using toyec aal w bilstein?
Discussion in 'ToyTec Lifts' started by Rincontaco, Jul 19, 2013.
  1. Jul 19, 2013 at 5:46 PM
    Rincontaco
    Rincontaco [OP] Member
    Rincon, Ga
    2013 MGM DC OR
    debadged, mostly.
    Hey guys, before i hit the pay button at toytec i wanted to double check that this is the setup i need. I've purchased the bilstein 5100's for the front and want to set them at 1.75. The stock config i have has me at a difference of 1.25 lower in front than rear (stock) So if i add this " 1 1/2" Lift rear add-a-leaf for Tacoma with rear TSB springs" which i do not have tsb as my off road is 3 pack and thats all they will replace. My question is this toytec setup does state that works for non tsb also but will it be lower than 1 1/2 inches rear lift ? And is this a set up with a fairly limited budget that you would reccomend. Also, im ok if it is less than 1.5 inch rear lift as i like a less raked front end. Thanks in advance!
  2. Jul 19, 2013 at 5:52 PM
    Fluffymonkey
    Fluffymonkey Token
    College Station, TX/ Lawrence, KS
    2013 Trd Sport DC, 07 DC sr5
    2007: Avid sliders, 30% front tint, Truxedo low-pro qt tonneu cover, aero turbine 2525 muffler w/ 8'' tip, AR25 Resonator, 16x8 Dick Cepek DC-1 w/ 265/75 Goodyear Wrangler Duratracs, 2010 headlights, ome 884 coils with .5'' top plate spacer, OME sport front shocks, blisten 5100s rear, 2'' aal, locking gas cap, LR ucas, Viper 2-way remote start, afe drop in filter, Rocky locking bike mounts, gear chest, scanguage, pop n lock tailgate lock 2013: most things transferred over from my 07, 5100s @ .85 + eibachs, wheelers progressive aal w/ overload
    You're asking if your toytec tsb aal will work with the blisten 5100s you bought? Yep, they're good for 0-2'' of lift in the rear, so you're good to go :thumbsup:
    Edit: just reread it. So you're keeping the rear with stock shocks and an aal? You may want extended shocks or to purchase some shock extenders so you don't damage your stock ones.
  3. Jul 19, 2013 at 6:10 PM
    teamhypoxia
    teamhypoxia MichelinMan
    Colorado
    '12 DCSB TRD OR
    DON'T purchase shock extenders.
    Toytec stoner told me they'd be fine. I'm pretty sure the first rock I rolled off of , my shocks bottomed out and blew up.
    In hindsight, it's pretty obvious that if you just extend the rod you make them bottom out sooner.
    Stock shocks might limit droop, but I'd bet that half the axle suspended from a fully extended shock is much less likely to destroy the shock than the trucks entire weight slamming the rod into the bottom of the shock.
    Fish Taco 4x4 likes this.
  4. Jul 19, 2013 at 6:46 PM
    Rincontaco
    Rincon, Ga
    2013 MGM DC OR
    debadged, mostly.
    no... I have not had a tsb done on my truck. its a off road 2013 and they only come in a 3 pack and they will only replace a 3 pack. I have one set of front bilstein 5100's. I want to level the truck and get at least the 1.75 lift.
    If i add the aal with toytec it is advertised to give a 1.5 inch rear lift but the model says with tsb. it also says works without tsb. I just dont want to add 1.5 in the back giving me a total of 2 3/4 back minus 1.75 front lift from billys leaving me fairly raked again. Does the toytec aal settle in or is it guaranteed 1.5 rear lift even without the tsb which i wont ever do. I know i can call them Monday just was hoping someone knew..sorry for the confusion.:eek:
    Also with the progressive springs on the off road model do you think it will be super stiff adding the bilsteins? I am super motivated or salivated to put these on but not wanting to pay to do it twice..as i get older trying to measure twice and cut once..:eek:
  5. Jul 19, 2013 at 6:57 PM
    Fluffymonkey
    Fluffymonkey Token
    Oh I see what you're asking now. I'd give toytec a call. I'm not sure how much lift you'll get using the tsb aal with a non-tsb leaf pack vs the tsb leaf pack. The tsb aal usually gives less lift than the non-tsb because it's compensating for the lift you'd already have with the 4 leaf pack. As far as the springs, it'll be a touch stiffer but not bad by any means. Many people prefer the ride over stock.
