Using high heat paint on an exhaust pipe an option?
Discussion in '1st Gen. Tacomas (1995-2004)' started by Glenn54, Apr 19, 2014.
  1. Apr 19, 2014 at 11:39 AM
    Glenn54
    Glenn54 [OP] Active Member
    Glenn
    Upper Marlboro, Maryland
    SR5 4X4
    (2001 Tacoma SR5, 4X4 2.7 100K miles) So I'm looking to replace my stock exhaust muffler pipe assy. I want to stay OEM, but did notice that my stock system did start to rust on the exterior within a month after purchasing my truck new back in 2001. I'm really not a fan of going aftermarket changes, so I was considering ordering an OEM muffler pipe assy and coating it with high heat paint before installing to prevent exterior rust. Any thoughts on how this might work out down the road?
  2. Apr 19, 2014 at 2:08 PM
    presto
    presto Well-Known Member
    Topher
    san francisco
    2000 T4R 4x4
    Fully armored on 33’s
    One thing you might consider is upgrading the oem to TRD because I think the TRD oem exhaust system was stainless steel? Not 100% sure tho. Might be pricey but best deal is in camel back toyota parts. I am curious of the high heat paint as well. I don't think an engine block or brake calipers get as hot as an exhaust pipe though..
  3. Apr 19, 2014 at 2:25 PM
    toyodajeff
    toyodajeff Well-Known Member
    jeff
    06 reg cab sr5
    I think it will all burn off close to the motor and cats. The high heat paint would last longer though, but I would just get stainless.
  4. Apr 19, 2014 at 2:41 PM
    smmarine
    smmarine Well-Known Member
    Melbourne FL
    2020 Kawasaki Vulcan S ABS
    I sell black grill paint at my Ace Harware. It's rated at like 1000 degrees
  5. Apr 19, 2014 at 5:36 PM
    TacoSkeet
    TacoSkeet 'MERICA
    Steven
    Memphis, TN
    03 DC Tacoma
    I sanded down the rust and cleaned my tailpipe and then painted it with high heat rustoleum engine paint. Even the very tip of the pipe is back to that rusty color..
  6. Apr 19, 2014 at 9:52 PM
    Madjik_Man
    Colorado Front Range
    I prepped the hell out of my tail pipe then used high heat paint.
    Looked awesome at first but after two seasons it turned right back to faded rust.
    Ended up cutting it off.
  7. Apr 20, 2014 at 8:51 AM
    Glenn54
    Glenn
    SR5 4X4
    Thanks for all the input. Is there anything aftermarket stainless steel system without the extra sound? Not a fan of anything race sounding in my 2.7 ltr.
  8. Apr 20, 2014 at 9:00 AM
    wildjerseyfirefighter
    wildjerseyfirefighter I sell fishing and fishing accessories
    Joe
    NJ
    05 Tacoma TRD Sport
    stock, for now
    anything will rust. Just how long you can prevent it.
    I had an aero turbine welded on a couple of weeks ago. I painted the fresh welds with BBQ paint (black) and called it a day.
  9. May 7, 2014 at 11:52 PM
    o0oSHADOWo0o
    o0oSHADOWo0o Just lurking in the darkness
    Shadow
    Va Beach
    2012 Double Cab Short Bed 4x4 TRD Sport
    Just a few LEDs...
    Even "stainless" steel rusts. Especially the lower grades. I bought my truck two years ago and noticed that the exhaust mounts and the flanges to the cats were rusting. So, a couple of months ago I sanded everything down and used Rustoleum High Temp Paint (1200 F) to paint everything from the tailpipe up as far as I could reach with a nice flat black. I plan on applying more coats soon.
    I'm trying to be proactive with rust because I had a 2001 Dodge Dakota that I drove for 10+ years that had exhaust and body rust.
  10. May 8, 2014 at 12:15 AM
    zboy
    zboy Well-Known Member
    Oahu808
    12 TRD OR
    Did mine 2 yrs ago with rust-oleum High Heat BBQ paint holding up well no rust
  11. May 8, 2014 at 12:18 AM
    DylansBase
    DylansBase Well-Known Member
    Dylan
    Murfreesboro TN
    2007 DCSB Taco TRD Off-road
    Bilstein 5100 w/OME 886 All pro expo leafs w/icon 2.0 Relentless Fab plate bumper BFG KO2
    I used high heat BBQ paint on mine and it held up for about 3 months. After that all the paint was burnt off
  12. May 8, 2014 at 7:19 AM
    RAT PRODUCTS
    RAT PRODUCTS Well-Known Member
    Farmington, MN
    Cummins Coal Roller
    Smokin with a smarty.
    VHT makes header primer and paint capable of 2000 degrees. If you want it to last, you need to rough up the pipe with 80 grit, then prime, cure the primer, then paint, then cure the paint. Do that and it will last a long time.
  13. May 8, 2014 at 9:15 AM
    Glenn54
    Glenn
    SR5 4X4
    Just to update since I first started this thread. I finally decided to just go with the stock OEM system witih no paint treatment.
