Using motor, trans and transfercase from 2013 in a 2007?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Lawaiathan, Mar 30, 2018.
  1. Mar 30, 2018 at 5:59 PM
    west467
    west467 Well-Known Member
    Two Black Tacos..03 and 09
    Will he even need to swap the valve cover? Looks like removing the air injection valves,exhaust header, and associated plumbing, may be all that's needed. Not sure but I think the air injection valves mount to the valve cover, and if no openings are left , I would leave the existing valve cover on if I could. ???
  2. Mar 30, 2018 at 6:05 PM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    But cleaner engine bay with tidier valve cover broski!
    Jcyr, JayRolla and west467[QUOTED] like this.
  3. Mar 31, 2018 at 2:45 AM
    Lawaiathan
    Lawaiathan [OP] Member
    2007 tacoma 4x4
    6 inchProcomp lift, icon resivore shocks and dampeners all around.
    Ok ill ask him .
  4. Mar 31, 2018 at 2:48 AM
    Lawaiathan
    2007 tacoma 4x4
    Thanks alot guys.please keep the tips and advise rolling in.anythimg helps
    DoorDing likes this.
  5. Mar 31, 2018 at 2:53 AM
    07 sport 4x4
    07 sport 4x4 Well-Known Member
    Blake
    Southeast
    2017 Duramax
    So... what happened to the 07 engine?
    gearcruncher likes this.
  6. Apr 7, 2018 at 6:08 PM
    Lawaiathan
    2007 tacoma 4x4
    I ran this without oil for too long.it never overheated that i know of because i only drive a 15 minute commute.
  7. Apr 7, 2018 at 7:38 PM
    07 sport 4x4
    Blake
    Southeast
    2017 Duramax
    Was it burning oil? Is it possible that the oil pump failed?
  8. Apr 9, 2018 at 11:56 PM
    Lawaiathan
    2007 tacoma 4x4
    I really dont know what happend.but as an update i took my truck to a friend who is going to install the 2013 motor.ill post pics next weekend.is the oil pump failure a common problem?
    07 sport 4x4 likes this.
  9. Apr 10, 2018 at 3:38 AM
    07 sport 4x4
    Blake
    Southeast
    2017 Duramax
    Not common, but I’ve heard of it happening on the 1gr-fe a few times.
  10. Apr 10, 2018 at 5:18 AM
    gearcruncher
    Canadain bumper technician
    Are you installing a new clutch and release bearing assembly while you are in there ? Are you going to be machining the flywheel ?
    Jcyr likes this.
  11. Apr 10, 2018 at 5:33 AM
    BEE-ROCK
    BEE-ROCK Well-Known Member
    Brock
    Dallas, TX
    2013 Tacoma TRD Sport
    TRD Pro Grille, TRD Pro Headlights, Bilstein 5100's and 5125’s.
    -Use the wiring harness in the 2007.
    -Remove Valves for the AIP and the exhaust header off the 2013 engine. (The thing you are pointing at..)
    -Swap over exhaust header from 2007 engine to 'new' engine.
    -OPTIONAL, swap over left side engine valve cover from 2007 engine to 2013 engine. The valve covers are slightly different. The cover on the 2013 engine has mounting points for the AIP valves.
    ALSO:
    - I would remove spark plugs and crank engine over. Probably should replace spark plugs while you're in there.
    - Replace valve cover gaskets while 'new' engine is not in truck..
    - Change oil before starting 'new' engine.
    Torspd likes this.
  12. Apr 19, 2018 at 9:46 PM
    Lawaiathan
    2007 tacoma 4x4
    Sorry for being so late to respond., bit my truck is up and running just fine.the thimg i was pointing at on the 2013 motor was removed, and the additional plumbing going into the blck was cut off and welded shut.used the 2007 wiring harness and everything seems to be running just fine.thanks for all the advice and help guys.
    Torspd, Jcyr, BEE-ROCK and 1 other person like this.
  13. Apr 20, 2018 at 5:19 AM
    BEE-ROCK
    Brock
    Dallas, TX
    Glad to hear!
    Jcyr likes this.
  14. Apr 20, 2018 at 5:37 AM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    So then you should have a bunch of engine parts for sale, yes? Like valve covers amd what not? ;)
    DoorDing and BEE-ROCK like this.
