Using Undercover Flex with factory rails
Discussion in 'Tonneau Covers, Caps and Shells' started by tomgru, Apr 17, 2018.
  1. Apr 17, 2018 at 9:06 AM
    tomgru
    tomgru [OP] Well-Known Member
    Thomas
    PNW
    2021 TRD Pro
    My dealer installed an Undercover Flex Tonneau cover on my 2017 limited.... and it mounts directly to the factory rails, making them useless for anything else.
    I saw this video for the backflip that has brackets that relocate the rail below:
    https://www.youtube.com/watch?v=zL1YNoYdrMo
    Has anyone tried this, and/or any other ideas on how to get some functionality of my rails back?
    Thanks
  2. Apr 17, 2018 at 9:07 AM
    chucklefunkk
    chucklefunkk Well-Known Member
    So. AZ
    2016 TRD OR
    I’ve got a Bakflip G2 that mounts like the one in the video. Still retain 100% functionality of the rails.
  3. Apr 17, 2018 at 9:13 AM
    tomgru
    Thomas
    PNW
    2021 TRD Pro
    i assume it came with those brackets? wonder if they'll work with another brand - don't see why not.
    i'm on the backflip site... don't see them offered as an add on.
  4. Apr 17, 2018 at 9:15 AM
    eccracer104
    eccracer104 O.G. Member
    San Diego, CA
    2016 Tundra 4x4
    I'd try giving them a call and see if you can order them as a replacement part. Chances are the only place to get them would be from BAK.
    Sub'd to see if it works!
  5. Apr 17, 2018 at 9:22 AM
    tomgru
    Thomas
    PNW
    2021 TRD Pro
    As FYI... just heard back from them :-(
    Hello,
    Unfortunately we do not have a kit like they do, all of our installs keep the factory track system where they are.
    And when i asked if they thought the brackets would work, they said:
    I don’t believe it will, our clamps are longer than there and they would interfere with the track
    Wonder how hard it would be to make something that would work?
  6. Apr 24, 2018 at 11:13 AM
    truckalter
    truckalter Well-Known Member Vendor
    Luke
    Waynesville, NC
    Funny thing is that BAK and Undercover are sister companies... They will likely be sharing this setup soon...
    You would have to be pretty good at fabrication to make something easily to work... those BAK rails have a groove in the back that the brackets slide into... so they won't attach to the Undercover rails...
  7. Apr 24, 2018 at 11:21 AM
    tomgru
    Thomas
    PNW
    2021 TRD Pro
    i hope so. i thought the products looked really similar. WAs a bit surprised that the response was so quick with no solution. Clearly must be a fairly large problem... or heck, maybe it's not.
  8. Jul 16, 2018 at 7:50 AM
    bacollier90
    bacollier90 Well-Known Member
    Bryce
    Springfield, MO
    19 DCSB 4x4 Cement
    Ran into this problem as well. Did you find a solution?
    My thought was to get some sort of 3d printed brackets that would relocate a new rail down a few inches to clear under the rails.
    tomgru[OP] likes this.
  9. Jul 16, 2018 at 4:34 PM
    tomgru
    Thomas
    PNW
    2021 TRD Pro
    Nope...
  10. Jul 17, 2018 at 7:42 AM
    bacollier90
    Bryce
    Springfield, MO
    19 DCSB 4x4 Cement
    I am thinking flat bar attached to the undercover brackets with two new channels would work, just not sure it will take much load that way.
