020 at 1:57 PM
    #251
    Dryfly24
    George
    NM
    And again, it goes both ways. They can’t then turn around and void the warranty on something just because you weren’t on pavement when it happened, when they themselves slapped an “Off-Road” decal and name on the truck and marketed it as such.
    kind of like saying, I’m gonna sell you this dishwasher, but if you put a plate in it you void the warranty.
    hiPSI[QUOTED] likes this.
  12. Oct 25, 2020 at 3:38 PM
    #252
    hiPSI
    hiPSI Laminar Flow
    South Carolina
    2024 Long Tundra
    I agree with you, but in the OP's case it failed from impact.
    Using your example, let's say your dishwasher had a key component mounted where your silverware goes and was unguarded. It will wash dishes all day long, but if you F up and hit the component with a knife then no more dishwashing.
    Could Toyota or Maytag do a better job of design or guarding? Yep, but the operator needs to know what's going on too instead of blindly believing a commercial for going offroad or washing dishes. ;)
    Dryfly24[QUOTED] likes this.
  13. Oct 26, 2020 at 11:15 AM
    #253
    Dryfly24
    George
    NM
    I was going to use the example of putting some jeans and a couple polo shirts in it to void the warranty but yours is even better.
  14. Oct 26, 2020 at 11:28 AM
    #254
    You Suck I Suck More
    You Suck I Suck More Well-Known Member
    Meatloaf
    North Florida
    2017 Super White DCSB TRD OR
    Your parents' favorite Airman
    This. OP broke his truck thanks to vacuum forces in wet sand. That's like blaming a 20000lbs load for breaking your truck because your truck has a hitch so it should be able to tow
    Bcjammerx likes this.
