UTAH (and Surrounding Areas) BS Thread
Discussion in 'South West' started by Drunknsloth, Feb 27, 2011.
  1. Jan 26, 2014 at 12:36 PM
    #2541
    TheArkMaster
    TheArkMaster Well-Known Member
    Noah
    Utah
    2000 SR5 4Runner
    If only I hadn't just taken off the weekend, I would :(
  2. Jan 27, 2014 at 12:41 AM
    #2542
    The6pharaohs
    The6pharaohs WTF just happened?
    Wil
    Eagle Mountain Utah
    2017 DCSB Offroad with JBL premium tech package
    Upgraded from 2012 DCSB TRD Offroad Entune JBL w/nav
    Are there any local shops that do a good job on lifts?
  3. Jan 27, 2014 at 9:41 AM
    #2543
    Box Rocket
    Box Rocket Well-Known Member
    Adam
    Syracuse, Utah
    1995 FZJ80 Land Cruiser
    3xLocked, lifted, well used
    Cruiser Outfitters in Sandy.
  4. Jan 27, 2014 at 11:55 AM
    #2544
    Drunknsloth
    Drunknsloth [OP] Indffrnce will be the fall of manknd but who cares
    Retribution
    South West
    08 SR5 Access V6 6-Speed
    Blacked-Out Badges; Retribution Decals (Sockmonkey); Tailgate Mod; Red LED Rear Blinkers; Yellow Foglights; Yellow Front Blinkers; Superwhite Xenon Corner Bulb; Leer Bedcap; Bedrug Bedmat; Black Cupholders; Black Plastic Piece Around Window Controls; Plasti-Dip Front Bumper Valence; Plasti-Dip Grill Surround; Blackout Chrome Back Bumper; Metal Miller Skid-Plate; Aero Turbine 2525 Muffler; TSB Rear Leaf Springs and Shocks; Satoshi Grill Pending; Off-Roading Torn off Mirror (Replaced); Blue-Sea Fuse Box; Tinted Tail Lights; URD Short Shifter; Interior Mood Lighting; Hood Lights; BedLights Pending
    I'll vouch for them too
  5. Jan 27, 2014 at 12:04 PM
    #2545
    zscott
    zscott Well-Known Member Vendor
    Zach
    Utah
    13 DCSB Off-Road 4x4
    I never got to taking my truck into to have them do work due to a change in cash availability but Kurt was extremely helpful and prompt with getting information to me.
  6. Jan 27, 2014 at 12:12 PM
    #2546
    zscott
    Zach
    Utah
    Did you ever get your bushing installed? If you haven't I would try to do it yourself. I just did the install this last weekend and it was pretty easy. First thing like this that I have ever done.
  7. Jan 27, 2014 at 9:45 PM
    #2547
    Manlaan
    Manlaan Well-Known Member
    Greg
    Riverton, Utah
    2002 XtraCab SR5 V6 4x4 Black
    See Signature
    For the most part, the transmitter and receiver is all going to be about the same. CB is limited to 4watts, and with technology today, that is very easy to come by.
    There are important things with CB though. Mainly wiring, antenna, and tuning. A CB setup is not like your am/fm car stereo and needs to be properly installed.
    Antennas are all pretty standard now, but with this, you need to know what type to get. Either a grounded antenna, or a NGP (no ground plane) antenna. Overall, for the stuff you'll be using it for, it really wont matter what type you get, but if you get a grounded one, you must have a great ground connection. I guess there's also the magnetic ones as well, and they should work fine on a trail (just dont expect great performance).
    For wiring, you do need a matching cable for your antenna (GP vs NGP). It is far easier if you get a cable that is pre-built. Do not cut it to length. It will make it quite a bit more difficult to tune if you do.
    I recommend just buying the cable + antenna in a kit. Sometimes you can even get the brackets also.
    Tuning is the most important of a cb radio. This will determine if you're able to send/receive for miles, or if you just completely destroy your radio. (yes, an improperly tuned antenna can destroy your radio). There's all sorts of wave length stuff to explain it, but the end result is if you aren't tuned, you're not going to get any real distance (I've seen some that have issues transmitting 5'), will be unhappy and frustrated with the results, and can cause damage to the radio. If you need help with this, I have a SWR meter and can help (SWR meters really aren't expensive) and are pretty easy to use.
  8. Jan 28, 2014 at 4:03 PM
    #2548
    WTFaulkner
    WTFaulkner Well-Known Member
    Kris
    SLC
    Tacoma
    Stuff
    Awesome info thank you!
    Im still looking into different options as to what to get, I was going to pull the trigger and start buying stuff. But I ended up owing money on my taxes so MOD money is on hold till I straighten that out.
    Again thanks for that info, I will give you a shout if I need some assistance!
