Using the 400w bed plug as a home generator?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by KVTaco, Nov 25, 2018.
  1. Nov 25, 2018 at 8:28 AM
    #61
    Dirtridercrf250
    Dirtridercrf250 Well-Known Member
    Well technically is on the automatic, read the manual it has more on it. The manual trans worthless for this feature I had to carry the coffee pot to the friends 3G and brew it. Get a group 31deep cycle now I run a refrigerator for 4 days
    stun gun[QUOTED] likes this.
  2. Nov 25, 2018 at 8:28 AM
    #62
    stun gun
    stun gun Well-Known Member
    Aaronski
    Tacomas.
    17 4X4 sr5spd/01 LT sr5spd
    Apologies, but I will not be reading the manual. Thank you very much.
    BlueFalconActual likes this.
  3. Nov 25, 2018 at 8:39 AM
    #63
    Linewalker
    Linewalker Well-Known Member
    Juh Broh Nee
    SE PA
    2017 White SR5 DCLB 4x4
  4. Nov 25, 2018 at 8:49 AM
    #64
    The_Devil
    The_Devil Well-Known Member
    E
    2018 Tacoma TRD Off-Road
    DIY Tonneau, Toolbox, Lift, TRD Wheels, TRD Grill
    Different people have different priorities. For most, a freezer or refrigerator full of food is the priority.
    For this, 2000/2200 watt gen is preferred.
    To run a whole mid size home, approx 5kw.
    Over size by 50% = 7.5kW as someone suggested.
    That peak allows AC etc.
    Solar is a good alternative, except when the power goes out it can be raining and make solar panels less effective.
    shakerhood likes this.
  5. Nov 25, 2018 at 9:02 AM
    #65
    ColoradoTJ
    ColoradoTJ Retired cat herder Moderator
    Colorado
    3500 Duramax, Roush Mustang, Jeep Crawler
    3rd gen never disappoints.
    Shared this thread.
  6. Nov 25, 2018 at 9:28 AM
    #66
    RangerComa
    RangerComa 58008
    Adam
    Marin, CA
    17 DCLB
    list is growing fast
  7. Nov 25, 2018 at 9:41 AM
    #67
    Elkyri
    Elkyri Living on the Raggedy Edge of the 'Verse
    2017 DCSB TRD-OR
    The issue is that your engine is not providing the power via a full generator kicking out 120v but is coming from the system that charges your battery. There is a mini-inverter converting the 12v dc to 120v ac.
    Power works like this: volts * amps = watts... or watts / volts = amps.... so 400 watts / 120 volts = 3.3 amps. Most appliances that "run" have two wattage ratings -- one to get them started (heavy draw) and one for continuous running (lower draw). You're going to be able to use that plug to keep the batteries for your battery operated tools charged, to run a small cooler, to run some lights... that sort of thing.
    KVTaco[QUOTED][OP] likes this.
  8. Nov 25, 2018 at 9:46 AM
    #68
    Elkyri
    2017 DCSB TRD-OR
    The engine has to be running. If it is in gear the max output is 100w. If in P or N the max output is 400w.
  9. Nov 25, 2018 at 10:07 AM
    #69
    tcjacado
    tcjacado Well-Known Member
  10. Nov 25, 2018 at 10:25 AM
    #70
    BlueFalconActual
    BlueFalconActual Some dude
    2017 DCSB TRD OR 4x4 MT
    Joke’s on all of you, I’m homeless so my Taco does power my entire home.
    Side note, is anyone looking for a roommate? I give really good lower back rubs.
  11. Nov 25, 2018 at 10:50 AM
    #71
    DeltaBravo
    DeltaBravo Do you know what nemesis means?
    Waste Management's residential dumpster rental allows you to quickly find the right size dumpster for your project, schedule delivery and pay, all in just a few steps.
    The vehicle commonly referred to as "The War Rig" is a 78 foot 18 wheeler based on a Tatra T815
    I told you guys someone lived under the bridge on the Schuylkill River...
  12. Nov 25, 2018 at 10:52 AM
    #72
    WOTaco
    WOTaco Well-Known Member
    NY near the old capital
    2016 MGM DCSB TRD OR MT
    I've used mine lots of times with the key on/engine off.
  13. Nov 25, 2018 at 11:06 AM
    #73
    Elkyri
    2017 DCSB TRD-OR
    That's interesting. On my truck, the lights on the switch will not come on showing power unless the engine is running. I have not tried just plugging something in to see if power is flowing with the "key" on but engine off and the lights on the switch not illuminated. I took the absence of lights on the switch to indicate no power to the outlet.
  14. Nov 25, 2018 at 11:53 AM
    #74
    tcjacado
    :anonymous: we can make it a double taco
  15. Nov 25, 2018 at 12:05 PM
    #75
    Wsteven
    Wsteven Well-Known Member
    2018 Tacoma TRD Pro
    Working on them
    You can get the Goal Zero one above at Costco for $999 at least the one local to me still not low noth for me to bite into.
  16. Nov 25, 2018 at 12:13 PM
    #76
    WOTaco
    The switch does light up on mine in the key on/engine off position. Manual trans FWIW.
  17. Nov 25, 2018 at 12:17 PM
    #77
    n0rlf
    n0rlf Living the good life
    Easy central Tenn. Bledsoe County
    17 YRS Sport DCSB 2WD. Pretty stock
    I told my wife it would run the shop vac so even with power out at the house she could clean!
    I remember some of that week.
  18. Nov 25, 2018 at 12:56 PM
    #78
    BlueFalconActual
    Close enough?
    tcjacado[QUOTED] likes this.
  19. Nov 25, 2018 at 1:02 PM
    #79
    n0rlf
    Thats just wrong!
    Needs chilli
  20. Nov 25, 2018 at 1:03 PM
    #80
    tcjacado
    That's perfect dry with just a little bit of lube:anonymous:
