UTAH (and Surrounding Areas) BS Thread
Discussion in 'South West' started by Drunknsloth, Feb 27, 2011.
  1. May 21, 2013 at 12:01 PM
    #2081
    DeeKay21
    DeeKay21 Lieutenant Dan.
    Nevada/Utah
    06' TRD Sport 4x4
    Sorry to hear about your trailer. I have no use for thieves and they are the ones I care about the least. Instead of working hard and saving up money they go out and steal things from descent people. Hope you relocate the trailer and Karma will get them sooner or later.
  2. May 21, 2013 at 3:26 PM
    #2082
    FirstTracks
    FirstTracks Well-Known Member
    Marc
    Salt Lake City, Utah
    07 Tacoma Access Cab 4.0L V6 SRS 6sp manual
    Leer cap, BedRug
    I've been reading up on installing a dual battery system in my 07 Taco, and it's not just the cost that scares me. I'm not the most mechanically inclined guy in the world and the thought of trying to install this myself frightens the bejeezus out of me, too. Because I'd apparently have to replace the stock battery that I just bought for the damned thing with two different batteries at ~$250 each, I think that I'm looking at about $800 in parts alone.
    So a couple of questions:
    1. The reason I want this is for camping, not for running a winch or the like. I'd just hate to be in the middle of the desert somewhere all alone and realize in the morning that I ran the battery down too low to start the truck. Can I get away with just carrying along one of those portable battery-powered car starters to alleviate this concern, or do I really need a dual setup with a deep cycle auxiliary?
    2. If the answer to number 1 above is just to carry a portable, is there a particular brand/model that folks recommend? Some of these things look really cheaply made and therefore not trustworthy.
    3. Who in the SLC area can fellow Utah Tacoma owners recommend to install a dual battery setup so that I don't fry/burn/damage/otherwise fubar my truck by attempting to do it myself?
    Forgive what some may perceive as dumbass questions, but thanks in advance from a relative newbie looking for advice.
  3. May 22, 2013 at 7:57 AM
    #2083
    knayrb
    knayrb Well-Known Member
    Bryan
    Somewhere in the square states
    2010 Dbl-Cab Off-Road
    Pure stock
    Thanks everyone for keeping your eyes open for my trailer. I probably won't see it again but wouldn't it be great to catch the scumbag?
  4. May 22, 2013 at 7:58 AM
    #2084
    Box Rocket
    Box Rocket Well-Known Member
    Adam
    Syracuse, Utah
    1995 FZJ80 Land Cruiser
    3xLocked, lifted, well used
    Kurt at Cruiser Outfitters in Sandy.
  5. May 22, 2013 at 8:29 AM
    #2085
    knayrb
    Bryan
    Pure stock
    So IMO the problem you have is that a battery for starting (truck) is different than one for camping. You need a deep cycle for camping. A starting battery has thin plates and dumps lots of AMP real fast in order to turn the engine over. It should never get lower than 90% capacity and sit without charging. A deep cycle battery has thick plates and is designed for a steady lower AMP discharge and can get down to about 40% charge capacity and can wait a day or 2 before charging. (Deep cycle means deep discharge). Both batteries have a different charging methods. Of course the charging system on our trucks are made for a starting batteries.
    One thing you might consider is replacing both batteries in a dual system with marine batteries. They have medium size plates and are a compromise between the 2 batteries. The will start the truck but you will notice that it might act "tired" in the cold winter.
    In hooking the system up just make sure the batteries are in parallel and not series. Run the truck's + leads to both +'s and same with the -'s. Do not run + on battery 1 to - on battery 2 and then back to the truck. If you do you'll have 24 volts and that will be bad.
    Good luck.
  6. May 22, 2013 at 8:49 AM
    #2086
    Kevin B.
    Kevin B. 4Runner hooligan
    SL,UT
    Gray Bastard
    1985 4Runner, 22RE/W56, 4.7 transfer case, OME lift, 5.29 diffs w/Spartan rear locker, 255/85 KM2s on 16 inch alloys
    Can't second this strongly enough. I wouldn't go anywhere else for an install like that.
    And I've never owned one of those portable jump kits that was actually capable of jumping a car with a truly dead battery.
