Using simple green to clean an engine
Discussion in 'Detailing' started by Khaos, Jul 15, 2012.
  1. Jul 15, 2012 at 2:18 PM
    Khaos
    Khaos [OP] Big Member
    Bryant
    Jacksonville, Florida
    2011 DC TRD SPORT Prerunner
    3” spacer lift, 285/75/17 KO2, Spidertrax 1.25” spacers
    I've read this is the best/easiest way to clean my engine. It's covered in water spots and sand and just general garbage from years of trail riding and being driven. I dont need it to look like it just came off the showroom floor, but I do want to get my engine atleast looking decent.
    So, cool engine, engine off, spray on simple green (do you dilute it? I've read some do it either way), let sit for a moment, and then spray off. That's all there is too it?
  2. Jul 15, 2012 at 3:30 PM
    boatswain
    boatswain Well-Known Member
    carl
    palmerton,PA.
    2018 Tacoma TRD Sport access cab, magnetic grey metallic.
    cool, engine off, and spray on is basic.
    I don't use simple green, although it may be better than what I've been using for years.
    I've kept my engine compartments clean for "MANY" years using- GUNK ENGINE BRITE origional HD engine degreaser. (not the foam).
    Let it sit a little, and rinse down. If very dirty, may have to do more than once.
    just giving another option!
    there are a lot of products out there that cut grease and grime, but this product seems to work well enough.
  3. Jul 15, 2012 at 3:40 PM
    bjmoose
    bjmoose Bullwinkle J. Moose
    San Jose CA
    '11 Std Cab 4x4 5sp
    No!
    Google simple green aluminum.
    Even their FAQ recommends against this, but they do make some other products that are OK for the purpose.
  4. Jul 15, 2012 at 3:40 PM
    Hunter500ky
    Hunter500ky Well-Known Member
    E-Town Ky
    06 Tacoma 4x4 SR5
    Weathertech Mats, Toolbox, 6k HID fogs, Hardwire Escort 8500 x50,
  5. Jul 15, 2012 at 3:41 PM
    Khaos
    Bryant
    I have read about the Gunk before, but we don't sell it at work yet we have simple green, so I got what I could with my discount. lol. I had been told and read in several places that Simple Green was good for this.
    I did the body a few mins ago but ran out of change/singles. Using the spray at the carwash on high is great on the leafs and frame area. Before hand my leafs would squeak for anything, even shutting a door, thats gone now. Tomorrow I'll do the engine, interior, and bed. Tuesday I plan on washing again and doing a wax+claybar, I've got a lot of new trail pinstripes, a coat of wax will help prevent that.
  6. Jul 15, 2012 at 3:43 PM
    Maysville06
    Maysville06 Well-Known Member
    Bruce
    Georgia
    Pre-runner SR5 Long bed
    K&N Cold Air Intake, Flowmaster Exhaust,20% window tint all around, Weather tec rear floor mats, Blacked out badges,Mudflaps removed,JDM black aftermarket headlights,black grille, running boards removed,Nightshaded tail lights,TRD Sport suspension,3in leveling kit in front,2in blocks in the rear,blacked out rims, Reese class III receiver hitch
    Simple green is a fantastic all purpose cleaner.... use it alot with good results
  7. Jul 15, 2012 at 4:03 PM
    Khaos
    Bryant
    I've read that having it on for an extended period of time can cause a problem, however I a minute or so is supposedly safe?
    Everything I read is so contradictory on this.
  8. Jul 15, 2012 at 4:45 PM
    Rich91710
    Rich91710 Well-Known Member
    Rich
    Los Angeles
    08 Base
    Just use it on a cold engine, use a diluted mixture... 50:50 or more diluted, and don't allow it to dry on the aluminum.
    It won't DAMAGE the aluminum, it can cause cosmetic spotting, but scuba shops use it to clean aluminum and steel tanks to prepare them for use with oxygen blends from 40% to 100%.
  9. Jul 15, 2012 at 4:50 PM
    PAlittlematty
    PAlittlematty "the soulless ginger"
    Beech Creek, PA
    I miss my taco
    OME Lift, 885 Coils, 13MM Top Spacer, Dakar Leafs, DSM UCAs, Homeroshi Flush Mount Grille, WeatherTech Digifit Mats, Bestop Super Top, Toyota Bed Extender, Clevice Receiver 1990 SR5 3.slow SAS 5” Leafs, high pinion diff, 37” PBRs, MC rear, AP front bumpers, 5.29s, locked
    I use simple green to clean my truck and motorcycle. Spray them with the hose first then spray simple green on. Let it sit a couple minutes and rinse it off. I've never had an issue. Spray nine works great too
  10. Jul 15, 2012 at 5:35 PM
    Khaos
    Bryant
    That was my next question was how much to dilute it.
    I figured spraying it down and immediately beginning to hose off in the order in which I sprayed the engine down would give it enough time to clean off, but not enough to cause any issues. Light pressure on the water?
  11. Jul 15, 2012 at 5:38 PM
    Rich91710
    Rich
    Los Angeles
    08 Base
    Pretty much.
    Wet the engine down, spray, rinse. Might take a little scrubbing, you've got a lot of dirt that just a spray and rinse won't clear, but an afternoon you could have that back to showroom condition.
  12. Jul 15, 2012 at 6:30 PM
    bjmoose
    San Jose CA
    '11 Std Cab 4x4 5sp
  13. Jul 15, 2012 at 6:43 PM
    Rich91710
    Rich
    Los Angeles
    08 Base
    Looks just fine as long as it is diluted and rinsed well. Even with the nooks and crannies, rinsing a diluted solution with a hose is going to remove it.
    And the Ph of the SG simply accelerates the normal corrosion process that would happen if you allowed plain water to remain on the surface.
    I'm talking about the inside of the tank... not the outside.
  14. Jul 15, 2012 at 7:07 PM
    BRONSON
    BRONSON Active Member
    Canada
    2009 TRD Sport 4x4 DCLB
    885 w/ 5100's + 1/2" d.s. top plate, EL096R w/ B110's, Whiteline LCA bushings, Energy Suspension poly leaf & shackle bushings, new OEM rear shackles, custom rear brakeline mount & e-brake extensions, LR UCA's, SnugTop cap
    Simple Green Pro HD (purple stuff available at Home Depot) is safe on aluminum. It's the exact same formula as their Boeing spec Extreme Aircraft cleaner, but with some added colorant.
