Using the AC... recirculate on or off?
Discussion in '1st Gen. Tacomas (1995-2004)' started by Madjik_Man, Jun 13, 2012.
  1. Jun 13, 2012 at 6:04 PM
    Madjik_Man
    Madjik_Man [OP] The Rembrandt of Rattle Can
    Colorado Front Range
    In my Legacy manual it says to maximize efficiency, use recirculate when running the A/C.
    Is this standard for all vehicles? Or is it the equivalent of "Max A/C" you see on some climate controls
  2. Jun 13, 2012 at 6:17 PM
    taco terror
    taco terror 1st gen = best gen
    USA
    1996 Black Tacoma, 3.4L
    4.56 ECGS regear, Wheelers 6 leaf pack, Eibach coils, Bilstein 5100s, AR Baja wheels, 33 BFG ATs, Line-x
    In the tacoma manual it says fresh air... that has always confused me.
  3. Jun 13, 2012 at 6:40 PM
    randytrish
    randytrish Active Member
    Randy
    King , NC
    2003 Tacoma SR5
    Usually the recirculate setting is for cooling down fast like if you just got in to a hot car. The cars I own with climate control come on with recirculate and then will switch to normal mode after the inside has cooled off. I use it in my Tacoma only when it's really hot and then switch back to normal.
    Randy
  4. Jun 13, 2012 at 6:42 PM
    92shawman
    92shawman Person
    K
    The Americas
    1992 Toyota Pickup
    Lots...see build
    Huh, that's interesting, 'cause I've always put it on recirculate after cooling the cab down. That's what my dad told me, anyways.
  5. Jun 13, 2012 at 7:25 PM
    TacomaJPP
    TacomaJPP To secure peace, is to prepare for war
    East TN
    03 4WD TRD XTD Cab
    Snugtop Camper Brushguard
    I've always thought the same thing.
    On one hand it seems that continuing to recirculate air that you are cooling would cool it quicker than cooling outside air.
    However, it always feel like fresh air is colder when you first start up.
    My carpooling buddy and I always laugh because we are diametrically opposed on this topic. When he drives, he clicks on the "recirc (max)" and when I drive, I run fresh air for a few minutes then click recirc.
  6. Jun 13, 2012 at 7:40 PM
    Madjik_Man
    In my Legacy the manual says to always use recirc when using the A/C because it's more efficient.
    I rarely use it in my Tacoma because the recirc feature is so f'in loud.
  7. Jun 13, 2012 at 7:52 PM
    RAT PRODUCTS
    RAT PRODUCTS Well-Known Member
    Farmington, MN
    Cummins Coal Roller
    Smokin with a smarty.
    I don't like the recirculation because it draws in the air I just farted and makes it stink. Fresh air FTW.
  8. Jun 13, 2012 at 7:57 PM
    Robertgeejr1
    Robertgeejr1 Well-Known Member
    Robert
    Aorora, Ill, yeah!
    1996 Toyota Tacoma SR5 4x4
    I have done all the hi-pro mods for a life time, since I got this truck at a great price, I will be happy with showroom new.
    and make sure you switch it to fresh if you use the defrost/defog. my dad and I had a long and lengthy argument about this and i had to read it to him out of the book... I don't make it a habit of correcting my dad but this was a safety issue.
    Brie likes this.
  9. Jun 13, 2012 at 8:08 PM
    Madjik_Man
    If you look at the climate control of some of the 01-04s it says to use recirc when you set it to defrost & defrost/foot
  10. Jun 14, 2012 at 8:51 AM
    Robertgeejr1
    Robert
    Aorora, Ill, yeah!
    this was on his 2nd (19934x4) the control panel seems close to ours. that was the one he got stuck on Ocracoke Island, funny story.
  11. Jun 14, 2012 at 12:15 PM
    skytower
    skytower Well-Known Member
    Dave
    virginia
    08 Tacoma 4x4
    Hitch and wiring, aux back-up light, rear strobe lights, radio and underseat sub.
    Consider this: The inside of the car is usually much hotter than the outside. Recirculating hot air to cool it off is not as efficient as drawing in the much cooler outside air when first starting to cool down. Cracking the window will also allow the fan to push more hot air out, until the temp inside starts to drop. After 5-10 min, close the window and switch to recirc/max. The interior air should be cooler than the exterior.
    Recirc is more efficient at keeping it cool, but can make for a musty/stinky interior.
    Brie likes this.
  12. Jun 14, 2012 at 2:25 PM
    koco
    koco Well-Known Member
    Bay Area Ca.
    '01 Taco
    Around $26,000 worth of unleaded in the fuel tank.
    +1 to this.
    The whole dashboard ductwork is heated by the sun when the truck is parked. You want to use the fresh setting to pull in cooler outside air for the first few minutes. On the freeway the recirc. setting keeps a lot of the exhaust fumes out.
    Brie likes this.
