USP port on 2012
Discussion in '2nd Gen. Tacomas (2005-2015)' started by tractng, Mar 8, 2012.
  1. Mar 8, 2012 at 8:35 AM
    tractng
    tractng [OP] Well-Known Member
    Guys,
    Does it play music from a usb drive? First I got an error reading it. Then I formatted fat32. Now its making me go through the BT setup. I read the manual.
    Thanks in advance.
  2. Mar 8, 2012 at 8:39 AM
    billv408
    billv408 Member
    bill
    san jose, ca
    12 Prerunner SR5
    Debadge, remove mud flaps, smittybilt nerf steps black, Magnaflow 16625 cat back, Black Pro Comp 7089 17x8 Rims, Nitto terra grappler 265/65/17 tires, fumoto/quick valve
    mine will play mp3's off a USB drive. i got the songs off a mac and a pc so not sure how the drive is formatted
  3. Mar 8, 2012 at 10:25 AM
    tractng
    Did you have to press any other button after plugging in the USB?
  4. Mar 8, 2012 at 10:50 AM
    Monkeyboy
    Monkeyboy Well-Known Member
    Grand Junction, CO
    2012 AC TRD Sport
    It does play music - plug in a USB stick, and away you go.
  5. Mar 8, 2012 at 11:03 AM
    myname150
    myname150 Well-Known Member
    Death Cab for Cutie is an awesome group :thumbsup:
    Anyways, Make sure the drive is FAT32 (which you already did) and try hitting the AUX button again.
    If I recall correctly, when you first hit the AUX button it defaults to the BT AUDIO stuff, then hit it again and it will switch to the USB port.
  6. Mar 8, 2012 at 12:16 PM
    tractng
    Thanks. I will give it a try.
  7. Mar 8, 2012 at 12:26 PM
    myname150
    No Problem buddy. Let us know how it goes.
  8. Mar 8, 2012 at 4:19 PM
    MountainDog
    MountainDog Well-Known Member
    Aurora, CO
    2012 4x4 Double Cab Off Road
    Vinyl floor; 265/75/16 Duratracs; SnugTop Rebel
    Just an FYI-
    I finally got around to testing this and it works. I usually have a Garmin eTrex GPS mounted on my dash and powered by a cigarette lighter adapter. I brought out the USB cable that I use to plug the GPS into my computer to see if I can use the USB port in the 2012 to power it. The GPS gets power and did not disrupt any Bluetooth stream of music from my iPhone.
    This frees up a cigarette lighter plug to power something else. Planning on Wet Okele seat covers with driver and passenger side heaters, which would require two plugins until I hard wire them (if I even do).
  9. Mar 8, 2012 at 8:29 PM
    tractng
    I got it to work. Thanks myname150. I had to use a different flash drive (previous usb drive worked on my Pioneer). Pressing the AUX twice afterwards.
    Quick question for you all. I notice it came with XM radio. I remember my wife's lexus had that for a few months. By default do you have to cancel it or it just automatically ends after 3 months? I did read Toyota's site, but can somebody confirm.
  10. Mar 8, 2012 at 9:33 PM
    myname150
    You're welcome!
    It will probably end after the trial. I doubt they have a means to bill you after the trial is over unless you reactivate or something. At least, I hope they dont :eek:
  11. Mar 9, 2012 at 5:05 AM
    RV7Garage
    RV7Garage R.O.U.S.
    Paul
    Ill Annoy
    2012 DCSB Offroad, Nautical Blue
    Disable DRL, Jailbreak Fog Lights, ARE topper
    XM does end after the trial. Now, when I try tuning the Grateful Dead channel, it says "unauthorized".
    XM just wanted way too much $$/year! Especially when I can just roll Pandora wirelessly :)
  12. Mar 9, 2012 at 5:38 AM
    g35man
    g35man Discount Double Check
    League City, TX
    2012 MGM DC 4x4 OR
    Icon Stage II lift kit, LR uca's, Weather Tech floor mats, FX-R retrofit, Morimoto factory fit LED fogs, flyzeye designs cup holder lights, wet okole seat covers, upgraded Entune system
    Agreed! i did not subscribe either. I have too much music to pay for satalite radio.