  7. May 22, 2013 at 3:38 PM
    #2087
    StaticFilter
    StaticFilter Well-Known Member
    Cedar Hills, UT
    2008 Blue FJ Cruiser
    Lifted, N-Fab steps, Roof rack light bar, Grill guard, Volant Snorkel (not installed ye)
    Here's a related post over at FJCforums...
    http://www.fjcruiserforums.com/foru...dual-battery-complete-kit-300-00-battery.html
  8. May 23, 2013 at 7:22 AM
    #2088
    Utard
    Utard Well-Known Member
    Mark
    Nyssa, Oregon
    2012 DC LB 4WD TRD SPORT NAVI
    ------------------------------------------------------------ Stabilus.EZDown.Tailgate http://www.ezdown.com/home.php ----------------------------------------------- Tekonsha.Primus.IQ.Trailer.brake http://www.tekonsha.com/content/default.aspx---------------------------------------------------------------- Leer 180 CC http://www.leer.com/Truck-Caps#------------------------------------------------ Firestone Air Rite Air Bags--------------------------------------Kargomaster Rack
    I do a lot of camping in the west deserts. A good days walk if I had problems.:eek:
    I did a little research on these. (had an older one that died) This one has a replaceable battery. Here is the best bang for the buck I could come up with. You just dont want to get a small cheapy one because they do not have enough juice to start a bigger engine.
    And to boot it not only has a jump start it has a compressor, inflator, inverter, usb charger, light and 12volt plugin.
    http://www.sears.com/diehard-platinum-portable-power-1150-with-jumpstarter-air/p-02871988000P
    But if you are really looking for a dual battery thing I personally would put in some wiring to the bed with a quick disconnect. Get a deep cycle battery with a huge amount of CCA's and just pop in the bed when you go out. And keep on a smart charger at home.
    And if you just want a jump starter this one will start an 18 wheeler.
    http://www.amazon.com/Truck-ES6000-...F8&qid=1369319078&sr=1-4&keywords=Booster+PAC
  9. May 23, 2013 at 1:12 PM
    #2089
    smkd13
    smkd13 Professional Idiot
    Ben
    Provo, UT
    19 DCSB OR
    Stock… for now
    I am running two starting type batteries in parallel and it seems to work fun for me. Granted I will step up to an AGM when I do my Big3 upgrade and relocate them to the engine bay. Then I will put an isolator in and be done with it.
  10. May 26, 2013 at 4:34 PM
    #2090
    Kevin B.
    SL,UT
    Gray Bastard
    Short notice, I know, but we're hitting American Fork Canyon tomorrow afternoon. Maybe Mineral Basin, maybe something milder if too many stockers show up. Anyone respectful is welcome to join us.
  11. May 26, 2013 at 4:51 PM
    #2091
    TROKITA
    TROKITA Well-Known Member
    Arty
    Utah, the valley
    98 tacoma TRD supercharged
    Supercharged, Custom sunroof, 6 inch lift, wheel spacers, over the rail tire carrier
    dang i work so "/ cant
  12. May 26, 2013 at 8:28 PM
    #2092
    Kevin B.
    SL,UT
    Gray Bastard
    That's what the good lord gave you sick days for! Tell the boss you've got low altitude sickness and can't come in. :D
  13. May 26, 2013 at 9:14 PM
    #2093
    TROKITA
    Arty
    Utah, the valley
    cant im already taking Whensday, Thursday, Friday, Saturday off. :D heading to moab :D
  14. May 27, 2013 at 1:12 AM
    #2094
    92LandCruiser
    92LandCruiser Well-Known Member
    Nevada
    80 series Land Cruiser
    Cummins, tons, 40s
    Anyone live in Hurricane? Just curious, have a few questions, PM me.
  15. May 27, 2013 at 6:23 PM
    #2095
    smkd13
    Ben
    Provo, UT
    19 DCSB OR
    Stock… for now
    Chop chop buddy ad btw when I was hooking my amp up, I accidentally hooked up the wires backwards and fried the transformer in the amp :(
  16. May 27, 2013 at 6:24 PM
    #2096
    TROKITA
    Arty
    Utah, the valley
    yup im getting all my shizz ready today and packing it so as soon as i get back from work im heading out :)
  17. May 27, 2013 at 8:56 PM
    #2097
    RMAN808
    RMAN808 S)(AKALO)(AWAII
    Reid
    Pearl City, Hawaii
    '17 TRD OR 4X4 Quicksand
    Anyone have any Toyota wheels lying around they wanna get rid of? 15 or 16" :D
  18. May 27, 2013 at 9:44 PM
    #2098
    ROGU3 PR3DATOR
    ROGU3 PR3DATOR Space Shuttle Door Gunner
    Jake
    Eagle River, Alaska
    MGM 2011 TRD Off-Road
    Lifted, Supercharged, Armored, and lots more
    I have 4 TRD off roads that need a new home...
  19. May 27, 2013 at 11:38 PM
    #2099
    TROKITA
    Arty
    Utah, the valley
    what size ?
  20. May 27, 2013 at 11:44 PM
    #2100
    RMAN808
    Reid
    Pearl City, Hawaii
    15 or 16". I'm not sure what the widths are, but whatever stock Toyota ones are.
    I was hoping to scoop up a pair of 4Runner wheels off KSL but the seller sold em after he said he'd hold em for me :( oh well
