Using tow strap to take out a stump
Discussion in '2nd Gen. Tacomas (2005-2015)' started by MHARMS, Jul 28, 2019.
  1. Jul 29, 2019 at 6:44 AM
    #41
    MolonLabeTaco
    MolonLabeTaco Well-Known Member
    Dude
    N. Texas
    '12 DC 4x4 OR
    Do NOT pull in reverse. That’s a good way to wreck your diff.
  2. Jul 29, 2019 at 6:54 AM
    #42
    TheDevilYouLove
    TheDevilYouLove You can’t polish a turd, but you can polish a TRD
    Marylandistan
    2010 Tacoma TRD Sport Access cab 4x4 silver streak
    Oops. Why is pulling in reverse bad for the diff? Front or rear diff or both?
  3. Jul 29, 2019 at 7:37 AM
    #43
    knottyrope
    knottyrope Well-Known Member
    Knotty
    Bahstun
    09 Taco CCLB 4x4 SR5 4.0
    Pads, rotors, ujoints, 5900K Super White Xenon HID Halogen Bulb Fog Light
    I use reverse because the weight is in the front and I like to watch
    Skyway, spitdog and TheDevilYouLove like this.
  4. Jul 29, 2019 at 7:42 AM
    #44
    TheDevilYouLove
    Marylandistan
    #metoo. Seems like better traction is obtained by pulling in reverse since the weight of the engine is closer to the load.
    Skyway likes this.
  5. Jul 29, 2019 at 7:56 AM
    #45
    rmorse
    rmorse Well-Known Member
    Bobby
    Bowie, MD
    2015 Blue Ribbon Metallic Access Cab TRD Sport
    https://www.tacomaworld.com/threads...le-any-danger-from-doing-it-in-reverse.72540/
  6. Jul 29, 2019 at 8:02 AM
    #46
    nh_yota
    nh_yota Well-Known Member
    Jeff
    Portsmouth, NH
    2010 DC V6 TRD-OR 6-SPD
    2" Lift with HS coils/AAL and 5100s, TRD Exhaust, TRD Skid Plate, URD Short Shift, AT3s
    Pulling heavy loads in reverse is bad for a manual transmission because reverse works by using a small idler gear between the input and output shafts so they are not directly connected like they are when moving forward. Put too much stress on the idler and it will break. I am not sure about automatic transmissions.
    Hypoid gears in differentials are cut so that they can withstand a heavy load in ONE direction (forward) but not so much in the other direction.
    Gunshot-6A and Armed in Utah like this.
  7. Jul 29, 2019 at 8:34 AM
    #47
    Muddinfun
    Muddinfun Well-Known Member
    Hypoid ring and pinion gears have a drive side and a coast side. The coast side teeth are angled a lot more, which causes more force trying to push the gears away from each other when putting the power down in reverse. Tacos use a high pinion front axle, so that is driving on the drive side of the teeth going forward also. There are plenty of trucks made with low pinion front axles which drive on the coast side going forward.
    So, the million dollar question. Are you applying enough force to destroy the gears in reverse when pulling a stump? If you're getting that violent with the stump, you probably should be using a different piece of machinery. So, there you have it. The gears are weaker in reverse than forward.
    Skyway and PzTank like this.
  8. Jul 29, 2019 at 9:52 AM
    #48
    Extra Hard Taco
    Extra Hard Taco Well-Known Member
    R.J.
    Devil's Island
    2012 Tacoma TRD OR, 2007 DC (sold), 2003 TRD OR (sold)
    ARB Bumper, SOS sliders, SOS rear bumper, SOS skid plate. OME Lift. Some other stuff.
    I believe the front drive shaft is also weaker and will break before the rear one will also. Someone correct me if I'm wrong.
  9. Jul 29, 2019 at 10:46 AM
    #49
    STAGE 2
    STAGE 2 Well-Known Member
    Did this once but it was with an Isuzu cab over with a long flatbed so no real potential for YouTube glory. Only way I’d try this with a personal truck is if I owned a deuce and a half.