  9. Jan 28, 2014 at 6:31 PM
    #2549
    BigHeadTaco
    BigHeadTaco GFY
    Big Head
    Full OME lift 885's with Dakar leaf springs. LR UCA's. ImMrYo relocation bracket.
    Yep. Had a local shop do it. Nice and smooth now.
  10. Jan 28, 2014 at 7:16 PM
    #2550
    zscott
    Zach
    Utah
    Good to hear. I am loving the lack of buzzing in the gas pedal around 35 mph
  11. Jan 28, 2014 at 8:55 PM
    #2551
    BigHeadTaco
    BigHeadTaco GFY
    Big Head
    Yes, so much better.
    And zscott, your roof racks are sweet!
  12. Jan 29, 2014 at 6:53 AM
    #2552
    Tacoma1192
    Tacoma1192 GD MOTORSPORTS
    Kyle
    Boise, ID
    2015 DCSB Sport
    39's, LT, 4 Link, Spidertrax 9"
    My brother and I might be headed out there with the Tacoma and the RZR's. It all depends on if his wife will let him get away. If we make it out there, I'll keep an eye out for ya.
  13. Jan 29, 2014 at 9:00 AM
    #2553
    zscott
    Zach
    Utah
    Thanks, I am pretty happy with the setup. I just got a set of the new rails back from the cutter today and they are even better looking than the originals. I think people will be very happy with them.
  14. Jan 29, 2014 at 10:51 PM
    #2554
    timmyedge
    timmyedge Well-Known Member
    Timmy
    Layton, UT
    TRD OR DCSB
    Magnaflow cat back exhaust with down pipe, Volant CAI, BHLM w/new bulbs, 3000K replacement fog lights,Debadged/Painted/Re-badged to say TACO/ New JVC Dbl Din Nav in dash/ Fosgate 400W amp/ Fosgate 10" sub/Tacotunes box/ Order OME complete lift w/Daker springs and LR UCA's/Ordered SCS Stealth 6 Matte Gun Metal -265/70R17 Goodyear Duratracks, BAMF behind gril light bar, Custom Trial Ridge Sliders , bed mat, weathertechs, Wet Okles, All Pro Front IFS skid Plate, Plasti Dir rear bumper Future MODS-Skids IFS/Fuel tank, transfer, rear dif
    Sweet, since your coming from Davis County were meeting at Wal Mart on Hill Field in Layton at 8am.
  15. Jan 30, 2014 at 7:46 AM
    #2555
    Cohbsteq
    Cohbsteq Hood Rat
    Jacob
    SL,UT
    02 Supercharged 4x4
    Pretty much stock with some crap welded to it.
    anyone know a good shop that wont charge an arm and a leg to weld on some sliders?
  16. Jan 30, 2014 at 10:09 AM
    #2556
    big dog
    big dog Hug balls bitch
    Las Vegas
    03 SR5 TRD 4X4
    OME 3" k&n cai magnaflow muffler all pro front bumper 4x innovations rock sliders moto metal wheels with 33" Bridgestone dueler revo 2 AT tires
    Just ordered my wheels and tires :woot: got the moto metal mo961s black with red inserts and Bridgestone Revo 2 2856518
  17. Jan 30, 2014 at 10:19 PM
    #2557
    Jib Bandits
    Jib Bandits Pork eating crusader. An "infidel".
    Ari
    Cedar Fort, UT
    06 Access TRD Sport
    Red devil horn emblem, All-Pro Expo leafs, Fox shocks, K&N CAI, aFe throttle body spacer, Flowmaster american thunder dual exhuast, Defender roof rack, Hell Bent steel level kit, Rigid Dually LED lights, smoked halo headlights, smoked LED taillights, Cobra CB, red badge mod(+30 HP), Spider-Trax wheel spacers!
    Well looks like I'll most likely be making it. Hopefully I can find time to switch my street tires over to my mudders tomorrow. I live about 2 miles away from 5 mile so someone just text me or let me know when you guys are close to the chevron at the cross roads (SR 73 & Redwood).
    My number is 801-243-9950
    Ari
  18. Jan 31, 2014 at 8:45 AM
    #2558
    TheArkMaster
    Noah
    Utah
    2000 SR5 4Runner
    I just saw this! I wish I didn't work tomorrow or I would be totally down! I want to meet some of you Tacoma guys haha.
  19. Jan 31, 2014 at 9:33 AM
    #2559
    smkd13
    smkd13 Professional Idiot
    Ben
    Provo, UT
    19 DCSB OR
    Stock… for now
    I am in the same boat bud. And when you gonna come get your PH bar?
  20. Jan 31, 2014 at 12:02 PM
    #2560
    WTFaulkner
    Kris
    SLC
    Tacoma
    Stuff
    X3 I don't wanna work tomorrow!!:(
    I wanna go wheel!:eek:
