Using Crawl Control ended up costing me $1100 in broken parts.
Discussion in '3rd Gen. Tacomas (2016-2023)' started by mmrocek, Feb 7, 2017.
  1. Feb 7, 2017 at 5:00 PM
    #161
    ElGatoLoco
    ElGatoLoco Well-Known Member
    '17 DCSB TRD Sport
    Sorry about your luck but appreciate the heads up in case I'm in a similar situation
  2. Feb 7, 2017 at 6:11 PM
    #162
    Paterico
    Paterico Well-Known Member
    San Antonio, TX
    2017 DCSB TRD OR 4x4
    This has me perplexed. Originally I assumed that the sand was pushed through those holes in his skid plate but that nipple on the actuator is well behind the openings...by at least a foot. Unless sand was packed in there like a brick, I can't see how that nipple broke off.
    And whoever stated it before is correct and I was wrong. That nipple is just a vent. It runs up to a vented cap just below and to the side of the battery. The actuator is fully electric.
    Seems like the actuator should have worked even w the nipple broken off.
    Now I'm seriously wondering what we're missing from the story.
    Did the dealer give him a line of BS or was there much more involved than just getting stuck and using CRAWL?
    ecoterragaia likes this.
  3. Feb 7, 2017 at 6:13 PM
    #163
    TXTaco13
    TXTaco13 Taco/T4R Enthusiast
    Dallas, Texas
    4TH GEN V8 4X4 T4R
    '83 CJ7 '19 MT 07
  4. Feb 7, 2017 at 6:15 PM
    #164
    Tunngavik
    Tunngavik Well-Known Member
    Alberta, Canada
    2018 TRD Off-Road Access Cab 6 speed manual
    KC-HiLites Fog Lamps, Kicker speaker and tweeter upgrade, USB in center console, Power tailgate lock, Soundproofing, 32" lightbar
    I think I found the answer - took a bit of digging. https://www.tacomaworld.com/threads...me-1100-in-broken-parts.474221/#post-14345395
    Sean73T likes this.
  5. Feb 7, 2017 at 6:45 PM
    #165
    89hatcher
    89hatcher Well-Known Member
    wonder if you can drill and tap that plastic house in and tap a barb fitting in its place? a little more stronger than that small plastic nipple
    airborndad and monsterkx2fiddy like this.
  6. Feb 8, 2017 at 9:24 AM
    #166
    PROseur
    PROseur Well-Known Member
    Pussy
    2012 FJC TTSE/ 2001 Taliban Poverty DCSB/ 2017 6MT PRO / 2018 2.7L SR Utility
    You can PM the owner/OP :)
  7. Feb 8, 2017 at 9:29 AM
    #167
    JoeCOVA
    JoeCOVA Well-Known Member
    Joe
    Colorado Springs
    crawl control is nothing more than a low speed cruise control, not sure why people think its a get out of jail free card.
  8. Feb 8, 2017 at 9:31 AM
    #168
    PROseur
    Pussy
    because the you tube videos said so :)
  9. Feb 9, 2017 at 6:12 AM
    #169
    Kennedyusmc
    Kennedyusmc Well-Known Member
    Christopher
    2017 Cement Pro
    Still waiting for it
    Business opportunity here for someone to make a skid/protection plate for this.
  10. Feb 9, 2017 at 6:16 AM
    #170
    Greg Hall
    Greg Hall Well-Known Member
    Greg
    Pittsburgh PA
    2016 Tacoma OR
    That's total BS man. From what your describing, I'd contact corporate and explain what happened. They would probably make things right.
    Modesto Tacoma likes this.
  11. Feb 9, 2017 at 7:08 AM
    #171
    TRDinOhio
    TRDinOhio Well-Known Member
    Andrew
    Lima
    16 Trd Pro 4Runner
    No more Turd-gen :)
    So let me get this straight....
    Your off-road truck broke by being used off of the road? I wouldn't consider playing in the sand "severe off roading" personally.
    As others have said Toyota themselves show multiple videos of crawl mode pulling you out of the sand.
    I guess another fan boy argument is out the window? Normally if you point out a problem with the Turd-gen all the fan boys are quick to mention that "its a truck" or " its for off-roading" but apparently its not. At least not in the real world anyways.
    I get that this MAY be a special situation or a fluke but even the die hard fan boys should look in the mirror and admit its a shitty design. Enjoy your truck that suddenly isn't much better off road that a ridgeline ROFL.
  12. Feb 9, 2017 at 7:20 AM
    #172
    TACOVRD
    TACOVRD I Identify As A Prius
    TW Addict
    AZ/WA
    2019 T4R ORP - Formerly 2013 DCSB OR Spruce Mica
    Workin' on it....
    Gotta pay to play sometimes. If you do take your truck offroad, occasionally shit breaks. That said, I totally agree that the marketing may be a little disingenuous if they are promoting multi terrain select and crawl control as key features of the truck and then expecting buyers to not use it as intended. Hope the fab guys can come up with something for this situation.
  13. Feb 9, 2017 at 7:27 AM
    #173
    gpb
    gpb Well-Known Member
    Atlanta
    2017 White DCSB TRDOR 4x4
    ah, gotta love TW. One guy has a problem and suddenly its an existential crisis.
  14. Feb 9, 2017 at 7:29 AM
    #174
    Kennedyusmc
    Christopher
    2017 Cement Pro
    Exactly.
    Shit breaks offroad sometimes.
  15. Feb 9, 2017 at 7:29 AM
    #175
    07amocat
    07amocat Well-Known Member
    Colorado
    2007 Silver Tacoma TRD Off Road
    Its no different then the Corvette. GM shows the Corvette on a race track in its commercials, but if you break it racing, they're not going to cover it under warranty. It's abuse. Yes it has the cool crawl control feature, but you still have to use your head and realize that things could break if you bury your truck to the frame rails in sand.
    If a module had failed I'm sure the dealer would have warrantied it, but since it was broken from outside forces, its no longer a warranty issue.
    Herniator and TACOVRD[QUOTED] like this.
  16. Feb 9, 2017 at 7:30 AM
    #176
    JoeyDel
    JoeyDel Well-Known Member
    Joe
    South Jersey
    2003 Off Road AC and '16 AC Sport Silver Sky Metallic
    If his exhaust got damaged instead would this even be a discussion? See what I did there?
    Herniator likes this.
  17. Feb 9, 2017 at 7:31 AM
    #177
    jowybyo
    jowybyo Well-Known Member
    Joe
    Baltimore, MD
    '14 MGM DCSB Postrunner 4wd Conversion, Debadged
    I'm not sure if this has been pointed out, but that line is not a vacuum line. It's a breather hose. The actuator is electronic. There is a small electric motor in there (about the size of an RC motor). Breaking that hose of would be nothing but let sand and water inside the cover that might foul up the motor. You can buy a new actuator on ebay for about $200 and it's an easy install.
  18. Feb 9, 2017 at 7:35 AM
    #178
    TACOVRD
    TW Addict
    AZ/WA
    Workin' on it....
    Yep I agree.
  19. Feb 9, 2017 at 7:44 AM
    #179
    PROseur
    Pussy
    Ford, Chevy, Ridgeline all break
    Tacomas never break ;)
  20. Feb 9, 2017 at 8:14 AM
    #180
    AdventureKid
    AdventureKid Let's Go Places
    Jake
    Oceanside, CA
    17' DCSB TRD OR 4x4 6MT
    Camper Shell
    Sounds like operator error. That vacuum unit was damn dirty. Obviously more to the story.
    Sand is easy to navigate in. Just drop tire pressure, and give it gas.
