Using the 4x6 grooves in the bed
Discussion in '2nd Gen. Tacomas (2005-2015)' started by dougmays, Feb 11, 2009.
  1. Feb 11, 2009 at 10:03 AM
    dougmays
    dougmays [OP] Well-Known Member
    Doug
    Gainesville, FL
    2007 SR5 Tacoma 4WD/Tow Pkg Black
    Westin Bull Bar, Firestone Destination AT 255/70/16
    so i know that there are 2 grooves in my taco's bed for putting 4x6's in and making a raised bed. I've never tried this but a friend of mine is having a airplane engine delivered and neither of our trucks have enough width for the crate between the wheel wells. So i was thinking about trying this out.
    Has anyone done this? without much weight? was it stable? is that composite bed able to handle heavier weight?
    The crate all-in-all is only supposed to weight 350lbs...so its not that heavy. Anyone have pictures or stories?
    thanks
  2. Feb 11, 2009 at 10:21 AM
    jdkeller
    jdkeller How many words can be fit in this s
    Jonathan
    Inland Empire, Ca
    2008 Tacoma Prerunner TRD Offroad
    Dome light LED, 6000k HID Headlights and fogs, Grillcraft black mesh, rear 5100's, Total Chaos UCA's, 285/75/16 BFG KM2's, Spidertrax spacers, Blacked out emblems, cb,kenwood tm270 ham radio, All Pro 3" leaf pack, Fox 2.0 coilovers, Revenge Fab Sliders, u bolt flip kit, Pioneer avh4200, bed bar with light and antenna, Wet Okoles, Weathertech Mats, Wet Okole Armrests, Rear KR Fab bumper, bed mat, N-Fab spare tire carrier with full size spare on 16" TRD rim, Bedlinered flares and grille. Camburg Spindles, All Pro front fenders.
    if its only 350lbs im sure it would be ok
  3. Feb 11, 2009 at 10:54 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    I have done this in the past with good results. I used 2x6, then put a 1/2" ply wood on the top of it.
  4. Feb 14, 2009 at 3:27 AM
    A.D.
    A.D. Desert Riding Ninja
    SoC♠l 4 life but stationed in Utah
    Low and Slow Mini
    Are you talking about the grooves on top of the wheel wells? Because if so, i have been wondering what they were for, LOL.
  5. Feb 14, 2009 at 5:47 AM
    dougmays
    Doug
    Gainesville, FL
    haha yea they are for "adding another bed" or having 2 levels
  6. Feb 14, 2009 at 6:51 AM
    petersharp
    petersharp Well-Known Member
    Do you need to ask?! It's up there ^
    Louisville, CO
    Ex DC LB Sport owner.
    I thought they were intended for making a raised bed that you could carry sheet materials (8' x 4') - which won't go between the wheel wells. Your plan sounds good, but I have a couple of suggestions. Use 2 x 6s, and if need be shave them down a bit. That way the top of the wheel wells will be at the same height as the top surface of the timber - to help spread the load. Dunno why the cutouts weren't designed to be the right depth for '2 bys'.
    Then have a couple of supports in the middle of the wood so they don't bow.
    But really, 350lbs is nothing.
  7. Feb 14, 2009 at 12:08 PM
    A.D.
    Low and Slow Mini
    Thanks so much guys!! I have been sitting there wondering what those notches were forever!! I decided to use mine to make an ATV rampish device, so the front wheels sit off the ground and the quad is angled enough and more forward(but with a chock to keep the quad from going far enough forward to have the bumper break the window) so the gate can shut, plus i can put all my gear under there and not worry about it flying away.
    But your idea would seem way more practical for most people than mine, hope to see some pics when you are done.
  8. Feb 14, 2009 at 4:25 PM
    dsds
    dsds Well-Known Member
    Calgary AB
    2008 DC TRD Sport - Black Sand Pearl
    TacomaWorld sticker, DRL mod, running boards, roof rack, remote start / security alarm, marker/turn signal mod, map light with dome light mod, TRD seat covers, rear spring TSB
    So, just wondering what you're working on.
    Is your friend building a kit plane?
  9. Feb 14, 2009 at 6:23 PM
    ZonKs
    ZonKs Can speak french in Russian.
    Ted
    Glendale, CA
    2018 Sport DCSB 4x4
    =p
    I wish they would have added some vertical grooves so you could make a cargo divider.
  10. Feb 14, 2009 at 10:03 PM
    dougmays
    Doug
    Gainesville, FL
    yea he is building a RV.
  11. Feb 15, 2009 at 6:55 PM
    sako243
    sako243 Active Member
    pennsylvaina
    2008 taco 4x4 off road v6
    scangaugell, bug deflector,
    if you want room for your quad, all i did was bought a set of car ramps. ya the quad sit up high in the front but it works and i even have a cross the bed tool box in my taco]
