Using The ECT Power Button
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Shades_Of_Red, Sep 21, 2019.
  1. Sep 21, 2019 at 9:33 PM
    Shades_Of_Red
    Shades_Of_Red [OP] Well-Known Member
    Lou
    Pittsburgh, PA
    2019 Tacoma TRD Off Road Premium Cavalry Blue
    A few.
    This was posted on another forum. A Tacoma owner contacted Toyota Motor Corp in reference to proper use of the ect power button:
    I had asked online and in three different Toyota dealerships and the answers were more or less split whether or not using the ECT button prevented the transmission from shifting into 6th gear. So, I wrote to Toyota corporation and here is their answer.
    "Thank you for contacting Toyota Motor Sales, U.S.A., Inc.
    We appreciate your inquiry, and thank you for allowing us the opportunity to respond.
    We have researched and found the following information:
    ECT PWR switch- Enhances acceleration performance and responsiveness by controlling the engine output and by changing the shift point of the transmission, thus achieving a sporty drive. Limiting the use of 6th gear when in this mode is a normal characteristic.
    S mode- Will allow the use of 6th gear however, if the vehicle speed and engine speed exceeds or go below a preset level in response to the driver's downshift operation request, changing the shift range will be prohibited. In this case, the buzzer in the combination meter will sound to alert the driver.
    We apologize, we do not have a speed diagram for each gear."
    Your email has been documented at our National Headquarters under file #1908093089. If we can be of further assistance, please feel free to contact us.
    Sincerely,
    Sharyce W.
    Toyota Customer Experience Center
    Notice how under the ECT mode heading, Toyota states that this mode not only changes shift points (which I already knew) but states that it also controls engine performance (which I had suspected).
  2. Sep 21, 2019 at 9:54 PM
    Bishop84
    Bishop84 Well-Known Member
    Nah man, it means higher shift point means more power. It always meant that and still does. It's not a turbo button.
    HondaGM, Veet-88, Lucifer1 and 3 others like this.
  3. Sep 21, 2019 at 10:06 PM
    Wesintex
    Wesintex Well-Known Member
    2017 Blazing Blue Tacoma TRD OR
    255/85R16 Toyo Open Country MT, Customish bed rack, CB radio
    Higher shift point = higher rpm = hot torque band faster = "more power"... more or less.
    Tullie D likes this.
  4. Sep 24, 2019 at 9:33 AM
    Clam04
    Clam04 Well-Known Member
    2018 TRD OR DCSB
    I don't find it holds a gear any longer when accelerating heavily. I used to always push the button when passing people, but now don't bother. It's a useless button in my opinion.
    Greene368, Russ68, CusterFan and 2 others like this.
  5. Sep 24, 2019 at 9:45 AM
    aleja_333
    aleja_333 Well-Known Member
    Colorado
    19’ Pro AT, 5.29's, Fox 2.5 RR, Alcan, PowerBrake
    Magnuson, Stryker tune, C4, Archive Garage HH, Alucab CC
    My MPG drops every time I use this button.
    SIDELINER4, CusterFan and Tocamo like this.
  6. Sep 24, 2019 at 9:57 AM
    kahanabob
    kahanabob Well-Known Member
    Maui
    16 TRD 2WD 4DR
    i agree here, i also (already knew). this will be debated back and forth forever here but you got the info from the horses mouth.
    Anton338 likes this.
  7. Sep 24, 2019 at 10:15 AM
    Stocklocker
    Stocklocker Well-Known Member
    17TRDORDCSBAT
    On stockish tire size, the effect of ECT button is very noticeable in my truck. I don’t use it generally, unless I’m in an area with a lot of steep undulations, and I want the engine to hold higher RPMs on the way down into the gulley before hitting another hill etc.
    davidstacoma, strongrob and GillyLink like this.
  8. Sep 24, 2019 at 10:20 AM
    Rock Lobster
    Rock Lobster Thread Derailer
    Dee Eff Dub
    I drive a Miata.
    I notice a huge difference if I'm hitched up to a trailer. If I'm running empty and on flats, the difference is subtle but still there. I have seen 6th gear with ECT on, though. It usually happens while coasting.
    cryptolyme and SIDELINER4 like this.