  10. Jul 29, 2019 at 10:50 AM
    #50
    photogr4x4
    photogr4x4 Well-Known Member
    Canada
    TRD OR
    Nada
    I couldn't dig a rose bush root system by hand unless I wanted to spend 6 hours doing so. It had offshoots in 5 different places in a large garden, main roots were 5" across. Tore it out with a bit of climbing webbing and my hitch and had a blast. Definitely not necessary, but fun nonetheless because it made a comical dust cloud as it got torn out lol
  11. Jul 29, 2019 at 10:50 AM
    #51
    Larzzzz
    Larzzzz Grande' Ricardo
    Larry
    MA
    '06 dclb 350+ kmiles
    Aux back up lights, Bed lights, Re-located trailer plug, Good dooby, a.k.a. jumper cable mod, Heated seats, back up camera,
    PzTank[QUOTED] likes this.
  12. Jul 29, 2019 at 11:14 AM
    #52
    PzTank
    PzTank Stuck in the Well
    Above the Notches
    ‘15 AC SR5 4X4 4.0 Auto
    ‘07 OR leather shift knob
    Here’s to you never being featured on it:cheers:
  13. Jul 29, 2019 at 11:23 AM
    #53
    stickyTaco
    stickyTaco Fuck Cancer
    Zack
    Reno/Tahoe
    '12 DCSB TRD-OR
    Fox/Dakar with Relentless goodies and stuff
    I used my winch to remove an old peach tree at our rental with little effort but it was three 4" to 6" trunks. Make sure you soak the ground well and cut as much of the root structure as you can.
    llamasmurf and MHARMS[OP] like this.
  14. Jul 29, 2019 at 11:24 AM
    #54
    Larzzzz
    Larry
    MA
    Backatcha :cheers:
    My days of doing stupid things are over.
    Calculated risks on the other hand... Hehehe
  15. Jul 30, 2019 at 3:01 PM
    #55
    MHARMS
    MHARMS [OP] Well-Known Member
    2014 Black Tacoma TRD sport DCLB
    GoRhino Dominator D2 nerf bars, K&N air filter, LED cabin lights, Neoprene seats, Billstein 5100 front shocks 2.5" lift, ultra crusher 17” wheels w/ko2s, DIY tinted tail lights, LED reverse lights, CONDENSATE DRAIN HOSE EXTENTION!
    Update! 4 stumps removed so far. Just take a mattock and swing away at most of the big roots then tore them out no problem with truck.
    llamasmurf, PzTank and stickyTaco like this.
  16. Jul 30, 2019 at 4:16 PM
    #56
    Catcrazed
    Catcrazed Love is Dogs and Toyotas
    Bryan
    Central Oregon
    3rd Gen Flatbed 3.4
    91 Flatbed, 4.88's, ARBs, SAS, 3.4 Swap, 35s, M8000, lots lights, Aux tank, Protech
    POV the only kind I watch
    knottyrope[QUOTED] and TireFire like this.
  17. Jul 30, 2019 at 4:38 PM
    #57
    rnish
    rnish Well-Known Member
    Tacoma 2nd gen
    Not that long ago farmers would blow tree trunks when clearing fields. You could buy dynamite at the local farm implement store.
  18. Jul 30, 2019 at 4:46 PM
    #58
    TireFire
    TireFire Superunknown Member
    Olympic Peninsula
    Drive shafts don’t care which way they spin. So while your statement is undoubtedly true it doesn’t apply here. It’s bc of the gears first and foremost (some transmissions secondly) but if you’re not shock loading the teeth it’s probably not going to break anything. Still the cautious approach would be to pull forward or use a winch if you can’t back up to it for some reason.
    The argument that the windshield is stronger is laughable at any rate because if you’re bright enough to figure that out you should also figure a way not to bust ANY windows
    imthejaybird and MolonLabeTaco like this.
  19. Jul 30, 2019 at 4:58 PM
    #59
    RedTacoATX
    RedTacoATX Well-Known Member
    Bryan
    Austin, TX
    Black 2016 Tacoma TRD skeeewp DCSB & 1992 DLX RC V6 4X4 MT 35's FTW
    None....yet.
    No one has suggested tannerite yet?
  20. Jul 30, 2019 at 5:02 PM
    #60
    Sharpish
    Sharpish Well-Known Member
    Brian
    Victoria, British Columbia, Canada
    2012 Tacoma TRD OR 4x4
    My dad used to pull stumps all the time. Of course it was a '78 F250 with a 460 V8 but they came right out with hardly any throttle at all.
    It was very satisfying to watch for some odd reason.
    stickyTaco likes this.
