Using Crawl Control ended up costing me $1100 in broken parts.
Discussion in '3rd Gen. Tacomas (2016-2023)' started by mmrocek, Feb 7, 2017.
  1. Feb 7, 2017 at 10:36 AM
    #81
    swimmer
    swimmer Well-Known Member
    Tucson
    2016 TRDORAC4WD
    Yea. Sorry for the OP but totally inaccurate thread title.
    Herniator and c4lvinnn like this.
  2. Feb 7, 2017 at 10:37 AM
    #82
    c4lvinnn
    c4lvinnn Well-Known Member
    '17 TRD Off Road DCSB
    Yep, correlation does not imply causation.
  3. Feb 7, 2017 at 10:38 AM
    #83
    pjensen641
    pjensen641 Well-Known Member
    Boone, IA
    '17 MGM ACLB Sport Manual
    One more reason for a manual lever with a good old metal linkage to the Tcase and FWD actuator. Most that would have happened would have been a bent linkage. Easy to trail repair. I hate electronic actuators.
  4. Feb 7, 2017 at 10:43 AM
    #84
    stevebaz
    stevebaz Well-Known Member
    2016 access cab, TRD offroad 4x4, Quicksand
    So sand and water got in to the axle disconnect and gummed up the works? is this what caused the truck to not shift out of 4wd? Is this actuator is still electrically controlled? If this is the same as the one for the cruiser in post 75 I don't understand on how breaking the vent line disabled the truck.
  5. Feb 7, 2017 at 10:48 AM
    #85
    Jpuch
    Jpuch Active Member
    2017 Tacoma TRD OR
    None yet
    Its just my opinion. One of the reasons I got that option was because of the video showing it getting out of the very same situation that broke this truck? If I use my CRAWL option for what it was intended for - Stuck up to the frame (maybe little past the frame??) in sand and then the stupid little nipple breaks off due to sand packed around it? Sounds like a bad design. If it looked like it was smashed off on some boulders, Id say that was abuse. I think the dealer could have cut a little slack in this instance. I went to my dealer after I ripped CV boot getting stuck with my old toyota. They replaced it no questions asked. The dealer even said "looks like a rock or stick stabbed it."
    0210, Camel89, vuTron and 1 other person like this.
  6. Feb 7, 2017 at 10:59 AM
    #86
    gpb
    gpb Well-Known Member
    Atlanta
    2017 White DCSB TRDOR 4x4
    Fixed. :bananadance::boink:
  7. Feb 7, 2017 at 11:00 AM
    #87
    OzzytheJack
    OzzytheJack Member
    Bill
    Connecticut
    2013 Double Cab TRD Off Road
    Working on it.
    Sorry to hear about your issue. I carelessly busted the same part when changing my front differential. The hose is only a breather for the actuator and I managed to fix it my self with brass nipple and a little epoxy putty. If/when the actuator fails, you can actually remove it and manually disengage things. You may need to roll the truck a little and you may also need some fluid but it should work. The same goes for the rear locker.
    vuTron likes this.
  8. Feb 7, 2017 at 11:03 AM
    #88
    walterj
    walterj Well-Known Member
    PA, USA
    Sexy Black '17 Taco 4x4 DCSB TRD Off-Road 6MT
    You should have taken it to a car wash, then to the dealer and told them only that "it's stuck in 4LO".
    Telling a dealer "I was buried to the diffs in sand on a beach just like in the video with the DO NOT ATTEMPT disclaimer!" was your mistake.
    Camel89 and vuTron like this.
  9. Feb 7, 2017 at 11:06 AM
    #89
    c4lvinnn
    He'll be AFMurse2014 #2
  10. Feb 7, 2017 at 11:09 AM
    #90
    Paterico
    Paterico Well-Known Member
    San Antonio, TX
    2017 DCSB TRD OR 4x4
    Just went out and looked at my truck and the actuator seems pretty well hidden underneath the skid plate. I'm trying to understand how
    Might have already been said but I wonder if that skid plate design, with the opening up front, contributed to the sand being forced into and above the skid plate during forward acceleration.
  11. Feb 7, 2017 at 11:11 AM
    #91
    Friggin Fuego
    Friggin Fuego Well-Known Member
    2004 Toyota Land Cruiser, 2007 Toyota FJ Cruiser 6MT 4x4, 1988 Toyota Hilux SSR Diesel 5MT 4x4
  12. Feb 7, 2017 at 11:12 AM
    #92
    Hiluxski
    Hiluxski Well-Known Member
    Ventura California
    2022 Lime green TRD Pro
    Your manual truck has the same electronic part that broke.
  13. Feb 7, 2017 at 11:16 AM
    #93
    c4lvinnn
    Are you that dense? He literally just told you. What do you mean "and?"
    GPsevinSixx likes this.
  14. Feb 7, 2017 at 11:16 AM
    #94
    T@co_Pr3runn3r
    08 RC Prerunner SR5
    While we're all playin SHOULDA..................Toyota SHOULDA put their plastic rescue nonsense feature up out of the way and/or guarded it from getting fucked up by the shit it is supposed to be getting you out of and advertised as such. Stupid design fail. Stupid product backing fail. Lame excuse making fail for not just taking care of it via platinum warranty. Fuck the micro disclaimer wherever it was in the commercials showing people doing what sells the high dollar shit to begin with. This is exactly the lame practices that enabled Toyota to gain a foothold in our automarket to begin with so I guess they're moving to take that BS to a new level. Bravo. Impressive. Confidence inspiring. Keeping my nanny gadget free model for sure and Toyota can keep their gadget handicapped nanny crap.
  15. Feb 7, 2017 at 11:19 AM
    #95
    Paterico
    San Antonio, TX
    It's pretty well hidden underneath the skid plate.
    Why should any warranty provider pay out for something that was caused by abuse/misuse?
    OP has an aftermarket skid plate that has four big holes in the front
    Joe23 likes this.
  16. Feb 7, 2017 at 11:21 AM
    #96
    c4lvinnn
    What? You literally said one of the reasons you went with a manual is to get rid of electronic gadgets out of your system. He replied with "your manual truck has the same electronic gadget", thus defeating the whole "purpose" of you getting a manual truck.
  17. Feb 7, 2017 at 11:24 AM
    #97
    Snowy
    Snowy Is neither here nor there
    Connor
    Winnebago, IL
    3 linked 98 Xtra cab
    Stock-ish
    Let me get you something...
    Spraynard and bobrown14 like this.
  18. Feb 7, 2017 at 11:28 AM
    #98
    Hank Heel
    Hank Heel Well-Known Member
    WA
    Haha aren't we the problem solvers :anonymous:
    gpb[QUOTED] likes this.
  19. Feb 7, 2017 at 11:28 AM
    #99
    T@co_Pr3runn3r
    08 RC Prerunner SR5
    OH, then it's all the user's fault for doing something the truck was supposedly designed for............good catch
  20. Feb 7, 2017 at 11:29 AM
    #100
    c4lvinnn
    bobrown14 and GPsevinSixx like this.