  6. Jul 19, 2013 at 7:11 PM
    Rincontaco
    Rincon, Ga
    2013 MGM DC OR
    debadged, mostly.
    Thanks! I will call them Monday. Im hoping since they sell the heck out of these things they can guide me in the right direction.
  7. Nov 14, 2013 at 7:31 PM
    Taco trd
    Taco trd Member
    Shannon
    Winnipeg
    13 Tacoma Double Cab 4x4 TRD Sport
    What is a tsb?
  8. Nov 26, 2013 at 1:42 PM
    steve2267
    steve2267 Active Member
    Colorado
    04 Double Cab Tacoma 3.4L 4WD/TRD
    I believe TSB is short for Toyota Service Bulletin
    Took me some searching to figure that out. Hope I'm right, but I'm pretty sure. I deduced that from Leaf Spring TSB for 2013 Tacoma.
  9. Dec 17, 2013 at 6:27 PM
    tacoftw
    tacoftw 5100s are the same price as spacers, seriously
    McDonough, GA
    05 Double Cab 4x4
    5100s, camburg arms, toytec AAL, 285s on m/t 17x9
    i have the toytec AAL (& non tsb leaf springs), had to set my 5100s at 2.5 AND use a 1/2" spacer to get it level
  10. Jan 23, 2014 at 7:50 PM
    TheGrayRider
    TheGrayRider MARANATHA !!!
    NW Florida
    2011 Dbl Cab Prerunner
    I have 5100s with the front set at 1.75" with the 1/4" toytec spacer on top
    That gives me a total of 2.25" of lift in the front
    Toytec AALs on the rear axle and since I have a Leer shell
    I have 1.5" of lift for the rear
    It's almost stock looking rake and no alignment issues
    Rides great
  11. May 27, 2016 at 5:56 PM
    kanoaml
    kanoaml Well-Known Member
    2001 Toyota Tacoma
    I am looking at toytec BOSS suspension for my 1st ten. If I set coils to 2.5-3" in. of lift and slap on the dakar leaf packs for my 01' will it level the truck/have rake in the back? I don't want to run blocks and am hoping to not have to buy shackles. Thanks!
  12. Aug 15, 2016 at 11:21 PM
    Ice Horse
    Ice Horse Stalking horse
    Lauren
    Colorado
    98 3.4L V6 TRD Ext. Cab 4x4 SR5
    ADS Racing Shocks 2.5" Extended Travel Coilovers with Reservoirs, 3 inch All Pro rear suspension kit, factory E-locker, Trail Gear sliders and front stinger bumper, CBI Offroad rear tube bumper, XRC8 Winch, 33 inch BFG KM2's, 16 inch Ivan Stewart Wheels, Uniden CB radio, flip up license plate, white tail lights, LED front signals, Tundra front brake upgrade, new radio, rock lights, sub woofer, remote start, satoshi grille with Prius emblem, Rigid DOT/SAE Fog Lights, 12" Light Bar
    It might have a little rake since the Dakars do about 3"-3.25" of lift according to the description. But if you don't have a lot of weight, it says you can remove the third from the top leaf for lighter duty or lower lift height. So you could level it out.
  13. Aug 16, 2016 at 7:56 AM
    ToyTec Lifts
    ToyTec Lifts Toyota Suspension specialist Vendor
    Rocky Mountains
    Toyota's are awesome
    With the '01 Taco you should receive about 2.5 inches of lift from the Dakar leaf packs. Since the rear of the taco is about 2 inches over the front stock, you will have a slight rake from the front to rear.
    http://toyteclifts.3dcartstores.com/Old-Man-Emu-rear-springs-with-bushings-98-04-Tacoma_p_144.html
