Using high mounted bed light as a chase light?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by AusRunner, Feb 26, 2023.
  1. Feb 26, 2023 at 8:17 PM
    AusRunner
    AusRunner [OP] Well-Known Member
    Las Vegas, NV
    2021 TRD Off Road 4X4 DCSB - Cement
    Just wondering if anyone swapped their high mounted bed light LEDs with something brighter or even a different color or if it is even possible. Would be kind of nice to be able to use this as a kind of chase light on the trails.
  2. Feb 26, 2023 at 8:18 PM
    Chew
    Chew Not so well known user
    Chewy
    Midwest
    19 TRD OR
    Amazon dog poo bed mat mod
    Are you talking third brake light over the cab?
    I think the double cab models are LEDs and don’t have “sockets” like old school bulbs, you can easily swap.
  3. Feb 26, 2023 at 9:07 PM
    soundman98
    soundman98 Well-Known Member
    NW Indiana
    '18 Taco Sport, '14 Ranger
    there aren't any swaps as the entire housing is an integrated assembly.
    but meso makes a replacement using kc lights rings, morimoto makes an alternative, as well as an Amazon model. the meso/kc light modules are going to be the brightest pre-built option.
    outside of that, you're into full-custom territory with a chase lightbar or similar.
  4. Feb 26, 2023 at 9:53 PM
    $yoda$
    $yoda$ Well-Known Member
    Tom
    2007 Tacoma 4.0
    2.5 inch lift, 285/75r16s, upgraded stereo system, Magnuson mp90 supercharger system.
    I actually saw a thread the other day where someone was selling one that could take some super bright off road pod or bulb from dd or one of the popular brands I can’t remember. I remember him being very clear it was “for off road use only”. I would probably tuck the factory wires and make my own circuit and switch for that cause I definitely wouldn’t want it on every time I hit the brakes. It wasn’t pre built though you had to get the lights for it yourself. Also not sure if he can or would make more.
  5. Feb 27, 2023 at 7:04 AM
    eurowner
    eurowner Duke Sky
    Scoty