  9. Sep 24, 2019 at 10:25 AM
    BOSS-DS2
    BOSS-DS2 Well-Known Member
    Sam
    Texas
    2016 Tacoma 3.5L A/T DCSB
    Motofab 3” Spacer lift Spidertrax 1.25” wheel spacers Yokohama G003 M/T 285/75/17 (34”) MBRP 3” Turndown PowerStop slotted & drilled rotors Tekonsha P3 brake controller
    I turn ECT one every time I start the engine. I find less than it gives “more power” but that it just smooths everything out a bit. Without it seems like I will keep pressing the pedal slowly more and more and nothing will happen and then all the sudden it will shoot to 4-5 grand. With ECT on this seems to happen much less.
  10. Sep 24, 2019 at 10:26 AM
    Stocklocker
    17TRDORDCSBAT
    What size tires are you running?
  11. Sep 24, 2019 at 10:48 AM
    Stonerider
    Stonerider Member
    Stonerider
    2016 Tacoma TRD Sport 4x2
    I agree. The ECT button definitely makes the Tacoma more drivable in city traffic when you need to merge lanes by speeding up quickly.
    davidstacoma and SIDELINER4 like this.
  12. Sep 24, 2019 at 10:53 AM
    Tocamo
    Tocamo .
    Ottawa
    Bug-out vehicle
    I feel the same way about it. They should have given us a turbo boost button.... :curls:
  13. Sep 24, 2019 at 11:16 AM
    Tullie D
    Tullie D Well-Known Member
    Tullie
    Wilson, NC
    2019 SR5 V6 SSM Access Cab
    I tell myself that I'm going to try the ECT button someday every time I read a thread like this, but then I forget all about it.
    :cool:
    Corrugated, Boghog1 and SIDELINER4 like this.
  14. Sep 24, 2019 at 12:24 PM
    BOSS-DS2
    Sam
    Texas
    I drive 99% highway mileage, but even still, when passing I don’t want the tach hitting damn near redline.
    CusterFan likes this.
  15. Sep 24, 2019 at 12:26 PM
    BOSS-DS2
    Sam
    Texas
    33”, have some 34’s I’m throwing on once I get a chance to do a CMC. My truck even did it stock though, however it wasn’t as exaggerated as it is currently.
    Stocklocker[QUOTED] likes this.
  16. Sep 24, 2019 at 12:33 PM
    CPS-65
    CPS-65 I’m good for some, but I’m not for everyone.
    Alta Loma, CA
    2019 Quicksand TRD Off Road 4X4
    Mostly old man mods
    I use it when driving in hilly areas, especially with traffic. It makes the drive easier since it holds the gear longer. It feels like it has better off-idle power, but I suspect that is because it's not up-shifting as soon as the truck moves forward.
  17. Sep 24, 2019 at 1:19 PM
    kahanabob
    Maui
    16 TRD 2WD 4DR
    agree 100%, is why i installed ETC on at start up mod.
    Easygojoe and davidstacoma like this.
  18. Sep 24, 2019 at 2:13 PM
    CusterFan
    CusterFan Well-Known Member
    Southeastern Illinois
    Silver Sky 2019 Tacoma SR, AC, 4X2, 2.7
    That is why I don't use it. No need to run the guts out of the little 4 popper.
  19. Sep 24, 2019 at 2:24 PM
    BOSS-DS2
    Sam
    Texas
    Which is exactly why I DO use it, feels like I have more control of where the engine speed is, and when the truck shifts, dare I say nearly like a manual......
  20. Sep 24, 2019 at 2:53 PM
    DWD484
    DWD484 Could Be Joking
    Dave
    Louisiana
    '19 DCSB TRD Sport
    Super White
    I like to press it. Even when my truck's not running. Mainly because I enjoy pressing things. Over and over and over again. I have heard that pressing it makes my truck go faster. Just like that new pair of shoes in middle school. Hells yeah! Wearing new shoes & pressing buttons in middle school... Wait, sorry. I went off track for a second... Oh, yeah. Saturdays! I love Saturdays! Sundays are cool, too...
    Ronk44, bfonic, Mikeymopar and 15 others like this.
