Usng 4 Wheel Drive on Dry Pavement
Discussion in '2nd Gen. Tacomas (2005-2015)' started by sobaz, Mar 9, 2010.
  1. Mar 9, 2010 at 6:24 PM
    sobaz
    sobaz [OP] Member
    Hi Everyone
    I am a new member. Just bought a new 2010 Tacoma 4x4. My first 4x4. I was reading the owners manual. It said not to use 4 wheel drve on dry pavement. I am wondering why? Yes, I know it is not necessary, and yes, I know the probablity of something wearing out, or breakng if used, increases with use, but there must be more to it then this, I think. I am curious. Is there a technical reason?
    Thanks
  2. Mar 9, 2010 at 6:48 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    The technical reason, is because it causes binding in the drive train, and can cause increased wear, or breakage of the parts....And its not needed on dry pavement.
  3. Mar 9, 2010 at 6:50 PM
    Carson
    Carson Well-Known Member
    Carson
    Modesto, California
    '20 Grey TRD Off-Road 6spd
    TC +2 LT, Kings, BAMF Armor, 35s, gears
    Just wanted to add that you can use the 4wd on dry pavement as long as you are going in a straight line.
  4. Mar 9, 2010 at 6:54 PM
    Brunes
    Brunes abides.
    Rotorhead
    Around
    Just like you can use use a sledge hammer to drive finishing nails....Technically-right tool...but still not a good idea.
  5. Mar 9, 2010 at 6:55 PM
    skistoy
    skistoy Make mine a Double!
    Western New York
    09 4X4 SR5 BSP Double Taco
    Rear Spring TSB,Billy 5100@.85,Bull bar,Nerfbar,Painted Grill,Painted Rims,Bed D-rings,Compustar Starter,Goodyear Duratrac's,Transmission TSB,Brake Overide
    The best thing to do is engage the 4wd every month to keep everything in good working order. It will also get you used to how your truck reacts when engaged.
    It is better to do this on giving surfaces - mud, snow, rain.
    But if all you have is dry pavement, short distances going straight will be fine.
    I do it every month, even during the summer on dry pavement.
    Dont forget to do 4-lo also.
  6. Mar 9, 2010 at 6:57 PM
    Lentsnh
    Lentsnh Well-Known Member
    2007 Hummer H3 Tactical Edition
    None yet- Future: HIDs, Tinted tails, LED interior lights,
    Sharp turns or turns in general can demolish CV axles and boots. Get your CV axles replaced BTW!!
  7. Mar 9, 2010 at 8:35 PM
    travelingman
    travelingman What would Scooby do?
    Brian
    Ohio
    07lb4x4DC
    ticking eng.mo,ventvisors,locking tailgate,wheelmasters ss spare tire inflation line,weathertech mats
    Why would he need to get his CV axles replaced?
  8. Mar 9, 2010 at 8:47 PM
    HBMurphy
    HBMurphy Ban Pending
    Paul
    So California Coast
    09 Off Road Delete Model
    None
    Dry pavement = AWD
    AWD has a center differential to allow all wheels to turn at different speeds (and each drive shaft can spin at different speeds).
  9. Mar 9, 2010 at 9:09 PM
    Lentsnh
    Could strip the ridges on the ends of the CV axles. And the constant awkward angles of the turns with the speeds can damage both.
  10. Mar 9, 2010 at 9:20 PM
    GnrlLee01
    GnrlLee01 Member
    Believe the owner manual states you're supposed to drive 10 miles per month in 4WD in order to keep everything lubed.
  11. Mar 9, 2010 at 9:23 PM
    Lentsnh
    Yes you can engage it to keep the fluids mixed and the viscosity to stay the same.
  12. Mar 9, 2010 at 9:34 PM
    HBMurphy
    Paul
    So California Coast
    None
    That is not the reason!!!
    It's strictly for mental health. I mean if you can't get out once a month is there really any reason to live? :eek: :) :D
  13. Mar 10, 2010 at 4:17 AM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    Yes.... and you can do that by going offroad, or....like myself... I put it in 4WD on the highway in the pouring rain for about 5 miles or so. No turns, under 60mph...that's all you need.
  14. Mar 10, 2010 at 5:15 AM
    sobaz
    sobaz [OP] Member
    Thanks everyone
    I am new to four wheel drives. I appreciate you sharing your knowledge and thoughts. I will do as advised. It make sense now. Thanks again!
  15. Mar 10, 2010 at 6:22 AM
    Tacoyota
    Tacoyota senile member
    North of Cali, South of Canada
    08 4wd
    4.56 gears, rear trutrac,DT header, 235/85r16 Duratracs, 2nd filter pulled, inter.wipers, Cruise control, Factory alum. whls/winter tires(2nd set), Afe pro Dry-S , Dumbo eared flaps cut down.
    Welcome to TW..... lesson #1 every simple question will become a stick of dynomite. You ask about 4wd on pavement , but we all know you want to know the best tire on sidewalks, or just fishing for lift kit opinions.
  16. Mar 10, 2010 at 7:58 AM
    David K
    David K Well-Known Member
    Pala Mesa, California
    2010 4WD Off Road DC
    Are there really months in Canada without snow or ice?:D
    Welcome!!!
    In my words: when you turn, the front tires will rotate more times than the back ones... in 4WD, the front and back are 'locked' together... not a problem in dirt/ ice/ snow/ water where the tires can slip some. On dry pavement, the tires don't 'slip' very easily so the binding can occur.
    The AWD (full time four wheel drive) autos and SUVs have a center differential that permits the front and back tires to rotate differently, so they can be on dry pavement.
    Have a good one!
  17. Mar 10, 2010 at 8:12 AM
    Lentsnh
    And for the CV axles to be replaced I meant that there was a TSB for them on the '10s. Don't know if it's still on the list though
  18. Mar 10, 2010 at 8:23 AM
    OffroadToy
    OffroadToy pull my finger
    Icon Stage 8, ECGS Bushing, Timbren ubolt flip, Crown extended brake lines, Overland Custom Design sway bar links, rear differential breather extension, oil filter drain hose, a/c drain hose extension & reroute, front windows tint, Cat Security, XPEL headlight/fog & grill protection, OEM block heater, RCBS illuminated 4X4 switch, Weathertech mats, Wet Okole seat covers, Sherpa Grand Teton/Crows Nest, Baja Designs S8 light bar, Diode Dynamics SS3 Pro fog lights, Piaa driving lights, Method 305 NV Double Black, 275/70/17 Toyo R/T Trail.
    got a link?
  19. Mar 10, 2010 at 3:58 PM
    sobaz
    sobaz [OP] Member
    Hey, thanks gain. This information is really helpful. I am one of thoe guys that if someone tells me not to do something but does not say why, well, unfortunatelly I sometimes find out why the had way. This was much easier.
    Sometimes there is no snow in Canada, :) In Calgary because we are so close to the Rockies we can get snow 11 out of 12 months, rare but it has hppened. Melts quickly in summer months.
  20. Mar 10, 2010 at 4:00 PM
    sobaz
    sobaz [OP] Member
    Yes, I can look it up. Thanks