  13. Mar 9, 2012 at 6:33 AM
    WV150
    WV150 Well-Known Member
    South Carolina
    Trifecta Tonneau Cover
    At best buy I got a sandisk USB flash drive that only sticks out 1/4 inch. A 4 or 8 GB will hold thousands of songs.It is so stubby the usb flap almost goes closed and you can hardly tell is is pluged in. I put about 60 cds on one and their is room for several hundred cds. You can change between cds using the folder button on the radio. Hit the #6 twice button after you are playing from USB and it will play randomly from different cds.Hit it once and it will play randomly from the cd you selected.That USB port is a great feature for 2012.Before you put anything the flash drive make sure you delete anything Scandisk may have had on it or it may not work on your radio.At least it would not on mine until I had it clean of anything.Its like having hundreds of cds on something as small as a honey bee.
  14. Mar 9, 2012 at 7:47 AM
    Utard
    Utard Well-Known Member
    Mark
    Nyssa, Oregon
    2012 DC LB 4WD TRD SPORT NAVI
    ------------------------------------------------------------ Stabilus.EZDown.Tailgate http://www.ezdown.com/home.php ----------------------------------------------- Tekonsha.Primus.IQ.Trailer.brake http://www.tekonsha.com/content/default.aspx---------------------------------------------------------------- Leer 180 CC http://www.leer.com/Truck-Caps#------------------------------------------------ Firestone Air Rite Air Bags--------------------------------------Kargomaster Rack
    I got a 16 gig and filled it with over 250 hours of techno and put it on random. And another 16 gig with all other music. about 3000 songs. Works great. I also have a 32 gig that works in it just fine. Not sure about 64's?
    With this fumbling with cd's or an icrap is stupid. $30 16 gig USB VS $250 icrap = no brainer
  15. Mar 9, 2012 at 8:29 AM
    Monkeyboy
    Grand Junction, CO
    2012 AC TRD Sport
    It will cancel automatically. They will send you ads as the date approaches, however.
    If you wait long enough, they will send you a notice for like 50% off if you renew. It's about 6 dollars a month, so that's not bad.
    After the 6 months, the subscription goes to regular rates, but if you cancel before it expires, they send you a new 50% off deal.
  16. Mar 9, 2012 at 8:39 AM
    Fed Taco
    Fed Taco Well-Known Member
    Cale
    2011 TRD Off Road
    Wheels & Tires, weathertech floor liners, Areo Turbine Exhaust
    I've had my truck for almost a year, never got a bill or letter and I still get sirius/xm radio.
  17. Mar 9, 2012 at 9:04 AM
    grhopper
    grhopper Well-Known Member
    Louisiana
    2012 DCLB TRD Sport
    Thanks for posting this. I was about to order a Kingston Micro flash drive until I read your post. The sandisk is a couple of dollars more, but it looks smaller and is black, the Kingston is blue. I got the 16GB for $17.
  18. Mar 9, 2012 at 1:57 PM
    WV150
    South Carolina
    I got a 8GB sandisk on sale for $9.95 normally $29.95. It is so small the USB flap covers it and you can not even see it.If you look down there it just looks like you did not push the flap all the way closed.
  19. Mar 10, 2012 at 12:27 PM
    billv408
    billv408 Member
    bill
    san jose, ca
    12 Prerunner SR5
    i have to push the AUX button twice to see the usb when i put it in.
  20. Mar 15, 2012 at 5:14 PM
    midniteben
    midniteben Member
    Glendale CA.
    2012 Prerunner DC
    This is great info. a couple questions for you. Do the artist's come up in alphabetical order on the screen? If so, how did you organize the cd's in itunes so they will come up in alphabetical order?
    Thanks in advance.
