Using the Transmission to break
Discussion in '4 Cylinder' started by paid4c4, Dec 13, 2012.
  1. Dec 13, 2012 at 8:10 PM
    paid4c4
    paid4c4 [OP] Well-Known Member
    Northern KY
    2015 4X4 TDR Sport, Auto Extended Cab
    I was just wondering if I was the only that uses the automatic transmission to slow the vehicle when stopping. Sometimes I move the shifter from D to 3 to slow my taco down when coming to a stop. I also us 2nd gear to hold the vehicle back when going down long hills when needed. Any comments regarding using the transmission this way good or bad.
    Bill
  2. Dec 13, 2012 at 8:11 PM
    Rich91710
    Rich91710 Well-Known Member
    Rich
    Los Angeles
    08 Base
    Generally not advised with an automatic unless you need to do it to save the brakes when towing.
  3. Dec 13, 2012 at 8:17 PM
    ProForce
    ProForce IG @proforce.expeditions OB#5411
    Anthony
    Alaska
    09 MGM TRD Sport DCSB 4.0 Auto 2wd
    Too many to list. See build page. Link in signature
    I've done it before. Don't make a habit of it but every now and then. I've heard its only bad because of the excess heat that it creates in the tranny but if you have a TRD model is should have a trans cooler which really helps keep the heat down, so I guess I depends how often you do it
  4. Dec 14, 2012 at 2:42 AM
    tacomathom
    tacomathom Well-Known Member
    Tom
    It's not new, it's not Mexico
    When I was a kid, old guys would tell me "you'll blow the seals in yer PowerGlide doin' that". How? "Don't get smart, ya just will"!
    I pop mine in to 3rd when going down hill, just to stay closer to the speed limit. I don't use the transmission as an engine brake on a level road. The truck seems to slow down plenty just taking my foot off the gas.
  5. Dec 14, 2012 at 3:00 AM
    gearcruncher
    Canadain bumper technician
    Yes , downshifting or engine braking will create heat within the transmission . All that enegry has to go somewhere . Better to create heat and wear on the brakes rather than the trans . Simply taking your foot off the accelerator seems to have an immediate effect with these trucks mind you. You do get better control of the truck by downshifting through icy corners or long hills .
  6. Dec 14, 2012 at 4:35 AM
    91r100gs
    91r100gs Understand the Voice Within
    Dan
    Kansas City area
    '08 Impluse Red SR5 I-4
    Factory bed mat, TacomaWorld.com sticker, EGR In-Channel Vent Visors, AFE ProDryS drop in air filter
    Brakes are cheap, transmissions are not. Other than decending a mountain with a load it is better to just leave it in D IMO
  7. Dec 14, 2012 at 4:39 AM
    TnRedNeck721
    TnRedNeck721 Nick Namer
    Zach
    TN
    07 TRD off road 4WD
    i do it in mine quite a bit. not problems yet.
    i do it mostly if i start into a turn, and realize i’m going just a little to fast. i’ll down shift to slow down.
    also i have done it mostly on the tail of the dragon(US129 into NC, 318 curves in 11 miles) i don’t even smell anything and thats shifting in every curve up into NC and back into TN.
  8. Dec 14, 2012 at 10:15 AM
    azreb
    azreb Geezer
    TN
    '20 SR5 crew cab; gray
    camper shell, front camera, floor mats, cheap bed mat, dash camera, catalytic converter cover, fumoto
    I did that all the time with a '94 T100. Never had a problem, but I did put an extra transmission cooler on the truck right after I bought it. Sold the truck with 130k miles. It was still running around town several years later.
  9. Dec 14, 2012 at 10:54 AM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    I believe the Owner's Manual actually states than you can use the transmission to engine break. Also, it's the engine that's doing the breaking, the transmission's torque converter locks up so how do you guys thing that you building heat in the transmission?
